Question about Maytag Neptune FAV6800AW Top Load Washer
Code od If you push the start button it says od no matter what you do or if change settings even unplugged. It said 57 min but as soon as I pushed start od please help
  • 240 Answers
The OD code should mean that the unit did not detect the door open between your loads. Try to open the door and close it a couple of time to see if it will reset itself. If it doesnt reset, then the problem could be one of three things. The first thing is the door latch assembly itself could be defective. Second problem could be the control board is defective, and is not picking up the code. The other could be the wiring itself running between the door and the control board. There really is no way of testing the control board (which is located in the console itself) or the door latch assembly. BE SURE TO UNPLUG THE UNIT BEFORE REMOVING ANYTHING PLEASE. This unit has 2 lid locks, left and right. I believe to remove the front panel you put a putty knife between the top and front panel, approx 2 inches in from the sides, and pop the two clips. Lift the top up and support in a safe way (if it swings down and hits you in the head, the door locks wont be a problem for a few hours). Check he wiring in and around the lid locks, the top, and where they pass all along the route to the console. The control boards on these units are very expensive to say the least. The part numbers for each part are:
Control Board Assembly: 25001217 Approx $175 US
Lid Lock Right Hand: 25001037 Approx $ 23 US
Lid Lock Left Hand: 25001048 Approx $ 23 US
Here is a couple of pages with diagrams that may help you a little better:
Top and lid diagram:
Front And Cabinet (Note that #14 will be the clips I was telling you about)
Let me know if you have any questions whatsoever. Just take note, that replacing one of these parts on a guess could cost you a lot of money. Pleased try to open and close that lid a couple of times to see if anything changes. And please let me know how it turns out, or if you need ANYTHING at all. Thanks and great luck. Jim
Posted on Dec 16, 2007
Set time on clock radio CS238-5G
This is the way I worked it out, as soon as you've plugged in the unit, push the MEM button for a couple of seconds then push the PLAY/PAUSE button and hour will start to flash then use the arrow buttons to change hour, then push PLAY to change minutes. Once you've finished minutes push PLAY again. Not sure about setting alarms though and if you get stuck, unplug it and start again.
Mar 26, 2014 | GPX CRCD6306DT Clock Radio
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Cuisinart bread oven menu will not change
Plug your machine in and push the menu button again and again are the numbers changing from program to program? If not push the start/stop button with no ingredients in it and if it starts kneading wait a few seconds then push the start/stop button again UNTIL IT BEEPS AND STOPS. Unplug the machine and plug it in again and the program 1 should show again, just push the Menu button until you see the number 9 program. Did that work?
Dec 21, 2012 | Cuisinart CBK-100 2-lb. Bread Maker with...
When you push the power button, the button turns green but the computer doesnt start up. The lights are on but there is nobody home, there is no sound indicating that the computer is starting up.
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 18, 2011 | Acer Aspire 9300 Notebook
When you push the "push to start" button, the
I would say change your Start button should take care of the problem.
FIRST Always unplug the Dryer before doing any work on it.
Good Luck
Dec 26, 2010 | Kenmore 62982 Electric Dryer
The tv wont power on and the green timer light continuously blinks. I have unplugged the the tv and also hit the reset button.
...OK to begin troubleshooting this. Unplug the set and leave for 1 min then plug up and leave for 2 min push the power button and let light blink for 2 min.... now push and hold at the same time the MENU and DEVICE buton st the same time. this is the self diagnoses feature ... the lights should link then pause then blink again... this 2 digit code will help narrow it down. Also have you check the lamp yet?
Oct 22, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I changed the oil but dont know hou to reset the change oil panel
open the panel with the trip/od and the mirror adjust. next to the trip/od you will see a rest button. turn the car off. weith your foot OFF the brake push the start button twice while holding in the reset button. the trip/od must be set to just odometer, no trip a or b. you will see the oil mileage reset on dash right in front of you. hold the button until it finishes. if you have navleave the ingition on and push INFO button, choose MAIT and reset the oil and filter to 5000 miles.
Oct 01, 2009 | 2007 Lexus GS 350 AWD Sedan
Switching from video1, video2, tv
First check for a button which is stuck down (activated) on the TV & remote. I have seen a stuck button on a remote box continually sending a command to the TV. Also, try unplugging the set so the microprocessor will reset. Other contributors might have seen this exact problem, and provide an exact solution.
Sep 13, 2007 | Toshiba 32A35 32" TV
Maytag Neptune FAV6800AW Top Load Washer Logo
188 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
