Question about Achiever Office Equipment & Supplies
I need a switch for my shredder. Arcolectric C1470AB
I need a switch for my shredder. Arcolectric #C1470AB Were can I get one?
  • 69 Answers
Maybe on ebay or the company website
Posted on Sep 24, 2009
Where is the switch that allows shredder to shred and can use another receptacle with the shredder?
The safety switch is underneath is a hole. You will see a pin sticking up on the basket.
May 06, 2016 | Shredder Office Equipment & Supplies
Paper shredder doesn't move due to too much adhesive paper - how to fix it
Before trying anything I suggest, make sure your shredder isn't plugged in.
You will need to remove the adhesive from the rollers. You will need to use a glue solvent on the shredder rollers,something like Goo Be Gone. Personally, I still use Ronsonol Lighter Fluid In the image below I've outlined the supplies you'll need to, hopefully, clear your jam.
25346531-f3timxio4jyou4u0bydnlgfi-2-0.jpg Without disassembling your shredder, the best way to clear your jam is to use Rosonol Lighter Fluid (3), tweezers (4), and dental picks (5).
  1. Make sure you are working in a well ventilated area. Separate the shredder from its shredded paper collection tub.
  2. Turn the shredder head upside down so that the paper output is facing up.
  3. Pour Rosonol lighter fluid on both sides of the rollers near where they come together.
  4. Use dental picks and tweezers to dislodge stuck paper pieces
  5. Turn Shredder head over and repeat steps 3 and 4
  6. Move power switch to the "Off" position
  7. Plug power cable back in
  8. Move power switch to "Rev" (reverse) position, if still stuck move power switch to the "Fwd" position, repeat twice
  9. Repeat steps 1 - 8 until the rollers move freely
Once the rollers are moving smoothly you need to oil the rollers.
Dec 30, 2014 | Shredder Office Equipment & Supplies
Infoguard sx100m
I don't own this shredder, but most are built with similarities. Usually there is a micro-switch that's used to detect a piece of paper being inserted. Should this switch get jambed, it will continue to "sense" paper being inserted and continue to run.
As I said, I don't know this shredder, but it would be reasonable to assume that someone will need to open the shredder and clean (or replace) the switch.
As a possibility, I think I would try using one of those 3M Dust Remover can's of compressed air and see it you can dislodge any paper or paper dust around the switch by blowing through the paper entry opening. (Will need to look into the opening to see where the switch is located. Usually near the center.)
Otherwise need to have a technician come out.
Aug 28, 2014 | Industrial Paper Shredders Office...
Emerson cross Cut Shredder X822 how to check Steel Interlock switch at bottom of unit?
Brian, a lot of shredders have a microswitch in the bottom of the unit that has to be activated by a tab on the basket. One possibility is that the tab has broken off, which means that you would need a new basket, or there is a possibility that the shredder head is on the basket backwards and is not connecting with the tab. Hope this helps.
May 22, 2014 | Shredder Office Equipment & Supplies
Power switch will not turn on
If it is just a matter of the power switch, that is an easy part to replace. It might also be that one of the leads to the switch has come loose (some shredders just use the slip-on connectors) and needs to be put back on. Also, if the wires are attached to the switch, have you tried touching the wires from the switch and seeing if the shredder will work then. You can use a short piece of insulated wire to act as a jumper cable to touch the two wires going to the switch. If this doesn't allow the shredder to operate (you need to have something pressing down on the safety switch), then you need a new shredder.
Jan 17, 2014 | Fellowes DM15C Shredder
I have an older royal orca 9512x shredder that I purchased at staples....recently it wouldn't work...I found out that the plastic switch that triggers the shredder fell off ...a small projection of...
screw a small screw into the piece in the back right corner of the basket that the shredder fits on. This will adjust to the height needed to make the shredder run.
Jun 17, 2011 | Royal 15MX Shredder
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
SHREDDER WILL NOT POWER UP. NO LIGHTS, NO POWER
you will need to open it and test the on/off switch, door switch, fuse all for continuity. turn the machine off and unplug it . unscrew it from the base. flip it over, unscrew the bottom. now test with a dm. if you are needing a tech i michigan please call 248-677-8112
Oct 23, 2009 | Royal 150MX Cross-Cut Shredder
No power to my shredder
Check that there is still power to your outlet by plugging in something else.
Make sure that your shredder is properly and completely seated on your waste receptacle. There is a switch in the notch that prevents the shredder's running if it doesn't make contact. With the shredder unplugged, you might need to look up into the notch to make sure that there idn't anything in there that might prevent the switch from making good contact.
Work the switch from forward to reverse and back.
This should get you going.
Regards!, --W/D--
Jul 20, 2009 | Fellowes DM8C Cross-Cut Shredder
Light is on. Reverse works, paper fed won't trigger the shredder
If you are pushing a button to make the shredder run something doesn't sound right.
See if this makes sense, Generally shredders will use a photo switch or a micro switch to detect the paper. If you are pushing a button it sounds like you have a micro switch. The switch should have an arm that would extend into the throat of the shredder and the paper would hit the arm activating the switch. From your description it sounds like the arm is missing or bent out of the way of the paper. If you can see the paper actually hitting an arm that would activate the button then the arm may just need to be bent a little so it moves farther to operate the button
Hope this makes sense and helps
Mar 14, 2009 | Office Equipment & Supplies
73 people viewed this question
Top Achiever Office Equipment & Supplies Experts
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
