Question about T-Mobile Sidekick ID Cellular Phone
My sidekick's screen turn on but the backlight doesnt turn on the screen. so at night. i cant see anything on the screen. i need a light to see teh screen
My sidekick 3's backlight wont turn on
Here is a guide for it Sidekick 3 LCD Flip Screen Replacement
and here is a link to the screens
Buy a replacement Sidekick 3 LCD screen.
Sep 20, 2009 | Sharp Sidekick LX Smartphone
My Sidekick BackScreem
So if the backlight is dead, you will need to replace the lcd screen to fix that. It is pretty easy to do and runs about 25 dollars from ebay.
Here is a guide for that
Sidekick 3 LCD screen replacement guide
and here is a link for the lcd screens
Sidekick 3 LCD Screens
Jul 06, 2009 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 2008 (gekko) backlight doesnt work i can
The problem with your sidekick 2008 screen is the backlight is burned out. this can happen if dropped or if it gets wet.
The only way to fix it is to replace the screen. It is fairly easy to do and new ones run about 65 dollars on ebay.
Below is a guide for the replacement and a link to buy the 2008 LCD screen.
Replace the Sidekcik 2008 LCD screen
Buy Sidekick 2008 LCD Screen
Jun 30, 2009 | T-Mobile Sidekick "Gekko" cellular phone
My screen on my sidekick 3 doesnt work.
if its been under a year you can go to the dealer that sold it to you and get a warranty exchange
Jan 07, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Screen
Is it white or dark?
If blank white, then the cable needs to be reset if dark then the lcd screen needs to be replaced. They are easy to change and run about 35 dollars for the whole assembly.
Sidekick 3 LCD replacement guide
and here is a link to see what is availble on ebay:
Hope that helps
Dec 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Lights don't turn on
You need to replace you LCD. About 50 bucks from ebay. most come with good instructions and the screwdriver. You will need a T6 Torx driver to open the LCD.
http://shop.sidekickskin.net/SideKick-Repair-Parts/Sidekick-LCD-Screens
Jun 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Really need help please
In both cases you lcd screen has died, the backlight will usually go first.
Fixing them is easy, a new lcd screen assy can be purchased from ebay for less than 45 dollars. It only take the removal of 2 screws to replace it. Read throught the procedure below.
Here is the link to new screens
Sidekick 3 LCD Screens for sale
Sidekick 3 problems
Antonio-
You may be able to fix many of those things yourself. The trackball proabaly just needs to be clean. Does the LCD have a white screen when it is on? The Camera, well that may take some work.
For the white screen check out here: http://www.repairmysidekick.org/Fix-Sidekick-White-LCD-Screen
If it is not white, a new lcd can be had for 45 dollars on ebay.
they are easy to replace.
replacement of the Sidekick 3 LCD flip screen.
To clean your track ball, follow these instructions:
1: Take a deep breath and blow on the trackball area, rotate and do it again. This may blow any particles block the sensors.
2: This requires a Q-tip and some alcohol. Turn off your sidekick, wet the end of the q-tip, and gently clean the trackball while rotating. Be careful not to get the alcohol on anything but the trackball. Let dry for a minute and try it out. If this doesn’t work then try again.
Apr 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
The backlight on my sidekick 3
you will just need to get a new light bulb thats in the sidekick
i live in the bronx and its like around $60 bucks here idono about any other place but it can be replaced.
Feb 15, 2008 | T-Mobile Sidekick II
Backlight on sidekick 3
Because your screen is broken and that can only be fixed if you have it replaced.
Jan 14, 2008 | T-Mobile Sidekick II
T-Mobile Sidekick ID Cellular Phone Logo
103 people viewed this question
Top T-Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
SHIVAJI YADAV
SHIVAJI YADAV
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
