Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Usb can't connect to the PC - Motorola Mobility MOTOKRZR K1 Cellular Phone
Connection with PC by USB
Be sure the USB cord being used is not just a charging cord(it will have the "trident" picture on it if it is for data transfer)
Oct 07, 2012 | Android Galaxy Ace
Sir i need procedure for connecting with pc sir..please help me sir
To connect your phone with a PC, there are several ways, but i will explain two ways in which you can connect your PC.
1. Via Bluetooth: You can connect your PC via bluetooth by turning ON your bluetooth from your PC and your phone to establish a connection. Search for your PC from your phone.
2. Via USB cable: You can connect your phone to your PC via USB cable. You will connect your USB cable from your phone and insert it into a USB slot to be able to copy files to your system.
Best regards
Aug 10, 2010 | LG KG800 Cellular Phone
HI Sir, My Samsung Corby F339 Mobule is not connect in my pc showing error 692 there was a hardware failure in the modem(or other connecting device) plz help me.....
This error usually comes when you use usb cable to connect the phone to pc . Please try to unplug the cable and plugin the USB cable to another port and try via pc suite to connect to internet. If still it is not working try to connect on another pc via same USB cable to phone. If you are getting the same error still then this means the USB cable is damaged then change the USB cable and you can connect to PC. If USB cable works with other pc then reinstall pc suite or try connecting by creating dial up connection.
May 24, 2010 | Lands Phones
Usb speed problem
I am not sure you can fix it there or different USB types.
  1. USB 1.0 Specified data rates of 1.5 Mbit/s (Low-Speed) and 12 Mbit/s (Full-Speed).
  2. USB 2.0 Added higher maximum speed of 480 Mbit/s (now called Hi-Speed).
Only certian motherboards have the USB 2.0..
That would seem to be the issue..
Sep 14, 2009 | Computers & Internet
Cannot connect my PDA to PC
Normally for when you connect any device to pc using USB port, windows detects it. Sometime it may take time.
Few initial things you may check....
1) You must have your PDA in ON condition
2) If PDA is not getting connected on port, try connecting to other USB port (assuming that pc normally have more than one USB port)
3) Make sure the cable that you are using between PDA to PC is working properly (normally you can check this by using other cable)
4) If you have intalled some anti virus program on your pc then check the settings of same.
5) last but not least check the settings of window's firewall (part of OS)
If everything of above is fine then either USB ports of pc or of PDA might not be working.
All the best!!
Regards,
Av
Dec 10, 2008 | Computers & Internet
My PC hangs sometimes when I connect my USB device into USB.
what kind of pc, what kind of operating system, how old is pc, what kind of device are you connecting... Fill in some blanks please.
Sep 12, 2007 | Computers & Internet
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
What should I do if my PC still won't recognize the camera after I reinstalled the USB drivers?
If the camera is still not recognized after the USB driver has been re-installed, one of the following situations may apply. "PC Camera" may be selected as the USB setting on the digital camera. Change the USB setting to DSC or select DSC in USB MODE. (This only applies to models with a USB Setting or USB MODE option in the SETUP screen.) Does the LCD monitor on the digital camera show that the USB connection is active (USB, DSC or a USB symbol with an arrow, etc.)? If not, the digital camera and PC may not be connected correctly. Check the items listed below. a) Restart the PC and reconnect the USB cable. b) If the PC has multiple USB ports, connect the cable to a different USB port. If steps a) and b) have both been tried and there is still no USB connection indicator displayed on the LCD monitor, there may be a problem with the digital camera or USB cable. Contact an authorized Fujifilm service center and ask them to check the digital camera together with the USB cable. Refer to the Digital Equipment Repair page for information such as the procedure for requesting checks and the locations of authorized Fujifilm service outlets. The USB driver may not be installed correctly. Download the USB driver from the Digital Camera Downloads page and re-install the driver The camera may not be recognized correctly if it is connected to an added USB interface board or via a USB hub. Always connect the camera directly to the USB port on the PC
Aug 30, 2005 | Fuji FinePix 2300 Digital Camera
If the camera is still not recognized after the USB driver has been re-installed, one of the following situations may apply. "PC Camera" may be selected as the USB setting on the digital camera. Change the USB setting to DSC or select DSC in USB MODE. (This only applies to models with a USB Setting or USB MODE option in the SETUP screen.) Does the LCD monitor on the digital camera show that the USB connection is active (USB, DSC or a USB symbol with an arrow, etc.)? If not, the digital camera and PC may not be connected correctly. Check the items listed below. a) Restart the PC and reconnect the USB cable. b) If the PC has multiple USB ports, connect the cable to a different USB port. If steps a) and b) have both been tried and there is still no USB connection indicator displayed on the LCD monitor, there may be a problem with the digital camera or USB cable. Contact an authorized Fujifilm service center and ask them to check the digital camera together with the USB cable. Refer to the Digital Equipment Repair page for information such as the procedure for requesting checks and the locations of authorized Fujifilm service outlets. The USB driver may not be installed correctly. Download the USB driver from the Digital Camera Downloads page and re-install the driver The camera may not be recognized correctly if it is connected to an added USB interface board or via a USB hub. Always connect the camera directly to the USB port on the PC.
Aug 29, 2005 | Fuji FinePix 3800 Digital Camera
Aug 29, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
