Question about Dryers
I recently had a fan installed in a small bathroom (5x8). The mirror and windows still fog up even when I take a brief shower. A few minutes after the water stops running, the moisture does seem to clear up. Is this a problem that moisture is building up while the shower is running? It is either a 50CFM or 80CFM fan. Thanks.
  • A Miller May 11, 2010
    General comment ... You are probably overwhelming this little fan. A little fan is better than no fan however, I dont know that there is a fan big enough to solve this. The trouble is with the temperature difference and the relative humidity. If the room were hot enough, there would be no fog.
  • 50 Answers
On the assumption that your bathroom is 8 ft high, then the volume of air in the bathroom is 5x8x8 or 320 cu ft. Even if your fan is 80 cfm it would take 4 minutes to completely exchange the air. Leaving the door slightly ajar would assist.
To overcome a similar problem, I installed a second fan with a push button 10 minute timer so the fan runs for a few minutes after I leave the bathroom.
Posted on Sep 24, 2009
  • 95 Answers
Take the room sizes to an electrical whole salers and they will calculate the air flow and size of fan required
Posted on Nov 18, 2009
Smoke alarm went off None of the other smoke alarms went off just the 1 I have a CO alarm and that didnt go off either Smoke alarm has a green light on and a red light that flashes every 30 seconds
Most smoke alarms depend on a mirror and laser. If the one is question is near a bathroom, it probably went off after someone took a shower? The steam from the bathroom will fog the mirror and set it off. Same problem if it is near a source of cold air on a cold day with heat on in the house. If the problem is cold air from the attic, go to the attic and move the insulation. Seal the hole for the wires with canned foam like Great Stuff, and put the insulation back over it.
Jan 04, 2016 | Home
How do you keep a mirror in the shower clear?
Make a mirror fog-free. Rub a thin layer of car wax onto a bathroom mirror and buff it clean. Next time you step out of the shower, you'll be able to see your reflection without having to wipe away condensation first.
Oct 04, 2015 | Cars & Trucks
I suffer from a build up of steam in my bathroom, I have an extractor fan and was wondering if fitting a humidistat may help.
If the build up only occurs when the shower is operating, it wouldn't be worth the money, time and effort. Check the fan, by removing the cover. It may need a good cleaning. As they do collect dust, lint and hair when they are in operation. Also, running it properly, may solve the problem. The fan should be ON prior to starting the shower and remain on at least 15 minutes (some manufacturer's recommend 30 minutes) after the shower is completed. If you bathroom has a window, opening that at least 1/2", allows the fan to pull in fresh air to help eliminate the humidity. Of course, in the dead of Winter, you don't want to open the window. As the cold air will turn the humidity/steam into water droplets.
Hope this helped you. Please let me know. Thanks.
May 16, 2011 | Honeywell Heating & Cooling
When I'm in my bathroom and showering the light turns red- what does this mean- Mold?. moisture?
The simple answer is moisture. If you have a bathroom exhaust fan, be sure to run it during and after you're showering. Typically, for a bathroom exhaust fan to reduce the moisture properly, it should remain ON for at least 15 minutes after your showering is complete,
Hope this helped to answer your question.
Apr 23, 2011 | Winix PlasmaWave 5000 Air Purifier
The bathroom exhaust fan in our bungalow is leaking this past week every few days , we are not handy folks and so we are wondering what type of professional do we call in to deal with this leak and...
Sounds like the issue is simply condensation inside the exhaust pipe where it passes through the un-heated attic space. If you use the shower and the exhaust fan, lots of humid air is passing over the inside surface of a very cold duct, then running back down to your bathroom ceiling. You could get any non-specialist handyman to wrap insulation around that duct in the attic. But you can mitigate the problem by running the fan for a few minutes before you start the shower (thereby pre-heating the duct before you give it a blast of moist air) , and leaving it run for 20 minutes afterwards (thereby drying out the duct after use). Regarding the discolored ceiling, the handyman can apply some stain-covering white primer too.
Jan 14, 2011 | Fantech Fans Exhaust Fan In-Line
Does a bathroom require an exhaust fan even if it has a window
YES!!!! all a window does is change the vapor into liquid. What is needed is to get the moisture OUT OF THE building. I prefer Neutone 200 CFM unit, for get specs, they are all way too low. You are combating health issues if you allow moisture to remain....mold...
Also, the exhaust ducting needs to run downhill as it exits the building, or you risk moisture dripping from the fan...
Futher, put a 60 minute timer on the fan, and run 45 minutes (at least) for every shower....
Aug 28, 2010 | American Standard Home
A small worn area on mirrored door in my shower, can it be repaired?
Yes but it will be expensive
A glass shop can re-apply the silver coating on the back surface of mirrors
Apr 02, 2010 | Home
Yellow Spots on Bathroom ceiling/walls after showers
You will have to paint over your new paint with a primer called BIN which will dry in about an hour. Then you can put your color coat on that. Problem solved.
Dec 04, 2009 | Home
Bathroom Ventilation Fan Motor Failures
I'm guessing that water isn't splashing up on this fan's motor, so the moisture that is causing the rust must be water vapor. The exact same water vapor that the fan is supposed to be removing. I have two suggestions before replacing the entire fan. One is to make sure that the ducting that carries the moist air out of the bathroom (and preferably out of the house altogether) is free of obstructions and that the fan can actually do it's job. Second is to actually run the fan, and run it a lot longer than you probably are right now. If it is running while you are in the shower and then you turn it off after you leave the bathroom, it can't possibly be removing that moisture. I'd invest in a countdown type timer and replace the existing switch with that. Set that thing for 30 or 60 minutes when you get in the shower and let it turn it off automatically.
Jan 28, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Dryers Logo
179 people viewed this question
Top Dryers Experts
