Question about Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 350 doesn't turn on after trying to use it on a motorcycle plug that was wired backwards. Reset does nothing but the unit does heat up when turned on. Nothing on the screen and no audio. Any ideas? Thanks
  • Garmin Master
  • 2,130 Answers
I'm afraid that if you connected the voltage incorrectly to the Nuvi, that it has been damaged internally. Please see this link:
http://www.sharc.net/gps_dead.htm
- Jim
Posted on Sep 24, 2009
I have a Garmin Nuvi 1200 series and it shut off by itself and will not turn back on. It was fully charged when it shut off. I tried holding the on/off button for 10 seconds to try to reset, but it still...
try and get it plugged into a computer using a USB data cable, if the unit comes on most likely all you need to do is go to www.garmin.com and run a software update off the webupdater. and also try holding the power button for 50-60 seconds
Sep 09, 2011 | Garmin nuvi 350 GPS Receiver
How do I reset the pin without being at the secure location on the garmin nuvi 350
The unit can not be reset without knowing the pin code used to activate the security feature.
The unit must be sent back to Garmin to have it reset.
Mar 30, 2011 | Garmin nuvi 350 GPS Receiver
Nuvi 350 will not run on DC charger
Make sure your DC & AC charger is a OEM charger.
There is a good chance that there is a bad connection on the mini-USB port.
What happens when you plug the unit into the cradle and NOT use the mini-USB jack?
http://www.sharc.net/gps_charger_repair.htm
- Jim
SHARCNET-USA
Apr 19, 2010 | Garmin nuvi 350 GPS Receiver
When i plug in my garmin to a car charger it
u need to replace the battery, they last about 2 years on average.
Sep 10, 2009 | Garmin nuvi 350 GPS Receiver
Nuvi 755 said it was receiving GPS update. Now it
Plug the unit in , if the unit turns on, after it turns on do a hard reset, the directions should be in your manual or will be at www.garmin.com.
Jun 23, 2009 | Garmin nuvi 350 GPS Receiver
After trying to install new maps, Garmin nuvi 350 don't start
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 30, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Muni 250 Battery problem
Try fully charging it, there is a small reset button on the bottom or behind the aerial....push that and try an restart it...then...webupdater
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Jul 12, 2008 | Garmin nuvi 350 GPS Receiver
Garamin Nuvi 350...blanked out and won't turn back on.
Try the computer USB adapter. After it's been connected for about 20 seconds then try powering on the Nuvi. Even if your unit's battery is dead the USB connection should hold power on the unit so that the computer recognizes it as a Mass Storage Device (Windows). If that doesn't work then use the wall adapter and leave it plugged in for an hour or so. At that point if the unit fails to power on then push the reset button in the back under the antena and hold it in for 10 seconds while the cord is connected to the wall. This will clear any software related issues that would stop it from powering up - any other result indicates most likely a hardware failure. At least rule out your plugs.
Jun 07, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
