Question about Samsung RS2556 Side by Side Refrigerator
Where do we connect the hose for the water line?
  • 358 Answers
In the in back of the fridgeat the bottom you'll see a dual plastic valve (probably is light blue) it has a tread sticking out (1/4") , that's where you connect the water line.
Posted on Sep 24, 2009
Washing machine leaking at the back
I would start by checking your hose connections for the water lines, they look like a garden hose connection, and you can replace the rubber washers in the ends of the hoses. Make sure they are tight and look for where the water is coming from, sometimes you get lucky and its a water hose that loosened up from vibration over time. If its not coming from the water lines its most likely an internal seal on the drum, or a leaking connection at the water pump. I would try and track down exactly where its leaking from first and if its an easy fix like the water lines try that before calling for a service/repair service to come look at it, could save a lot of money!
Jan 11, 2018 | Washing Machines
Hot water supply to washer works,but not cold water
Probably the small filter screen in the cold water supply line is plugged up with sediment. The screen will either be directly on where the hose connects to the supply line, or may be on the rear of the washing machine where the cold water supply line connects to the washer, usually a simple screw-on just like a garden hose.
Jun 25, 2014 | Bosch WFMC 3200 Front Load Washer
Kenmore water hose
If it is not connected to the freezer unit - it cannot make ice.. Ice is frozen water - you have connected a separate line that seems to have nothing to do with the fridge unit.
May 09, 2013 | Freezers
ENGINE COOLANT LEAK FROM BACK OF ENGINE WHERE IS THE WATER PUMP LOCATED
Hopefully just a water hose or connection leak...some parts of these hoses are now metal, and rust away...these factory metal hoses are dealer, and salvage yard only...Many times you can replace the entire metal line with a rubber line...as long as you can connect to both sides...there is a water hose that runs under the coolant overflow, to the firewall...(many times the culprit)...the water pump on your motor is under a pulley located on the front of your engine...Hope this helps.
May 13, 2011 | Oldsmobile Alero Cars & Trucks
Connected shower head to hose and the hose connection to shower head leaks back toward line. There is a white end over the inside of the end of the hose. I believe this restriction is causing the line to...
I understand that the white vac breaker end should be connected to the valve not the hand shower. FYI a little leak from this connection when the water is switched off is normal.
Sep 27, 2010 | Water Pik Shower Head
Leaks water and water line not connected
The water is coming from the evaporator coil during defrost. The water is supposed to get caught in a pan and then down a hose to another drip pan where it can evaporate from the heat off the compressor. I would check the pan under the evaporator and where the hose connects to it. The hoses fall off all the time.
Hope this helps
Apr 20, 2010 | Samsung RS2534 Side by Side Refrigerator
Power Washer has no pressure, any ideas
1. If you have an inlet chemical injection valve make sure that the hose is intact and that the valve is closed.
2. Purge all air from the line by holding the nozzle actuation lever open until all air has been purged. When you connect the water supply hose turn it on before connecting the high pressure hose and let the unit self purge to the pump outlet high pressure hose fitting. Then connect the high pressure hose.
3. You could have a stuck spring and ball inside the high pressure head of the pump. You can tip the unit on its' side and add a substantial amount of WD-40 to the water supply hose fitting in an attempt to free the springs and balls.
4. Try BRIEFLY running the unit without the hose connected to see if there is high pressure water ejected from the high pressure fitting.
5. Inlet water screen at hose connection is clogged (hose screen and rubber) Check screen for debris.
6. The water strainer is clogged. (Almost looks like an LPG regulator just after but in line of the supply hose connection to the pump)
Order of troubleshooting
1, 2, 5, 6, 4, then 3.
Thanks for using FixYa!
Kelly
Mar 19, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Frigidaire frig ice maker line leak
Could you put a small circular hose clamp on the hose line?
Apr 23, 2017 | Refrigerators
The water does not drain out. Water in tub bottom
hi Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
Sep 13, 2008 | Amana Dishwashers
Samsung RS2556 Side by Side Refrigerator Logo
130 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
