Question about Creative Labs ZEN V Plus MP3 Player
My mp3 player says now playing but won't do anything. It has the lightning bolt across where it is supposed to show that it is charging.
    President:
  • 803 Answers
Try manually resetting the player. It probably is just alittle confused and this should fix your problem
Posted on Sep 24, 2009
After charging,the screen says philips,and wont do anything else
Hi Cheryl, The link below is a youtube page full of videos showing how to turn on your mp3 player and unfreeze it.........CHEERS..
how to fix mp3 player that won turn on YouTube
Apr 24, 2016 | Philips GOGEAR Audio Players & Recorders
How do i charge my mp3 player.It plugs into a usb port to download music but I cannot find a place for batteries.
Without knowing the model number of your player it is difficult to answer your question.
Players which can be recharged typically do so through the USB port. When plugged into a charger or computer, this type device should have a LED illuminate or lightning bolt appear on the display to show it is charging.
If nothing happens when it is plugged in to a charger or computer, then it may only operate on AA or AAA batteries and should display something when it's time to change them.
Oct 13, 2014 | Nextar Audio Players & Recorders
My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
Three possibilities;
1) You have a dead battery because the battery is no good.
2) You have a dead battery because your Sansa is no longer charging the battery.
3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Amazon.com. Here's a link:
http://www.amazon.com/HQRP-Replacement-Battery-Universal-Protector/dp/B001NZ981S
If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
Hope that helps! Please post a message to let others know what happened to your Sansa player.
Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
I have an iPod 4GB. I haven't used it for a while and now when I plug it into the computer to charge, I do not get the lightning bolt to show it is charging. All I get is the apple on the screen. ...
If the apple is on the screen then it probably is not broken. It may be a little damaged but it should still play music. Sometimes the pixles on the screen become unresponsive after awhile.
May 14, 2011 | Audio Players & Recorders
My zen wont charge
It won't charge from an USB hub. It must be plugged intoan USB port on the computer itself.
Oct 29, 2008 | Creative Labs ZEN V Plus MP3 Player
Charging, downloading
your lap top probbubly has a power saving seting for your usb ports ..try changing that or pluging into a regular desktop computer... it will turn on when it is charging and show a lightning bolt going through the pickture of the battery...
if that dosent work make use of the warenty (if it is still useable)
May 18, 2008 | Creative Labs ZEN V Plus MP3 Player
Trouble charging my zune
I would say make sure you are in the right USB port. My laptop has 3 and only one of them will charge my mp3 player
Apr 12, 2008 | Microsoft Zune JS8-00001 Digital Media...
Frozen
Press the reset button once with a pin/paper clip by the usb connection. If that does not work press the reset button again but this time hold the play button until a different screen comes up....then I selected clean up. crzmiggie@hotmail.com
Jun 16, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
56 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
