Question about Coleman 2 Burner Dual Fuel 424-700G Grill
Unable to install tank due to generator is not at
New Model 424 I'm unable to install tank due to generator is not at 90 degrees to valve on tank thus right tank clip will not reach insertion slot should I try to bend generator tube to 90 degrees or return?
  • 557 Answers
If this is a new unit I would return it and ask for help. If you try bending it and break it its then you have a real problem.
Posted on Sep 24, 2009
Handle will not turn water off
single cartridge? pull old one, flush some water through empty valve then install new cartridge. once installed, make sure the horseshoe clip is properly inserted to keep the stem in. once the clip is in right, there is a chrome tube with a ridge that slides over the barrel and the clip. the ridge acts as the stop for the handle. also make sure there are stops inside back of handle to hit the ridge on the chrome tube. the plastic inside the handle may break off allowing the handle to spin. the stem unit/cart may also be installed 180 degrees out of place. pull the lock clip and use the remover tool that came with new cart to rotate it 180 degrees with water supply turned off.
Jun 17, 2013 | Moen & One Handle Tub & Shower Faucet
I need to replace the fuel pump on my 2001 Saturn L200 with a 2.2 L Engine. What is the best procedure?
Fuel Pump REMOVAL & INSTALLATION 1.9L Engine To prevent excessive fuel spillage, whenever the tank is removed from the vehicle it should be no more than 1?2 full. Removal of the fuel pump module assembly requires the removal of the fuel tank.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Properly relieve the fuel system pressure.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Fuel feed and return lines from the filter/pressure regulator
    • Fuel pump vapor line from the fuel tank vent pipe
    • Fuel pump module retaining ring with service tool SA9156E. A 1?2 inch breaker bar will loosen the lockring
    NOTE: To prevent bending of the sending unit float arm, lift the pump module up slightly to disengage the orientation tabs in the tank. Rotate the module 90 degrees clockwise until the fuel lines are facing the 1 o'clock position.
    • Fuel pump module from the fuel tank until the bottom of the pump module is close to the fuel tank opening
    • Tilt the pump module approximately 45 degrees to the right hand side of the tank and lift the pump from the fuel tank
    • Fuel pump to tank seal and discard it
    To install:
  4. Install or connect the following:
    • Fuel pump module into the fuel tank by orientating the float to face the right side and tilting the module approximately 45 degrees
    • Fuel pump into the tank and rotate the assembly 90 degrees counterclockwise to align the module tabs with the slots in the tank
    NOTE: The fuel pump retaining ring cannot be properly installed if the flange locator tabs are not aligned with the slots in the fuel tank.
    • Retaining lockring with tool SA9156E
    • Vapor line to the fuel tank vent pipe
    • Fuel feed and return lines to the filter/pressure regulator
    • Fuel feed, return and EVAP canister purge line in the fuel tank retaining clip
    • Fuel tank
  5. Start the vehicle and check for leaks, repair if necessary.
2.2L and 3.0L Engines
    • Fuel tank
    • Fuel lines from the fuel pump module cover
    • Fuel pump module retaining ring with a Sending Unit Wrench, J43827
    • Pull the retaining clip toward the float arm and lift up
    • Fuel pump straight up from the fuel tank
    • Fuel pump tank seal and discard the seal
    • Fuel feed line from the bottom of the fuel pump cover with Clamp Pliers J43914
    • Fuel pump electrical connector Fig. 1: Remove the fuel pump cover lockring-2.2L and 3.0L engines 9306zg57.gif
    To install:
    • Fuel pump feed line to the cover
    • Fuel pump to the new seal
    • Fuel pump cover lockring with tool J-43827
    • Fuel lines and wiring harness
    • Fuel tank
Jan 29, 2011 | 2001 Saturn L-Series
My Moens One handle tub shower shot out at me and i could not stop the water for nothing what would make it shot out
If it is an older valve there is a small copper retaining clip that holds the cartridge in place. If this clip broke it could blow cartridge out or come out when you pulled it to turn it on.
If that is the trouble you can see the slot in the top of the valve body where the retaining clip goes.You will need to get a new clip and put the cartridge back in and insert clip to hold it. If you find that you have the hot and cold sides reversed simply turn the stem of the cartridge 180 degrees and you should be in business. Thank you
Jan 02, 2011 | Moen & One Handle Tub & Shower Faucet
Need to replace evaporator emmission valve by gas tank, can tell how to remove, what holds it in place?
Hello: If this the vent valve there will be a metal bracket that is holding the valve in place. on the side that the valve is close to you will see a metal clip in the middle, release it with a straight slot screw driver. Before installing the new valve push the clip back so it will hold the new valve. Hope this helps you.
Nov 02, 2010 | 2002 GMC Envoy
Will not get above 350 degrees. this happened after moving the grill. have changed tanks. could it be the regulator? who can service it in the 30339 zip code?
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 30, 2010 | Grilling
My q grill is not heating properly. I have a full tank of propane and the grill is clean but the burner is not getting enough gas to heat past 200 degrees
Mar 30, 2010 | Weber Q Grill
When I changed my gas tank, the gas flow would not return
Mar 29, 2010 | Grilling
Weber grill three burner. New tank of propane but
Mar 29, 2010 | Weber Genesis Silver B Grill
Heats only to 300 degrees.
Mar 29, 2010 | Weber Genesis Silver A Grill
Coleman 2 Burner Dual Fuel 424-700G Grill Logo
138 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
