Question about Miele Touchtronic W1113 Washing Machine
Both the intake and drain lights are flashing
The washer sounds like it is going to drain, but the intake and drain lights are flashing. Nothing else happens, washer will not work. Any suggestions would be great.
  • 9 Answers
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Posted on Apr 20, 2008
I had the same problem. Thanks to comments on this site we were able, with the bottom door open and the lint trap fully unscrewed, to tilt forward and empty the last 2 oz of water from the sump. Worked great after that.
Posted on Oct 03, 2011
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
Nov 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Mar 22, 2010 | Kenmore 43142 Front Load Washer
Machine will not work and flashes 12 minutes
remove bottom cover look for tech sheet usually on right side of cabinet at bottom fh is usually a water fill issue drain may be siphoning water may be slow filling or bad flow meter flow meter may be harder to diagnois but try tapping lightly with screwdriver (it's the round object left side with 2 small hoses attached ) slim chance may be pressure switch left side rear corner
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer not working
Okay...try unplugging the washer for AT LEAST 30 minutes. This will often cure momentary glitches with the washer computer. After the washer has been reset, attempt the start a load and let me know if it functions normally. If it doesn't, let me know what the front panel display reads.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Miele Touchtronic W1113 Washing Machine Logo
925 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
