Question about Fedders A6P09S2A Air Conditioner
PANASONIC CU160C53XP FAULT CODE F33 COMES UP ON KEY PAD WHAT DOES IT MEAN HOW CAN I OBTAIN FAULT CODES FOR THIS UNIT THANK YOU FOR ANY HELP
BEST WAY IS TO GET AHOLD OF THE MFR'S TECH SUPPORT LINE EASILY OBTAINED FROM YOUR SERVICE MANUAL OR INFO (NOT SURE OF STATE)
Posted on Jan 30, 2008
Panasonic fault codes
h14 is indoor intake air temperature sensor
try turning power off for over 1 min, and restarting
Jul 12, 2014 | Panasonic Heating & Cooling
F1 code after installing oven, cut power to unit for 30 min. then F7 code displayed. What do they mean? This is a model SC302ZS Thank you for your help.
F1 means internal logic failure; control needs to be replaced
F7 means function key shorted (touch pad).
Hope that helps.
May 20, 2011 | Thermador SC302T Electric Double Oven
What does F33 mean- its the code on my front loader washing machine
"F33" means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch. The flow meter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
Thank you !!
Jul 15, 2010 | Kenmore HE2 Plus Front Load Washer
My washer said f33 on in. What does this mean?
F-33 Error Code.
When the connection between pump
and the Central Control Unit (CCU) is
lost.
1. Unplug washer or disconnect power.
2. Check wire harness connections to
the pump and Central Control Unit
(CCU).
3. Plug in washer or reconnect power.
Dec 04, 2009 | Kenmore HE2 Plus Front Load Washer
Error code f33 on an he4t
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 11, 2009 | Kenmore Washing Machines
Forgot security code of Nokia 2100
If your problem is only to open key pad with out any issue.just remove the battery and again place it and now your mobile is active with out key pad locked now u save all ur numbers and important messages and then restore the settings to facotory settings. now ur default passcode will be 12345.
All the best
SuryaVenu
suryavenu@gmail.com
May 27, 2009 | Nokia 2100 Cellular Phone
Error message and alarm
These are the fault codes for your unit
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Hope this helps, Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Maytag MGR5870 Gas Kitchen Range
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: elylimo@gmail.com I have the same model number. 9114658811 and plugged in the stove for the...
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Kenmore 46123 Stainless Steel Electric...
Panasonic reverse cycle aircon.
Found the codes are printed inside the air conditioner.
F33 ---01. = locked up compressor.
Cannot fix this problem myself, will have to engage a serviceman.
Stan.
Jul 15, 2008 | Heating & Cooling
Fedders A6P09S2A Air Conditioner Logo
622 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
