Question about Samsung CLP 300 Laser Printer
Stopped printing and red light on
It printed a couple pages then stopped and the red light came on.  I've opened everything that can be opened and I don't see anything jammed anywhere.  I've tried re-starting but after the lights make one cycle the red light comes back on. what should I do?
  • 1 more comment
  • Anonymous Dec 23, 2007
    I had the same problem on the same day - we got new ink but still it wouldn't do anything. Finally we emptied the ink waste tray - open the front panel and it's a gray L-shaped tray to the left of the cyan cartridge. There is a little handle to pull it out, empty it and put it back - printer works now.
  • mcla Dec 26, 2007
    My printer does the same, almost everytime I try to print a document. It starts to grab the paper, then pulls it about 4 inches and stops. The red light goes on, then I pull the paper out, unplug it, plug it back in and then it prints part of the document (only backwards this time!). I am no longer able to print anything at all! This printer is only a few months old and I'm clearly frustrated!
  • Anonymous Jan 19, 2008
    I had the same problem and pulling out the waste ink tray and putting it back in worked.
Check your ink levels as the red light comes on if the cartridges are low or empty and it will not allow you to print?
Posted on Dec 19, 2007
We have a Xerox Phaser 6350 and I was printing some copies today, when I looked over and it stopped printing magenta. So, I replaced the toner cartridge and opened the printer to make sure that everything...
Make sure you turn the printer off and back on a couple times. The fuser is not "hot-swappable"meaning you need to cycle the power for the machine to recognize it. If after doing this and you are confident that the fuser is seated correctly the next step would be to replace the fuser (part# - 115R00035). has these in stock and ships same day. Hope this helps and thanks for using FixYa!
Aug 02, 2011 | Xerox Phaser 6350/YDT Laser Printer
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
Aug 01, 2011 | HP LaserJet 1020 Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Samsung ML 1710 won't print second page
i'm thinking it's a config-related problem. i've seen a comparable problem already. could you check the settings in the printer software? there is setting that says "print first page from different tray" if its box is checked, the printer wants to print the rest of the print job from another tray, and will block when there is no other tray available.
if you find this setting is not marked, then i propose to delete the printer driver and all settings and then downloading the most recent driver from the manufacturer's website and installing that one.
May 25, 2009 | Samsung ML 1710 Laser Printer
My canom laserbase mf3110 print only one page
Well, when it comes to PDF files i found a solution. When u click the "print" icon, u get the "print" window. If u leave it as is, u will get a format/paper size error when trying to type several pages, as described by u. However, if u unmark the "Choose paper source by PDF page size", it will print as many pages as u want.
So...If u have trouble printing pages, it may work if u turn your pages into PDF format and follow the instruction above :)
Dec 20, 2008 | Canon MF3110 All-In-One Laser Printer
Samsung CLP 300 Laser Printer Logo
554 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
