Question about Porter Cable 7812 Wet/Dry Vacuum
Craftsman compressor Hi we have a craftsman 30 gal vertical air compressor with 2 guages. we want to use to fill up the flat tire. Only the left gauge reads with pressure but the right one does not. How do we fill up the tire and get the right gauge to register? Can you help me
  • 313 Answers
1 gauge will read the tank prssure. 1 gauge is for the regulated pressure to your quick disconnect.
Posted on May 30, 2008
  • 1,673 Answers
They put this under vacuums, relist it in the right place.
Posted on Feb 22, 2008
Where do i place the foam sleeve for 5 gal craftsman wet vac
The foam just is put over the round center beneath the top of vacumn with top off the bucket. Just slide up to top of round assembly and you good to go. If you have the paper bag filter on remove it first.
Aug 31, 2014 | Craftsman 17765 Canister Wet/Dry Vacuum
B&s engine on mower turned upside down, won't start now.
Take the spark plug out, turn ignition key or pull rope until the engine turns over several times. Let it sit for about 5 or 10 minutes and repeat. Replace the spark plug with a new one. Make sure that your crankcase is not over filled or under filled with oil, and make sure that there is plenty of gasoline in the tank. Make sure that gasoline cap and oil cap are on "securely". Now try to re-start. (The engine may smoke for a while, but it should clear up in a few minutes).
Nov 27, 2013 | Craftsman 16-gal 6.5-peak hp Wet/Dry Vac...
Hi -- For my White Wing Steam Cleaner: After I plug in the unit, and wait over 10 minutes, the Pressure gauge shows that the pressure at 2 (maybe 2.5, I can't recall as I'm typing today) -- not...
Re: Low pressure on WhiteWing steam cleaner
1. Make sure the safety switch for the hose handle on the right side of the hose handle is turned to the closed position. To do that, push it away form the hose.
2. Make sure the steam release button (next to the on/off button on the control panel on the steamer) is in the Off position.
3. Make sure the safety cap is tightened.
4. Make sure you have enough water in the tank (at least half a bottle of water)
I hope this helps.
Jul 31, 2011 | Vapor WhiteWing Steamer Canister Vacuum
How do l change the filters please
Hi there SmartAlec from assuming your dyson is the one pictured it will have 2 filters.
1st. If you look at the machine from the front there will be a filter cover on the left hand side. It is in a vertical position and is released by a smallish lever just above the cover.
2nd. The post motor filter is found under the clear bin. Simply take the entire cyclone canister off and you will see it sits on a filter cover. With a small flat blade screwdriver gently pry the cover off and access the filter. carry all the filters for Dyson Vacuum cleaners in stock.
Aug 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Low tire light stays lit.
If there is a red reset button in the fuse box, press & hold till your air pressure light flashes this with the key on, engine off
Jan 09, 2009 | NexxTech 611-8212 Handheld Wet/Dry Vacuum
Was vacumning watershut off switch would not start again water level was well below the ball
left the top assembly which includes the motor out side in the sun for 2 days and this am it started. cwcb
Aug 21, 2008 | Vacuums
Craftsman 20 Gal Wet/Dry Vacuum model number 17762
you did take the filter off before useing it wet didnt you make sure the check ball in the filter housing is down in the cage and that the top is locked down properly
Feb 13, 2008 | Craftsman 17762 Wet/Dry Vacuum
Porter Cable 7812 Wet/Dry Vacuum Logo
56 people viewed this question
Top Porter Cable Vacuums Experts
Are you a Porter Cable Vacuum Expert? Answer questions, earn points and help others
