Question about Amana ABB1927DE Bottom Freezer Refrigerator
Frost forms on top of food in my freezer (top of refrigerator)...even inside sealed bags of items like microwave Stouffer's, etc. Sometimes up to 1/4" thick! No frost on inside of freezer though. ?????
  • 4,066 Answers
This excess frosting can be caused by leaky door gaskets, frequent door opening, dispenser door not closing good, anywhere air can get in. Gaskets should hold a dollar bill sung all the way around both doors.
Posted on Sep 24, 2009
Freezer not cooling below 20degrees, compressor and all fans working, condencer not frozen
If the freezer keeps on working, but is not able to go below the desired temperature, you should check if the freezer is able to go this low. If it does, it might be ice-forming inside, which acts merely like a thermic insulator. So if there is ice, remove it carefully. Best is to let the ice melt, by unplugging the power, and put a pan with boiling water inside. Ofcourse you need to remove all stored items / food of the freezere, before you do this. Store them in special bags (those bags with aluminium foil)
Another source can be leakage of the cooling-fluid. This is difficult to tackle, because it means most of the time : look for a new refrigerator.
Oct 14, 2013 | Maytag Admiral Top-Freezer Refrigerator
My food although in freezer bags and even store wrapped(sealed) will still end up with frost on it how can I stop this from happening?It is a ROPER
its only moisture inside the wrappings freezing,it will stop freezer burn,you could chill it before you freeze it but that means you would have to rewrap every piece of food again with a vacuum sealer.to make the packets airtight.(when we freeze homegrown veg we always vacuum pack it into portions,so it keeps better).
Dec 07, 2010 | Refrigerators
Not cooling properly
First thing- set the controls at the mid range of their settings. Next, check the coils under the fridge to see if they are clogged with dust, etc. Next, using a couple stem thermometers, determine the temps in the freezer and fresh food sections. In the fresh food section, place a tall glass of water on a shelf in the middle, put the thermometer in and let it set for awhile in the fridge. Inside the fresh food section, look for the damper opening at the top of the wall in between the two sections. Wet the back of your fingers- can you feel air blowing through the damper opening? Inside the freezer section, look at the back wall- any frost buildup there.
Hope this help.....
Jun 28, 2010 | Magic Chef CTF2125 Top Freezer...
Older (20 to 25 years old) non-frost free Whirlpool refrigerator is not cooling below 60 degrees. I defrosted it and left it off with doors open in garage for 10 hours. Turned the cooler knob to 4...
Good day,
If it is a conventional refrigerator, there should be a cooling plate on the top back of the wall in the food section.
Assuming the door fits and closes properly, and the light goes out when the door closes, the plate described above should have a frost pattern on it. That is what cools the bottom fresh food section.
If left on for plus 12 hours normal cooling should exist.
If the plate is not frosted, and the machine runs constantly, you have a freon leak with no real practical repair possible.
You could recharge it, but it would be pricey, and just repeat the problem shortly.
Jun 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
The freezer makes ice and keeps everything frozen, but does not defrost. we are getting a very fine frost on everything including the top of the freezer compartment. What is wrong?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} There are two possible causes or types of frosting. One is where the surface of the items in the freezer have frost on them. It may be in one spot or evenly distributed. This is caused by excess room air getting into the freezer because of leaky door gasket which should seal snugly on a dollar bill inserted between the gasket. Frequent or prolonged door opening will also allow room air in. The higher moisture content in the air freezes on the surfaces of the food etc.
The other cause and type of frosting is automatic defrost failure.
Jan 02, 2010 | Refrigerators
We have Kenmore side-by-side door refigerator, recently we found a problem with freezer, all the items any type of containers are getting iced in the form of a thin layer.even the sheves and most of the...
1)The door gasket on the freezer door helps keep the cold air in and the warm air out. If the gasket is dirty or damaged, it may prevent the door from closing properly, which can lead to frost buildup on your freezer walls. To make sure the door is sealing, slip a dollar bill or a sheet of paper between the gasket and the freezer and then close the door. If the bill or paper pulls free with little or no resistance, the gasket isn't sealing properly. Wipe the gasket with a damp cloth to remove dirt, grease and other residue. If the gasket is damaged, replace it with a new one. Sometimes frost can accumulate on the back panel of your freezer if the door is open too long or too often. When you open the door, you let warm, humid air inside, and this condenses and freezes. Make sure there are no packages preventing the door from fully closing, and limit how often you open the door by removing what you need all at once.
2)Ventilation is important because it ensures your freezer stays cold. If something inside the freezer blocks the internal vents, the freezer may become warm, causing condensation to form on the walls, and eventually leading to frost buildup. When loading your freezer, make sure there are no items resting against the rear wall of the freezer and space the contents out as much as possible to improve ventilation.
3)Side-by-side refrigerators with a built-in ice maker may accumulate frost if the flap on the ice dispenser doesn't close properly. This allows warm air to enter the freezer side, condense and freeze, causing frost buildup over time. Open the freezer door and examine the flap inside the ice chute. It should be flush against the housing. If it is not, empty the ice bin and make sure there is no ice or debris preventing the flap from closing.
4)If your freezer door closes properly and nothing is keeping it open, frost buildup on the back panel may indicate a problem with the freezer's self-defrost system. The self-defrost system turns off the compressor for a short time every six to 12 hours so it can turn on the defrost heater. This melts any frost buildup on the freezer coils, and the water drains to the pan beneath the freezer. If this component fails, frost continues to build. Move the contents to another freezer and turn your freezer off for 24 to 48 hours to manually defrost the interior. If frost builds up again, contact a qualified appliance repair technician to inspect the defrost timer and repair the problem.
Oct 29, 2017 | Whirlpool GR9FHMXP Top Freezer...
We have cracks forming in an 8 inch section of
you can use a hydraulic adhesive or Automotive door trim glue ( yellow) works great too these are made for extreem weather conditions ,
Aug 29, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Freezer temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.the temp depends upon your need.if you are using stronly freezers for storing food items like meat, then you can set the temperature to (0-10) degree celsius. else you can set it to (5-15) degrees.always keep the liquid items closed in the refrigerator failing to which it causes crystals.it also costs dearer since you have to defrost then. so always keep your food items covered.hope your problem is tackled..have a nice day
May 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
304 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
