Question about Karcher K2.26 Electric Power Washer
Pressure does not exist, motor? won't shut off- help
Water pressure does not exist. the motor? keeps running when you pull the trigger, and keeps running even when you turn the switch off. I love this little machine, please help.
stug_57u
  • 99 Answers
SOURCE: No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Posted on Nov 01, 2008
trav998
  • 26 Answers
SOURCE: pressure washer
call kartcher
Posted on Nov 05, 2008
david04928
  • 102 Answers
SOURCE: the motor is pulsing on and off without the trigger being pressed
It is probably sucking air on one of the connections or around one of the fittings at the regulator. You can also turn the pressure up allittle on the regulator, that might stop it also. Make sure the clamps on the hoses going to the regulator is tite. Also it could be that the regulator is just bypassing water and if it has air in it it will pulsate.
Posted on Mar 15, 2009
  • 92 Answers
SOURCE: Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare parts...you can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Regards,
Fulltech.
Posted on May 30, 2009
  • 623 Answers
SOURCE: POWER CRAFT BY Karcher bought Aldi on 31Mar 05.2100Watts 130 bar.
You did winterize the machine? Leaving water in a powerwasher will freeze and damage the pump. It's a common happening, because people don't think of it or are not told by the maker.
Posted on Apr 30, 2010
Husky 1800 Pressure Washer motor will not turn off when wand trigger is released
I think you have one of two things going on hear, an overpressure problem or a carburetor issue with the engine.
Jul 25, 2017 | Husky Garden
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
I switch the pressure washer on motor starts pressure builds up motor stops. OK pull the trigger on the lance the moter starts sounds different water pressure low. Release trigger motor still runs.
It isnt very clear your explanation of the problem but what type washer do you have first? It sounds like you have a bad unloader or need a new variable nozzle tip. Can you explain in more clear detail. Thanks
Feb 16, 2015 | Garden
Why does the motor run when I do not pull the trigger of the gun after the high pressure washer is turned on? The motor is supposed to run only if the trigger of the gun is pulled and shuts off when the...
When water is running through system, the motor has to run to keep the pressure built up. So, if the water is leaking out, the motor think it needs to keep running to keep the pressure built up. The leak needs to be fixed to the motor will not run constantly.
Jun 16, 2014 | Karcher PSI Electric Pressure Washer
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Karcher pressure washer 620m motor only runs with switch held down but will not water pressur is the same as tap pressure out the nozzle
it is not uncommon that the switch is bad? if the switch controls the pressure telling it their is water and to start working? then i would just replace the switch.
Dec 17, 2013 | Karcher Garden
I get hose pressure from my Brute 2600 psi, 6.75hp power washer when the engine is not running, but when I start the engine, I get no additional motor pressure.
The pressure you have when the motor is not running is supply pressure through the unit. When you start the motor it will build up pressure then shut the pump action down until you pull the trigger of the gun. When you release the trigger the pressure drops to zero . This happens through a relief valve that the pressure hose is connected to. If what I stated is not happening then there is a problem with insufficient water supply to the machine or a problem in the relief valve.
Sep 28, 2013 | Yamaha Kawasaki Genuine Kvf750 Brute Force...
Portercable Pressure Washer Model PCH2401
when the trigger for the wand is not pulled , there is a pressure relief valve that bypasses the water in the pump and so there is no pressure until the trigger is pulled again.
with the pump getting hot and not being able to pull the motor to restart, it indicates that that pressure relief valve has jammed ( faulty ) and the pump is running at full pressure all the time
That will heat the pump and stop the engine from restarting
That valve is where I would start looking for a problem
Apr 25, 2017 | Porter Cable Garden
My electric Karcher pressure washer does not shut off.
this can be that you need to bleed the system of air or that there is a problem with your trigger gun sticking when you release the trigger.
These are two things I would check before you go into the machine.
May 14, 2012 | Karcher Garden
Won't stay running
Pressure washer when you first try to start them that stop underload. We had the same type of problem with 11 hp Honda if you hold the trigger open the motor will be under less load we found by running the motor for about a minute it would work normally. Remember to make sure the water hose is turned on pull the trigger on, until water is coming out of the wand , now try and start the motor but also hold the trigger open, now you will not be building maximum pressure, after about a minute release the trigger and see if it keeps running.
Feb 19, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
Karcher K2.26 Electric Power Washer Logo
282 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
