Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
I have a monogram ZIS420 the freezer works fine
I have a monogram ZIS420 the freezer works fine but the refigerator is not cold. The area above the refrigerator is very warm to the touch while he panel above he freezer is cold. I have waited 6 hours with the door firmly shut and the temperature has risen to 56 degees.
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Sep 24, 2009
GE monogram zis420d refrigerator is not very cold, but the freezer is fine
Usually the air transfers from the freezer to the fridge in the center of the back of the fridge and freezer areas. they are easy to identify, make sure the vents in both the freezer and fridge are not air flow blocked preventing cooler air from transferring to the fridge.
Sep 18, 2014 | Refrigerators
Freezer works but refigerator won't get cold
IF YOU HAVE ALOT OF FROST ON THE BACK PANEL OF THE FREEZER IT IS A DEFROST T-STAT THAT CAN BE BAD IF THERE IS NO FROST FELL UP IN THE LEFT UPPER CORN OF THE FRIG SIDE SEE IF YOU CAN FILL THE AIR COMING OUT OF IT
Nov 01, 2012 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
WONDERING WHY MY GE GSS22SGRB SS REFIGERATOR ISN'T GETTING COLD, ALTHOUGH THE FREEZER SEEMS TO BE WORKING PROPERLY.
you should have a dial or knob that says freezer colder or warmer if so turn it for freezer to get warmer thast should allow cold aiur from freezer to enter into ref. that should make ref. colder. if to cold then dail it back a little at a time till ref. is what u like. ok try that. later gator.
Feb 15, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
Freezer -24 F and refigerator will not go below 58F
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
I have a Kitchenaid KSCS20QFAL01 refrigerator. The freezer side gets cold but the refigerator side does not. The difuser has been replaced but did not solve the problem. It was working fine until the...
clean all the dust off the coils on the back of the fridge and all the dust out from underneath the fridge. This was the cause of my fridge not cooling and it worked and cost me to have somebody come out to blow all the dust out from underneath. Give it a try
Jul 24, 2010 | KitchenAid Refrigerators
Refigerator will not saty cold but freezer works
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Jun 28, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Refrigerator warm, freezer too cold
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | GE Monogram ZICS360NRRH C... Bottom...
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
605 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
