Question about Kenmore Refrigerators
How does water get into door for water dispenser
  • 4,066 Answers
It goes in at the bottom of the door where the hinge is. There is a coupling there.
Posted on Sep 24, 2009
Ice switch dispenses water
If the refrigerator water dispenser is not working correctly the water supply tube in the door may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Apr 27, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
The water isnt getting thru to the icemaker, i have used a hairdryer on the water valve and still nothing , i even changed out the water valve but alas no water is being pumped thru to the icemaker, what...
Does water dispense through the dispenser ok in the door dispenser??
If yes wate r dispenses through the door ok the problem is going to be with the icemaker itself and its not sending power to the water valve when its supposed to fill so it could make the ice
If water doesnt dispense through the door check that water pressure into valve is sufficent..even if water does dispense what seems to be ok check first that thier is good water pressure into the valve before replacing icemaker
GENE
Sep 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Out of no where the water dispenser doesn't dispense water. Cannot figure out why it would do that. The ice maker works fine. We have had our Whirlpool refrigerator model #GI7FVCXWQ0 for almost a year...
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Oct 09, 2010 | Whirlpool Refrigerators
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Water Dispensing Problem
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser is not working
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 05, 2009 | Refrigerators
No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Jan 23, 2009 | Hotpoint HSS25GFP Side by Side...
No water on dispenser Model#ED5CHQXKQ01
most likely you have a frozen water line to the dispenser. it could be inside the back of the refr section that is just too cold or inside the freezer door.
either one can be tested by allowing each to warm up for 15 to 20 minutes and see if you get water thru door.
do you hear a buzz from the water valve coil when you push the dispenser lever? if so then the water line is probably frozen somewhere.
Jan 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
