The outside fan on the unit no coming on
After the unit runs and turns itself off the outside fan will not restart when the unit does
  • 358 Answers
Replace the fan motor capacitor (about $20) , that should solve the problem but if not , the fan motor has to be changed, make sure the new one has the same H.P.,same volts and same r.p.m.
Posted on Sep 24, 2009
AC unit wont work, inside coils are hissing but outside unit not turning on.
If thisnis a central air conditioner and there is hissing at the indoor coil then the compressor is running, it is possible that both fans are not running. The indoor motor may not run if the control board is bad, capacitor is bad or the motor itself is bad. The outdoor fan may have a bad capacitor or the motor itself is bad
Jul 23, 2012 | Heating & Cooling
My unit to my house wont turn on outside. This happened last night at about 8:30. I have checked the circuit breaker/fuses and the little red switch on the unit itself-- I pushed that. I turned the...
Turn power off to indoor unit. Remove red, yellow and green wires from tstat and wire nut the three together. Turn power to indoor unit back on. This should bring on indoor fan and outdoor conpressor and fan. Let me know
Jun 22, 2017 | Fedders Q Chassis A6Q10F2A Air Conditioner
My Goodman gsh103301ab. The fan in the outside unit will not come on. The heat is still coming out the the vents but, just don't think that sounds right. Is this suppose to happen?
If it's in cool mode, the outside fan definitely should run to remove the heat. If it's heat mode the outside fan will start only when pressure build up. If it's problem with condenser fan definitely the breaker or fuse will be blown when the amphs increased.
Dec 08, 2010 | Goodman CKL36AR36 Air Conditioner
My compressor doesn't turn on. My thermostat
you probably need a start/run capacitor. on the out side condenser unit. about $100.00 to have it fixed,
Jul 03, 2010 | Heating & Cooling
I have a Goodman ckl49-1 airconditiong unit that
Check for burned wires at the outside unit and if the fan doesn't work could be the capacitor or the fan motor itself , i would try replacing the capacitor first is no more than $25.
Aug 27, 2009 | Heating & Cooling
The outside unit of a whole house air conditioner
replace start run capacitor of motor fan
Aug 17, 2009 | Heating & Cooling
The outside unit is not working on my Heil Air conditioner
The attic fan is not a part of your a/c system, and you should not run it while you are running the a/c. If you are currently using the attic fan, it is possible that someone wired it so that the a/c won't turn on while the attic fan is on. Otherwise if the thermostat is set below room temp, and says it is calling for cool, then the problem is most likely coming from an issue at the outside unit itself. Make sure to check your fuses, at the fuse panel and outside breaker. Hope this helps
FYI.. the only part of the system that might use batteries is the thermostat.
Jul 28, 2009 | Heating & Cooling
1004 tempstar a/c air quits blowing into house
Possible fan motor problem. Bad capacitor or bad fan motro. Either way you ned to call a service tech. Russ
Jul 18, 2009 | Heating & Cooling
Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
May 28, 2009 | Heating & Cooling
I have a colman ac unit and the outside unit will not come on. i hear it clicking but nothing happens
On my computer screen these two problems are not the same.
To "garys2003" Clicking you hear is the contactor closing in calling for cooling. If no power is being supplied to the outside unit high voltage the unit will not run. Check your circuit breaker or fuses in the outside power box. If the outside power box is of the non-fused disconnect, check that the disconnect is inserted properly.
To Trenina: Is your unit a self contained unit outside ducted to the inside as with a Mobile Home. If so your evaporator cooling coil may be frozen over stopping air movement, turn the cooling off and set your fan to on until it defrosts, then return to normal operation and leave the fan on during cooling.
If nothing comes on inside as with a central A/C system you may have a problem with the blower motor itself.
May 12, 2008 | Heating & Cooling
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
