Question about Sony Ericsson Walkman W810i Cellular Phone
My w660 is not working. when I turn on the switch, it will lit for 2 seconds but nothing happens, no display at all.
Model mgh-055 furnace. Why won't it light?
Pushing down the button causes enough gas to be fed to the pilot to allow it to be lit and remain burning. If nothing happened, the gas valve could be at fault.
Sep 20, 2015 | Heating & Cooling
I am reposting this question with more detail in hopes that someone can help me! I have Lenovo Y550 that has been sitting for several months without being used. It was working fine the last time it was...
You may need to remove all the power from the device including the CMOS Battery. As well try using an external display to see if there is any display.
Oct 27, 2013 | Lenovo Y550 Notebook
My sansa fuze 8gb won't turn off the screen is blank but the blue light around the wheel is sitll lit. When i tried to plug it into my computer it still did nothing. i just bought this 2 months ago and am...
You should be able to hold the power button (as if you were turning it on) for 20-25 seconds, which will shut it off completely. It should work as if nothing happened when you turn it back on again. Hope this works for you!!
Jul 10, 2010 | SanDisk Sansa Fuze MP3 Player
On boot up a lock symbol with a '9' is lit & nothing else happens
the "9" inside a lock means that your Num Lock button has been pressed. If all you see is the ">" then maybe you are looking at what's called a DOS prompt, and I have no idea why that would display. Try holding the Power Switch for 10 seconds and restart your computer. Hopefully things will be better, and you know where your Num Lock key is.
Oct 10, 2009 | Dell Vostro 1500 Notebook
Powers up but black screen shows
1st - Try pressing <Fn> + <BrithnessUP> keys a few times, (on HP <Fn> key is between <Ctrl> key and <Windows> key, <BrightnessUP> key is <F8> key and <BrightnessDown> key is <F7> key. If nothing happens try the 2nd one.
2nd - Plugin external monitor, (type and size doesn't matter). Turn on your laptop. If you can see desktop on the external monitor, your drivers are o.k., The problem is your laptop display, NOT the graphic chip.
Oct 21, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Kenwood XD 550 stereo start-up problem
this normally happens with a lot of sets! It usually happens during a Power Failure, Power Surge (Fluctuation) and if the wire of the component is taken out from the wall outlet while the system is on...To get rid of this problem all you need to do is to press the Display button on the main unit, it is located just below the main display! Voltage Selection has got nothing to do with this problem...
Jun 29, 2008 | Jwin JK-777 Nostalgic Stereo System with...
My xs 700 won't stay on
it is worse do you know why it problay be the xs 700
May 03, 2008 | Crown XS700 Amplifier
System is lit with no display does not turn on
your set needs to be repaired have a tech look at your set, the power supply is defected along with the audio output.good luck
Jun 03, 2007 | Teac CD-X8 CD Shelf System
Interior display
the interior display on my nokia 9300i does not work. It comes on in that there is a lit display but nothing else happens. HELP
Jan 22, 2007 | Nokia O2 9300 9300I Flexible Mini Boom W/...
Sony Ericsson Walkman W810i Cellular Phone Logo
51 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
