Question about Mitsubishi WD-52525 52" Rear Projection HDTV
New bulb and won't come on. audio works. what circuit panel controls video and light circuitry?
  • Mitsubishi Master
  • 5,138 Answers
Replace Ballast Board it is what turns Lamp on! Call Encompass for Part 1-800-638-3328 .
Posted on Sep 24, 2009
    Problem Solver:
  • 9 Answers
There are a couple of caps on the main power supply board that might be bad. The way you can tell if they are bad is if they are buldgeing at the tops. Try that first as the ballast usually runs about 100-150 bucks depending on where ya go. to fix the bad caps is the first thing you should do.
Posted on Sep 26, 2009
Radio stopped working now dash lights stay on 09 focus
With the parking lamps ON, the instrument panel dimmer switch uses electronic circuitry to provide a variable pulse width modulated (PWM) output to the instrument panel and all applicable switches depending on the driver-controlled level of intensity, The dash lights stay on with headlamp switch off ?
Have checked the fuse's for the Radio ?
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Compact disc (CD)
  • Antenna
  • Battery junction box (BJB) fuse 11 (30A) (subwoofer amplifier)
  • Central junction box (CJB) fuse(s):
    • 31 (20A) (audio unit hot at all times)
    • 41 (7.5A) (audio unit hot in RUN/ACC) (early build)
    • 57 (7.5A) (audio unit hot in RUN/ACC) (late build)
    • 62 (7.5A) (audio unit hot in START)
  • Audio unit
  • Speakers
  • Subwoofer amplifier
Do you know where the central junction box Is ?
Pinpoint Test A: The Audio Unit Is Inoperative/Does Not Operate Correctly
Normal Operation The audio unit receives voltage at all times through circuit 29-MD15 (OG/BK), voltage in RUN/ACC through circuit 75-MD15 (YE/GN), and ground through circuit 91-MD15 (BK/GN). The audio unit is operational with the key in RUN or ACC.
    Possible Causes
  • Fuse
  • Circuit 29-MD15 (OG/BK) open
  • Circuit 75-DA4 (YE/GN) open
  • Circuit 75-MD15 (YE/GN) open
  • Circuit 91-MD15 (BK/GN) open
  • Audio unit
  • Can you pull the radio out , to check power and grounds at the radio connector's if fuse's are Ok .
Dec 30, 2016 | 2009 Ford Focus
Honda civic instrument panel lights out
  1. Use a test lead with a indicator light / led to trace power to instrument cluster lights.
  2. A circuit diagram would be of assistance if you are competent to read the circuitry and symbols.
Mar 05, 2014 | Cars & Trucks
The lamp of won't work
follow the steps and fix it. God bless you
ight Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
Range lights on a over the range GE mirco wave won't work. The touch pad works and says the lights are on but no lights
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
Or you can buy and install a new control circuit board (smart board) from the Pros here, our favorite supplier.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
Oct 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Two lamps and turnable motor won't work, i already replace new bulb
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Sep 07, 2011 | Microwave Ovens
Bulb burned out but will not work with new bulb...is there a breaker or fuse?
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
Or you can order a new control circuit board. You can find handy exploded views and order parts by model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 22, 2011 | Whirlpool MH1150XM Convection/Microwave...
We replaced the light in the hood (over the stove) and there was a spark and now neither the hood nor the microwave works. We reset the circuit breaker but it did not fix the problem. Do we need a buy a...
If you prefer, you can order a new control circuit board and install it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Then you unplug the keypad (as per the photo below), remove the damaged circuit board and insert the new one.
Some connectors on the relays have a lock:
What you'd send
Jan 01, 2011 | Whirlpool MH1150XM Convection/Microwave...
My tv was accidentally unplugged while it was still on and when i turned it back on there is audio no video and the green light just flashes next the to the red light and the tv turns on and off by itself...
Hi
Thanks for using FixYa. From what you have described it seems to be a shutdown circuit problem, and a problem in the section of the TV that provides High Voltage to drive the raster creating circuitry. Usually the issue is with the bulb going bad however, as you have already replaced the bulb few months back, so in your case this would also be the DLP related circuitry which includes the light engine (white light bulb/Color wheel drive circuitry or LED array, DLP chip and associated circuitry). If you want to do the repair yourself then it is highly recommended that you should have knowledge of internal circuitry of the TV, if not then it is always better to take assistance from a qualified repair tech. The cost of repair will be around $300 including labor if you get it done by a professional.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 17, 2010 | Toshiba 52HM95 52" HDTV Projection...
Baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
No picture
Hello Fliper,
These symptoms denote a shutdown circuit problem, and a problem in the section of the TV that provides High Voltage to drive the raster creating circuitry. In your case this would be the DLP related circuitry this would include the light engine (white light blub/Color wheel drive circuitry or LED array, DLP chip and associated circuitry). In any event if you are not planning on working on this yourself (which I would not suggest for this type of problem), Have a qualified TV repair technician come over and examine the TV and give you an estimate on its cost.
I would also tell you to expect it to be rather high since for your description of the problem it looks like a light engine problem, however it could be as simple as a blown bulb or LED array. The Technician will find that out.
I hope this helps,
Thank you,
Shuttle83
Nov 25, 2007 | Toshiba 52HM95 52" HDTV Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
