Question about Samsung RS2556 Side by Side Refrigerator
Where do we connect the water hose - Samsung RS2556 Side by Side Refrigerator
    Sergeant:
    Champion:
  • 255 Answers
Trace small white water lines on back of unit to the small 3/8 water port fitting.
Posted on Sep 24, 2009
How do i change a thermostat in a 1996 mercury grand marquis
Hi, Welcome to FixYa.com my name is Shawn and I will be answering your question.
  1. Partially drain the engine cooling system so that the engine coolant level is below the water thermostat (8575).
  2. Disconnect the upper radiator hose (8260) from the water hose connection (8592).
  3. Remove the two water outlet connection retaining bolts.
  4. Remove the water hose connection gasket (8255) and water thermostat from the intake manifold (9424). Inspect water hose connection gasket for damage and replace if necessary.
Installation
  1. Install the water thermostat, water hose connection gasket and water hose connection as shown.
  2. I hope my assistance helped you and resolved your concern, if you need further assistance please ask.
Aug 07, 2011 | 1996 Mercury Grand Marquis
Tip
How to troubleshoot water leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Check the lid seal. If faulty, replace with a new gasket.
- Check the hoses at faucet connections. Tighten connections or replace hoses.
- Check the hoses at water valve connections. Tighten connections or replace hoses.
- Check the drain hoses. Tighten connections or replace hoses.
- Check the inlet nozzles. Tighten connections or replace nozzles.
- Check the splash guard. Tighten connections or replace.
- Check any plastic valve. Tighten connections or replace.
- Check the outlet hose to drain. Tighten connections or replace hose.
- Check the water pump, using the procedures that follow.
on Jan 16, 2010 | Washing Machines
I have a 2000 taurus can you show me how do I change the thermostat on my car
3.0L OHV Engine
Fig. Exploded view of the water hose connection and the thermostat assembly - 3.0L OHV engines (click over pic for zoom)
  1. Drain the coolant until the level of the coolant is below the level of the thermostat.
  2. Disconnect the upper radiator hose from the water hose connection.
  3. Unfasten the three water inlet connection retaining bolts and remove the water hose connection.
  4. Remove the gasket and thermostat from the water hose connection. Discard the gasket.
To install:
  1. Clean the water inlet connection mating surfaces.
    NOTE The jiggle valve on the thermostat must be in the up position.
  2. Place the thermostat in the water hose connection making sure the thermostat jiggle valve is facing up.
  3. Install the new gasket and place the water hose connection assembly into position.
  4. Install the water hose connection assembly retainers and tighten them to 89-124 inch lbs. (10-14 Nm).
  5. Connect the upper radiator hose to the water hose connection.
  6. Fill the engine with coolant, start the engine and check for leaks.
  7. Stop the engine and top off the coolant recovery reservoir as necessary.
3.0L DOHC Engine
Fig. Exploded view of the water inlet connection and the thermostat assembly-3.0L DOHC engines (click over pic for zoom)
  2. Raise the vehicle and support it with jackstands.
  3. Disconnect the lower radiator hose from the water inlet connection.
  4. Unfasten the two water inlet connection retaining bolts and remove the water inlet connection.
  5. Remove the O-ring seal and thermostat from the water inlet connection. Inspect the O-ring for damage and replace as necessary.
To install:
  2. Install the O-ring, thermostat and the water inlet connection. Refer to the accompanying illustration If you can-t remember how the O-ring and thermostat are positioned.
  3. Install the water inlet connection assembly retainers and tighten them to 71-106 inch lbs. (8-12 Nm).
  4. Connect the lower radiator hose to the water inlet connection.
  5. Fill the engine with coolant, start the engine and check for leaks.
  6. Stop the engine and top off the coolant recovery reservoir as necessary.
Good luck (remember to rate this answer).
Apr 27, 2011 | 2000 Ford Taurus
I am getting the error code "HC" since we replaced a hot water heater. What does it mean? How might I correct this? Whirlpool Cabrio
There is most likely debris from the plumbing repair / install of the hot water heater that has migrated into the inlet screens of the washing machine. Turn off the water supply. Remove the water hoses from the water inlet valve and then use a thin bnladed kinfe to coax the inlet screens out of the inlet water valve body. Wash then under slow running water by gently rubbing your fingers over them until they are clean. Hod the screens up to a light source to make sure you have them totally clean. Reinstall the CLEANED screens and connect the water. This should correct the HC code.
If not there is one more series of steps to do:
- Water supply OFF
- Remove both hoses at water valve inlet
- Remove the inlet screens
- Reconnect BOTH hoses to the inlet water valve.
- Remove ONE hose from the Wall water supply and place it in a bucket TURN ON THE REMAINING HOSE connected to the wall.
- Start a WARM fill cycle and tap the water valve hose connections with the HANDLE of a hammer or the head of a very large screw driver while the unit is filling. (15 seconds)
- Stop fill cycle and turn off water to connected hose
- Reconnect removed hose to the wall connection.
- Reverse hose positons and place 2nd hose in the bucket. Thern ON the hose still connected to the wall.
- Start a WARM FILL cycle.
- Gently tap the water valve hose connections 15 seconds
- STOP Fill
- reinstall inlet screens and connect all hoses.
- test fill cycle and return to normal service
Thanks for choosing FixYa,
I am Kelly
Mar 16, 2011 | Washing Machines
Where is the thermostat on a 2002 sable?
Try this:
3.0L DOHC Engine
To install:
3.0L OHV Engine
To install:
    Fig. Exploded view of the water hose connection and the thermostat assembly-3.0L OHV engines
    Fig. Remove the upper radiator hose from the water outlet
    Fig. Remove the water outlet retaining bolts and . . .
    Fig. . . . remove the outlet from the engine
    Fig. Remove the thermostat from the water outlet
    Fig. Inspect the water outlet connection for cracks or damage
    Fig. Thoroughly clean the mating surfaces of the water outlet and . . .
    Fig. . . . the engine before installing a new gasket
    Fig. The jiggle valve must be in the up (12 o-clock) position after installation into the water outlet
Jan 19, 2011 | 2001 Mercury Sable
Pav3300 water pressure in machine very low. Is there a filter pressure at end of hose is excellent thanks fred
Hi Fred. Turn off the water and clean the water valve inlet screens inside the water valve.
-Remove the hose connection to the washer.
-Use a knife blade at the outer edge of the screen and pull it out.
-Wash the screens under slow running water rubbing it with your fingers.
-Reinstall screens
CHECK hose water flow into a bucket by turning on each hose. Slow flow= plumbing problem
Good flow = Connect hoses to washer
Before you turn on the water check the wall connection end of the hoses. Sometimes there are hose screens there also. If there are screens in the wall connection end of the hose remove the screens and wash them.
Thanks for choosing FixYa.
Kelly
Sep 20, 2010 | Maytag Washing Machines
WATER IN WASHER WONT SHUT OFF
Hi and welcone to FixYa. I am Kelly. When water wont shut off no matter what you do the problem is inside of the water valve assy. Usually there is a small bit of debris in the diaphram center hole that is holding the water passage open.
Here is what you can try to do to clear if BEFORE replacing the eater Valve.
1. Get a bucket
2. Turn off both water supply hoses momentarily
3. Set the water temp to warm
4. Remove ONE hose from the wall connection and place the hose in a the bucket.
5. Turn on the remaning connected hose/
6. Start machine fill cycle and tap the hose connection at the water valve on the back of the machine with either a screw driver or hammer handle.
Timer OFF
REVERSE HOSE CONNECTIONS ON THE WALL CONNECTION.
7. Place the other hose in the bucket
8. Start Fill cycle.
9. Again tap the hose connection at the water valve
10. Stop timer.
11. Reconnect both hoses and test for water flow with timer off.
12. Start fill cycle
13. Rapidly select hot and cold wash water.
14. STOP fill cycle.
15. Remove each hose individually from the water valve one at a time.
16. Use a knive blade and remove the inlet screen from the water valve. Wash screen under slowly running water rubbing it clean with your fingers. Re install screen. Reconnect water hose.
17. Repeat step 16 for opposite hose and screen.
18. Turn on water supply.
19. Test for proper filling and water stopping by starting and stopping fill cycle.
If it works you got lucky. If you still have the problem you will need to change the water valve. Either one of these water valves will work on your machine:
http://www.repairclinic.com/Appliance-Parts?s=t-PAV2300-%3d%3dc292d509361
Thanks for using FixYa.
Kelly
That is about it
Jun 05, 2010 | Maytag PAV2300 Top Load Washer
Old admiral clothes washer leaks at front
Troubleshooting Water Leaks
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Aug 25, 2009 | Maytag PAV2300 Top Load Washer
Water pouring out from soap tray !!!
hi Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Sep 13, 2008 | Washing Machines
Mavt634 cold water comes out the hot water inlet connection
Need to make sure that the water connections are correct - first that the hot water hose and cold water hose have not been interchanged and then if they are correct try interchanging the electrical connections to the water valves.
Mar 10, 2008 | Washing Machines
Samsung RS2556 Side by Side Refrigerator Logo
73 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
