Question about Toshiba Satellite M45X-S331 15.4 PC Notebook
Ctrl, not stuck, but when I go into a program, I'm prompted that Ctrl is pressed.. Key move up and down freely without getting syuck..
  • 125 Answers
Did you check both of the control keys some models have a control key on both sides of the keyboard
Posted on Sep 27, 2009
  • 733 Answers
May need to replace your keyboard.
Posted on Sep 24, 2009
How do i get into a spreadsheet when i get a message saying it can't be opened
Hi, what is the exact error code you receive? If you can provide the exact error code or message, will narrow down troubleshoot. To get around the problem, try starting Excel in safe mode. The command is "C:\Program Files\Microsoft Office\Office14\EXCEL.EXE /s".
To run the command:
1. Copy the above command without inverted commas.
2. Click Start and paste by pressing "Ctrl + V" and press the Enter key.
See if this open Excel. Thereafter, exit Excel and try opening Excel again in normal mode without the "/s" switch at the end.
If still having issue, suspect some of the system files may be corrupted. Run Office setup and hit Repair when prompted.
Regards,
Maha
Apr 29, 2014 | Microsoft Excel 2010
Tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
on Nov 12, 2014 | Microsoft Windows XP Professional With...
Tip
Toshiba Laptop BIOS Password Removal
<span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
on Jun 09, 2011 | Computers & Internet
My HP Pavilion dv5-1004 nr when I type any letters it it just types numbers numerical. Ex. I type COMPUTER I get 12345678 Num loc is NOT on I have tried numerous version of the num lk..
For laptops that don't have a Num Lock key on the Key board, go to
http://windows.microsoft.com/en-US/windows-xp/help/on-screen-keyboard
You can pull up an onscreen KB that does have a Num Lock key and mouse click it....fixit
To open On-Screen Keyboard using your keyboard
  1. Display the Start menu by pressing Ctrl+Esc (or the Windows logo key). Move to All Programs by pressing P. Move to Accessories by pressing the Down Arrow key and then Enter. Press Enter again to move to Accessibility. Move to On-Screen Keyboard by pressing the Down Arrow key and then Enter.
Feb 16, 2013 | Computers & Internet
How do I get to the onscreen key board on a Presario V2000
if you have windows Xp installed see on microsoft site:http://windows.microsoft.com/en-US/windows-xp/help/on-screen-keyboard
using kayboard: Display the Start menu by pressing Ctrl+Esc (or the Windows logo key). Move to All Programs by pressing P. Move to Accessories by pressing the Down Arrow key and then Enter. Press Enter again to move to Accessibility. Move to On-Screen Keyboard by pressing the Down Arrow key and then Enter.Or using mouse: Display the Start menu by pressing Ctrl+Esc (or the Windows logo key). Move to All Programs by pressing P. Move to Accessories by pressing the Down Arrow key and then Enter. Press Enter again to move to Accessibility. Move to On-Screen Keyboard by pressing the Down Arrow key and then Enter.
Mar 05, 2012 | HP Compaq Presario V2000 Notebook
Tip
Windows XP HELP Windows key + R = Run menu cmd = Command Prompt iexplore...
Windows XP HELP
  • Windows key + R = Run menu
  • cmd = Command Prompt
    iexplore + "web address" = Internet Explorer
    compmgmt.msc = Computer Management
  • Windows key + E = Explorer
  • ALT + Tab = Switch between windows
    ALT, Space, X = Maximize window
    CTRL + Shift + Esc = Task Manager
    Windows key + Break = System properties
    Windows key + F = Search
    Windows key + D = Hide/Display all windows
    CTRL + C = copy
    CTRL + X = cut
    CTRL + V = paste
  • Keyboard Shortcuts
  • [Alt] and [Esc] Switch between running applications
    [Alt] and letter Select menu item by underlined letter
    [Ctrl] and [Esc] Open Program Menu
    [Ctrl] and [F4] Close active document or group windows (does not work with some applications)
    [Alt] and [F4] Quit active application or close current window
    Ctrl] Lft., Rt. arrow Move cursor forward or back one word
    Ctrl] Up, Down arrow Move cursor forward or back one paragraph
    [F1] Open Help for active application
    Windows+M Minimize all open windows
    Shift+Windows+M Undo minimize all open windows
    Windows+F1 Open Windows Help
    Windows+Tab Cycle through the Taskbar buttons
    Windows+Break Open the System Properties dialog box
    explorer shortcuts
    END....... Display the bottom of the active window.
    HOME....... Display the top of the active window.
  • Type the following commands in your Run Box (Windows Key + R) or Start Run
  • devmgmt.msc = Device Manager
    msinfo32 = System Information
    cleanmgr = Disk Cleanup
    ntbackup = Backup or Restore Wizard (Windows Backup Utility)
    excel = Microsoft Excel (If Installed)
    msaccess = Microsoft Access (If Installed)
    powerpnt = Microsoft PowerPoint (If Installed)
    winword = Microsoft Word (If Installed)
    frontpg = Microsoft FrontPage (If Installed)
    notepad = Notepad
    wordpad = WordPad
    calc = Calculator
    mspaint = Microsoft Paint
    wmplayer = Windows Media Player
    control = Opens the Control Panel
  • Internetbrowser
  • type in u're adress "google", then press [Right CTRL] and [Enter]
    add www. and .com to word and go to it
  • For Windows XP:
  • Copy. CTRL+C
    Cut. CTRL+X
    Paste. CTRL+V
    Undo. CTRL+Z
    Delete. DELETE
    Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE
    Copy selected item. CTRL while dragging an item
    Rename selected item. F2
    Move the insertion point to the beginning of the previous paragraph. CTRL+UP
    Select all. CTRL+A
    Search for a file or folder. F3
    View properties for the selected item. ALT+ENTER
    Close the active item, or quit the active program. ALT+F4
    Opens the shortcut menu for the active window. ALT+SPACEBAR
    Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4
    Refresh the active window. F5
    Cancel the current task. ESC
    on Oct 12, 2010 | Computers & Internet
    Tip
    Top 10 keyboard shortcuts everyone should know
    Using keyboard shortcuts can often cut the time it takes to do something on a computer in half. Below are our top 10 keyboard shortcuts we recommend everyone memorize and use.
    Ctrl + C or Ctrl + Insert
    Copy the highlighted text or selected item.
    Ctrl + V or Shift + Insert
    Paste the text or object that's in the clipboard.
    Ctrl + Z and Ctrl + Y
    Undo any change. For example, if you cut text, pressing this will undo it. This can also often be pressed multiple times to undo multiple changes. Pressing Ctrl + Y would re-do the undo.
    Ctrl + F
    Open the Find in any program. This includes your Internet browser to find text on the current page.
    Alt + Tab or Alt + Esc
    Quickly switch between open programs.
    F1
    Open help for the program you're in.
    Ctrl + P
    Print what's currently being viewed in programs such as Microsoft Word or your Internet browser.
    Ctrl + Left arrow / Right arrow
    Move the cursor one word at a time instead of one character at a time. If you wanted to highlight one word at a time you can hold down Ctrl + Alt and then press the left or right arrow key to move one word at a time in that direction while highlighting each word.
    Ctrl + Home / End
    Move the cursor to the beginning or end of a document.
    Page Up / Space bar and Page Down
    Pressing either the page up or page down key will move that page one page at a time in that direction. When browsing the Internet pressing the space bar will also move the page down one page at a time.
    on Sep 03, 2010 | Computers & Internet
    I am trying to restore my laptop to factory settings coz I had a virus and as soon as i had pressed F10 after the Windows logo it is asking for a password. But I do not have one. Can you help?
    Keyboard Shortcut for Windows
    Getting used to using your keyboard exclusively and leaving your mouse behind will make you much more efficient at performing any task on any Windows system. I use the following keyboard shortcuts every day:
    This is usually followed by: cmd = Command Prompt iexplore + "web address" = Internet Explorer compmgmt.msc = Computer Management dhcpmgmt.msc = DHCP Management dnsmgmt.msc = DNS Management services.msc = Services eventvwr = Event Viewer dsa.msc = Active Directory Users and Computers dssite.msc = Active Directory Sites and Services Windows key + E = Explorer
    CTRL + C = copy
    CTRL + X = cut
    CTRL + V = paste
    Also don't forget about the "Right-click" key next to the right Windows key on your keyboard. Using the arrows and that key can get just about anything done once you've opened up any program.
    Keyboard Shortcuts
    [Alt] and [-] Open Control menu for active document
    acessability shortcuts
    Right SHIFT for eight seconds........ Switch FilterKeys on and off.
    Left ALT +left SHIFT +PRINT SCREEN....... Switch High Contrast on and off.
    Left ALT +left SHIFT +NUM LOCK....... Switch MouseKeys on and off.
    SHIFT....... five times Switch StickyKeys on and off.
    NUM LOCK...... for five seconds Switch ToggleKeys on and off.
    explorer shortcuts
    NUM LOCK+ASTERISK....... on numeric keypad (*) Display all subfolders under the selected folder.
    NUM LOCK+PLUS SIGN....... on numeric keypad (+) Display the contents of the selected folder.
    NUM LOCK+MINUS SIGN....... on numeric keypad (-) Collapse the selected folder.
    LEFT ARROW...... Collapse current selection if it's expanded, or select parent folder.
    RIGHT ARROW....... Display current selection if it's collapsed, or select first subfolder.
    devmgmt.msc = Device Manager msinfo32 = System Information cleanmgr = Disk Cleanup ntbackup = Backup or Restore Wizard (Windows Backup Utility) mmc = Microsoft Management Console excel = Microsoft Excel (If Installed) msaccess = Microsoft Access (If Installed) powerpnt = Microsoft PowerPoint (If Installed) winword = Microsoft Word (If Installed) frontpg = Microsoft FrontPage (If Installed) notepad = Notepad wordpad = WordPad calc = Calculator msmsgs = Windows Messenger mspaint = Microsoft Paint wmplayer = Windows Media Player rstrui = System Restore netscp6 = Netscape 6.x netscp = Netscape 7.x netscape = Netscape 4.x waol = America Online control = Opens the Control Panel control printers = Opens the Printers Dialog
    internetbrowser
    type in u're adress "google", then press [Right CTRL] and [Enter] add www. and .com to word and go to it
    For Windows XP:
    Copy. CTRL+C Cut. CTRL+X Paste. CTRL+V Undo. CTRL+Z Delete. DELETE Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE Copy selected item. CTRL while dragging an item Create shortcut to selected item. CTRL+SHIFT while dragging an item Rename selected item. F2 Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROW Move the insertion point to the beginning of the previous word. CTRL+LEFT ARROW Move the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROW Move the insertion point to the beginning of the previous paragraph. CTRL+UP ARROW Highlight a block of text. CTRL+SHIFT with any of the arrow keys Select more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keys Select all. CTRL+A Search for a file or folder. F3 View properties for the selected item. ALT+ENTER Close the active item, or quit the active program. ALT+F4 Opens the shortcut menu for the active window. ALT+SPACEBAR Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4 Switch between open items. ALT+TAB Cycle through items in the order they were opened. ALT+ESC Cycle through screen elements in a window or on the desktop. F6 Display the Address bar list in My Computer or Windows Explorer. F4 Display the shortcut menu for the selected item. SHIFT+F10 Display the System menu for the active window. ALT+SPACEBAR Display the Start menu. CTRL+ESC Display the corresponding menu. ALT+Underlined letter in a menu name Carry out the corresponding command. Underlined letter in a command name on an open menu Activate the menu bar in the active program. F10 Open the next menu to the right, or open a submenu. RIGHT ARROW Open the next menu to the left, or close a submenu. LEFT ARROW Refresh the active window. F5 View the folder one level up in My Computer or Windows Explorer. BACKSPACE Cancel the current task. ESC SHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing.
    Use these keyboard shortcuts for dialog boxes:
    To Press Move forward through tabs. CTRL+TAB Move backward through tabs. CTRL+SHIFT+TAB Move forward through options. TAB Move backward through options. SHIFT+TAB Carry out the corresponding command or select the corresponding option. ALT+Underlined letter Carry out the command for the active option or button. ENTER Select or clear the check box if the active option is a check box. SPACEBAR Select a button if the active option is a group of option buttons. Arrow keys Display Help. F1 Display the items in the active list. F4 Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE
    If you have a Microsoft Natural Keyboard, or any other compatible keyboard that includes the Windows logo key and the Application key , you can use these keyboard shortcuts:
    Display or hide the Start menu. WIN Key Display the System Properties dialog box. WIN Key+BREAK Show the desktop. WIN Key+D Minimize all windows. WIN Key+M Restores minimized windows. WIN Key+Shift+M Open My Computer. WIN Key+E Search for a file or folder. WIN Key+F Search for computers. CTRL+WIN Key+F Display Windows Help. WIN Key+F1 Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ L Open the Run dialog box. WIN Key+R Open Utility Manager. WIN Key+U
    accessibility keyboard shortcuts:
    Oct 19, 2008 | Computers & Internet
    Computers & Internet Logo
    85 people viewed this question
    Top Toshiba Computers & Internet Experts
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
