Question about Kenmore Elite 45986 Front Load Washer
Can not keep the HE 3 washer from jumping around on the spin cycle. Floor is level and machine is level with legs locked in place. Have lowered leveling legs to the base and locked them tight with the nuts. The machine is level and does not jiggle when I shake it. Can not pass a sheet of paper under the leveling legs.
    Scholar:
  • 138 Answers
These machines can have this problem when placed on a pedestal and/or the floor may be level but not solid. a "bouncy" floor will amplify any movements. remember, these machines are much heavier and spin much faster than top-loaders. just because it doesn't jiggle doesn't mean the floor is level. you may have to brace to floor or foundation somehow
Posted on Sep 24, 2009
My washer is off balance during the spin cycle it jumps, and moves around
With the washer empty, tilt it front a few inches and drop it back down. This will re-level the legs. If it still jumps around, replace the drum snubber, inside the front of the machine. It's a rubber pad that keeps the drum from moving around too much. Snubbers dry out with age.
May 07, 2011 | LG WM-2277HW Front Load Washer
Can't keep washer level
as far as leveling goes once leveling legs have been set,you can lock them in place by turning the nut on leg itself counter clockwise until its secure to top of leg,however if the unit is shaking during spin cycle and is located in upper floor laundry setting,chances are the floor is weak,and cannot withstand downward force generated during final spin...add an absorption pad under unit to assist/alleive the issue
Mar 10, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
LG front loading washer: recently moved to a new house and laundry room is on the 2nd floor. Re-installed the shipping bolts in the back of the washer that secures the drum prior to moving the washer. But...
Make sure machine is level and all four leveling legs are solidly touching floor at the same time. Make sure leveling leg locking nuts are screwed up to lock legs in place. Check floor for firmness. (try bouncing up and down in front of washer to see if the floor has excessive give.) You may need to re-inforce floor. Wash larger loads. On bulky items, use a lower spin speed. You can re-spin at a higher speed after cycle is complete if you want them spun out better. (some models have a pump and spin only setting, on others, just turn on the power and then only touch the spin speed button to select a 14 minute pump and spin only cycle, then touch the start button.) The only other thing is that the new LG washers use a balance ring now, which makes the machine perform much smoother. (I know because I gave my old LG to my son and replaced it with the newer model, which now runs much quieter, in the exact same location as the old one.)
Jan 13, 2010 | Washing Machines
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
Front Load Washer moving around because of the high rpm
if you dont have a weak floor just lock the legs,,,on the legs theres a nut on each leg..your unit came with a little wrench..that fits theses nuts,,,now you have to put unit on spin ,,when you get in highest or fastest spin ..adjust leg nuts than thighten them one at a time all the way up to the base of unit,,you might have to spin on high speed twice ..you will see when unit becomes steady...this wont work as well if you have a wooden floor or a weak floor..onthejob
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
Spins off balance
Hello kel_lyn_eve,
Because your washing machine is so heavy, when it's not level, it can vibrate strongly during the spin cycle. If your washing machine is not perfectly level--with all four legs touching the floor--it can bang and rock back and forth, and even begin to "walk" across the room. This isn't good for the machine and may damage anything near the machine.
Your washing machine has adjustable, front leveling legs with a lock nut. You adjust the leg to the proper height, then tighten the lock nut up against the body of the machine to keep the leg from rotating.
Some machines have adjustable leveling legs in the rear also, and you can adjust them in the same way. Keep the machine as close to the floor as possible--the lower it is, the less likely it is to vibrate.
Most machines, however, have "self-adjusting" rear legs. You set these legs by tilting the entire machine forward onto its front legs (with the rear legs 3 to 4 inches off the floor) and then setting the machine back down. The legs should adjust automatically. If they don't, you may need to tilt the machine forward and rap on the rear legs with the handle of a hammer to loosen them--a procedure that's easier to accomplish with a helper.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 12, 2008 | Washing Machines
Whirlpool Duet Sports unbalanced...
be sure the 4 screws that hold pedistal to bottom are tight ..next lower washer all the way down run all 4 feet up as far as possible next adj front legs until washer is firm on floor and has no motion when manually rocked ..tighten lock nuts to upper limit of legs to keep them from backing out if still have excess motion try adj 1 leg at a time while in spin ..also possible weak floor ..these machines are quite heavy and need solid flooring..also machine may rock some at low rpm but usually steady at max
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Unbalance
You problem may a simple leveling issue. Check your machine front to back and side to side to ensure it properly level. Also, most top-loaders have "self-leveling" feet on the rear legs. If you walk up to your washer and it looks like the back is sitting lower than the front, you may only have to follow a few simple steps to re-level it. If your machine is equipped with this type of leveling system all you have to do is to lift the rear legs of the floor about two-inches by rocking the machine (empty of water, of course) towards you: 1. Lift the lid. 2. Place one hand under the rim of the front casing (not the wash tub). 3. Place your foot at the center of the front base to keep it from sliding. 4. Pull towards you to lift the back feet off the floor. 5. You should hear clicking noises as the feet re-level. 6. Slowly lower machine back to the floor. This should take care of most leveling problems that cause your machine to vibrate and shake during the spin cycle. These legs periodically become unlevel due to vibration and need to checked from time to time. I hope this may help you.
Apr 09, 2007 | Magic Chef CAV4000 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
179 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
