Question about HP Computers & Internet
I no longer have an N key!
My N key got jammed somehow and started peeling off. as you can tell it's still functioning but i'm actually touching the white (inside part of teh key) the entire N came off! help please!
    President:
  • 3,278 Answers
Hi, Laurene !
Use a small dab of Blu-Tack or other adhesive and press the key back on.
Hope this helps.
Posted on Sep 24, 2009
Dead computer
have you had the chip tested in the key would start there first. you should be able to put an ob2 reader on the car as long as the key turns the ignition and the lights on the dash come on. just will not bypass the immobilizer, but you should be able to find out if the ecu is at fault or alarm. the alarm and immobilizer are linked. they then open the ecu so the engine can be started.
Sep 26, 2013 | Ford Taurus Cars & Trucks
I have ZERO functionality on the right side of my motorola s9 headphones. No button function, no music, no nothing.
Motorola Headset S9 Control Keys Prob.
Hi
i am using motorola S9 for last one year.
I had the same problem of controls keys which i have corrected of my own.
Most of the sites i read say's this problem is due to the moisture.
Let me tell its not because of moisture.
Below steps will help you guys hopefully if its only the keys control problem.
Take the headset,The control keys are placed near the ear plugs within a area
which is different from the other part.
now what u have to do is just take some sharp thing or your nails enough and
move it around the control keys area (edges) and peel off the rubber layer
carefully.Please note its very soft rubber so be careful not tear it off else it
will be spoiled completely.
After u remove this layer u wll find layer of plastic attached to the rubber
whichh u took out and the same kind on the base. you will fin ther will be
small vertical lines and center one dot on the peeled out rubber and on base
horizontal 2-3 thin lines at the edges and dot at the centre.
actually thes are the contacts which acts as a switch if u observe it would have
been covered with the rubber kind of gum used to stick thes layers.
Just clean these (only)contacts area with piece of cloth and use some rubber kind
of glue (Do not use Feviquik it will spoil the strips completely) at edges and put
it back ,b4 fixing it gum u can test it by just keeping it and check if the keys
are working then fix every thing as it was b4 and stick the peeled out rubber panel
with the same type of glue.
there u are ur problem is solved enjoy the best music experirnce with your S9.
If u have any problem or Queries please post it i wll try to answer as soon as
possible.
if u want a video for this i wll b up loading it soon and post d link.
Dec 21, 2010 | Motorola Mobility S9 Headphones
I don't have the door key to my 1997 Nissan Maxima and my remotes are no longer working at all, how can I bypass the alarm going off so I can drive the car? The anti theft system won't allow it to start
after the alarm stops going off... do not touch anything... wait 10 minutes or longer... if you are in the car with the doors closed, and the alarm has run through it's cycle and is no longer sounding, do not touch the locks or open the door you will set off the alarm again each time you do this.... attempt to start the vehicle, it will probably just turn on but wont crank or start. this is the immobilizer. It thinks you are tying to steal the car. Since the 97 does not have a key with a chip in it, it will eventually start. However, only after I waited almost 20 minutes without touching anything except to put the key in the ignition and try to start the car withdrawing the key completely each time. This has only happened to me twice because I just don't lock the car anymore. I keep nothing of value in it ever. Each time I got the car to start after waiting and apparently it will start after some time if you push to roll down the driver side window... Haven't been able to find any other mention of this on the internet, somehow this was the trick to getting the car to start again after my remote quit working, and like you i only have a worn down ignition key. It worked for me with all doors except for the drivers side closed. I just kept trying to insert the key and start it, while rolling the drivers side window up and down. Eventually it started after like 30 minutes and after one press to roll down the drivers side window.
Oct 01, 2010 | 1997 Nissan Maxima
Paper jam
You have a piece of paper stuck in one of the switches that tells the machine you have a paper jam. One of the worst things to cause these are printing peel off labels as they sometimes peel off while printing and get caught in the mechanim. You have a jam it's just not a full size piece.
Jun 01, 2009 | HP LaserJet 3030 All-In-One Printer
How to feed labels on zebra s4m
The issue that is causing the problem is when users tear off the label they are actually partially pulling on the next label causing it to peel away a little then when it feeds it will jam. Only reliable way to stop this is once the user prints tell them to press feed and feed 1 label through.
Mar 31, 2009 | Zebra S4M Thermal Label Printer
Sub zero paint peeling
I have found no fix for this. I have tried repainting but it is not long before the paint is falling off again. Get ahold of sub-zero and tell them of the problem.
Jan 23, 2009 | Sub-Zero 650 / O Bottom Freezer...
Actually question for the Panasonic UF - 7000
Funtion #7, go to faxparameters and set parameter 12 to always
Aug 08, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Programing numbers to dail
for one touch keys. press the fax button
1---function-7-4-start-1-1-9-start-1"qwerty key board"-start-stop
2---function-7-2-start-1"one touch"-press the speed dial you want to program"- enter number-start-enter name start-((do another one or hit stop))
if its name search let me know
Jul 18, 2008 | Panasonic DP190 All-In-One Laser Printer
Non-stick peeling off
You should get in touch with the manufacture service rep, or directly in touch with them to find out how to order spare parts.
I found that with Tephlon coatings, after some time they all start to peel and not perform very well.
Jerry G.
Jun 27, 2008 | VillaWare 3900 Krumkake Baker
Function+F5 not working
Check bios if you disabled somehow the fn key.
Jan 01, 2008 | Acer Aspire 5004WLMi Notebook
Computers & Internet Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
