Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The TV tries to turn on three times, at each point making a loud high pitch beeping noise, and then shuts off. It is a HD projection TV, bought about 4 years ago.
  • RCA Master
  • 8,457 Answers
Ur high voltage is dead,the FBT.The flyback transformer is dead.The big black block of plastic with a wire with cap hook up to ur CRT(tv tube).Might
also ur DM power board,have burns capacitors,check for puff ups capacitors must also be replace as rebuild board.U know how to solder right?Tries thes websites for parts.Tv Repair World.com Shopjimmy.com Partstore.com or Ebay.com.
Posted on Sep 24, 2009
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
Samsung dlp tv HLP5663W makes loud noise
Yes, the set uses a color wheel and the lamp faces it.
The wheel turns at over 8,000 rpm and is well known for this problem=bearings in the tiny motor go bad.
The high pitched or fan like noise (classic description) is this part.
Sooner or later the wheel (plastic colored segments) will shatter and set will shut down lamp and not operate---set monitors the speed of the wheel so if it slows down or stops it knows.
The part is readily available on the internet (Google the model number with "color wheel").
This can be a do it yourself repair and You Tube has video instructions for replacing the wheel by model number.
There are two common pitfalls to avoid which the instructions that come with the replacement part usually do not mention---if you decide to do this repair let me know and I will explain.
SD TECH
May 26, 2012 | Televison & Video
Our tv made a loud high pitched noise for a few weeks and then the color went green to then shutting off. Now, when we try to turn on the tv, the light blinks and then it just shuts off and keeps repeating...
Hi, Symptom shows high pitch sound is of color wheel that is not spinning any more so TV stay in protection mode and does not power up. TV requires color wheel replacement.
Jun 15, 2009 | Samsung HLN5065W 50" Rear Projection...
Loud high pitch noise
The Transistor H.O.T maybe shorted , Get a technician to have a check.
Jun 07, 2009 | Televison & Video
Tv turns on and off three times
sounds like the flyback which is a 259296 flyback. You can get the replacement flyback at the following link with free instructions
http://servicemanuals.vstore.ca/
May 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
TV making high pitch sound
Hi, There are usually 1 or 2 fans inside the TV's. Could be worn bearings, or fan blade interference. Sorry, without my electric ear working, I can only guess.
Apr 21, 2008 | RCA HD52W56 52" Rear Projection HDTV
Rca tv
I had this happen to mine and I had to have the high voltage transformer replaced. I took it all apart my self to save money and it only cost me about $285
Jan 14, 2008 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
143 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
