Acer Aspire  5610-4648  PC Notebook
Problem for Acer Aspire 5610-4648 (LX.AXZ0X.097) PC Notebook
Acer 5610z need to locate cmos battery for bios password reset
By jellis0820 on Sep 24, 2009
i cannot acess my laptop due to password protection put on by accident and need help removing cmos battery. PLEASE HELP
Solution #1
posted on Sep 24, 2009
Somewhat Helpful)
parrotheadpc
Rank: Guru  Acer Computer Hardware  Expert
Rating: 89%, 631 votes
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Below is the link to your service manual that will point everything out to you. Good luck.
http://tim.id.au/laptops/acer/aspire%205610%20travelmate%204200.pdf
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5610-4648 PC
Questions and Unsolved Problems for Acer Aspire 5610-4648 PC
Do you recommend Acer Aspire 5610-4648 (LX.AXZ0X.097) PC Notebook?
Answer
Answer
I have an acer aspire 5534, and it is supposed to have the Crystal Eye webcam. It is mentioned by... (More)
Answer
i cant open it i guess my hardrive has problem...tell me what to do please...t.y
Answer
i click on my acer crystal eye webcam but it says the application has failed to start because image... (More)
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , PA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
