Question about LG LRSC26980 Refrigerator
LG fridge waterline broke
I discovered that the waterline had broken and was spraying water, probably for a few weeks.
The water seeped under the hardwood floor and needed to be replaced.
I am so upset because I spent $2500 on this fridge and it's now costing me another $4000!
LG should reimburse me
  • gillville482 May 11, 2010
    Lg is not responsible for home damage unless there is evidence that the appliance failed. That is why you carry home owners insurance.
    Sergeant:
    Champion:
  • 255 Answers
Witch water line, one on the fridge or external line going to the house water line ? did you install the water line to the house water line or did they install it ?
Posted on Sep 24, 2009
How to connect water line to water inlet valve
The brass ring cannot be reused. You cannot buy it separately but it is inside any 1/4" fittings available in your local adware store.
be sure to cut the end of the waterline and install the ring on a Fresh section. Also, make sure the waterline is lined up with the valve inlet before trying to tighten up.
May 19, 2014 | LG LSC26905TT Side by Side Refrigerator
Need to replace water line inside freezer door.
Water lines inside doors are typically not serviceable as the insulation is "foam in place". Pulling apart the door and reassembling will be next to impossible. Generally the door would need to be replaced.
Apr 14, 2014 | Samsung 24.8 Cu. Ft. Side-by-Side...
Internal waterline broke
i would need a model number because in most cases if the water line broke in the door, you would have to replace the whole door assembly.
Dec 30, 2012 | Refrigerators
I have water seeping out from under the refrigerator. I have takenteh front grill out but cannot accesst he pan. I suspect a pump or waterline problem. My Refirgerator is a 1995
Can be the auto defrost water is overflowing in the collection tray.
It can be plumbing lines leaking in the inlet.
it canbe the deffrost tubing leaking onthe way down or the evaporator tray leaking out.
Best is to drain and check once again with the fridge moved forward and inbetter position to check.
Sep 23, 2010 | Whirlpool Refrigerators
Copper waterline is broken
Hi .. there should be piping connectors at each end of the tubing. I would disconnect those connectors andtake them to the building supply store and get new fittings and a new supply hose. The new hose does not need to be copper,. you do not need to cut the existing fittings off the wall or the fridge, the new fittings, or new hose can connect directly to the old fittings. my tool of choice is a pair of crescent wrenches
May 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Have broken ice maker waterline. Water everywhere. Cant find a waterline that will work can you help me?
For starters turn off the water at the faucet that controls that line. It is most likely behind the fridge, or in the basement where that 1/4 inch line comes up to feed the fridge. The waterline is 1/4" and is available at any hardware store, home depot, lowes.
Aug 15, 2009 | Refrigerators
Whirlpool ultraease warm on left side, dispenses warm water
not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
Nov 20, 2008 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
LG LRSC26980 Refrigerator Logo
742 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
