Question about Breville Brushed Stainless Electric Teakettle (1.6-L) SK550XL Electric Kettle
Set top box, OK, but no color
Analog TV OK, but no color with set top box
  • 50 Answers
Suggest you reset the channels on the set top box by going into the menu and selecting auto scan etc.
Posted on Sep 24, 2009
Can you tell me if this older tv is digital ready?
there is no make of tv brand, model,year you purchased it?
in australia we no longer broadcast analog only in digital now.. so if your tv does not tune in to any station/channel its analog.. you can still use it if you connect a set top box or a device which has a digital tuner. set top boxes are around $30 , even a second hand one would be ok or a free one from gumtree online classified
May 12, 2016 | Televison & Video
Is it analog or digital?
If it is a standard CRT TV unit it will be analogue only. If you want it to display a picture from a digital signal you will need to buy and connect a digital set top box to the TV. The set top box then picks up the digital channels through the antenna and displays the picture on the TV set. You will need the basic connections on the back of the TV to be able to connect a set top box and many older TVs do not have them..
Dec 26, 2015 | Televison & Video
The analog tv picks up a lot more stations and correct channels than the LED TV. Is it possible to set the Insignia LED NS-19E320A13 to analog? Is there a device available?
.YES IF ITS A DIGITAL TV U WILL GO TO MENU GO TO ANTENNA CHANGE FROM DIGITAL TO ANALOG OR AUTO ENTER THEN SEARCH ANOTHER WAY GET AN ANALOG TO DIGITAL SET TOP BOX FIX YA ANTENNA TO IT CONNECT TO TV BY HDMI.OR AV CABLES GET THE SET TOP. ON GO TO SCAN OR SEARCH AND YOU WILL HAVE ANALOG CHANNELS ON YOUR LED TV
Oct 08, 2015 | Insignia Televison & Video
How to tune channels on a 14 inch RCA tv?
You need a good set top box, either Hi definition or standard Pal, to make any CRT Television work. These days, non digital TV do work well but they no longer accept analog signals, but when connected to a set top box that receives digital signals, the box converts the digitals signals to analo and sends then to the RCA inputs of your TV and not via an antenna connected to the set top box and the TV.
Sep 01, 2014 | Televison & Video
How do i connect my set top box to my digital tv
Ok, I am confused. How old is the TV? If new, hook the ariel directly into the tuner on the TV. The ATSM tuner in auto configure will identify and setup the channels with no need for a set top box. On old TV using an Analog Tuner will need a box. Antenna in goes to the antenna, antenna out goes to the F connector on the TV. Should be one coax connector on the TV. That is an F connector. Set the TV to channel 3 or 4 depending on what the switch is set on the back of the set top box.
Nov 16, 2013 | GPS
CANNOT GET DIGITAL TUNING - IT SEEMED I HAD IT AND NOW THE PICTURE ON THE SCREEN HAS GONE SMALLER AND NO OPTION FOR RESET IN THE TV SET UP BUTTON AND ONLY CAN GET BBC 1 AND 2? ANY HELP WOULD BE...
Hello katiebould,
Welcome, and thank you for using FixYa!
I woul recommend that you try a Set-Top Box. It appears that you were actually on the last leg of Analog TV and need to use a converter to pass the digital TV into Analog for your TV set.
You can try and find them at your local Best Buy/WalMart or check with you local TV Shop.
Here is a link to one that can be purchased online.
Set-Top Box
http://www.newegg.com/Product/Product.aspx?Item=N82E16882439001
Have a great day!
Sep 11, 2011 | Televison & Video
How do I connect the set top box to analogue television
What type of set top box? What outputs are available on the box and what inputs are on the TV?
For a basic OTA digital to analog converter, you put the antenna coaxial cable to the antenna in of the box. Then either connect the coax out to the TV's antenna in (set the tv and the box to Channel 3 or 4) or connect the composite out to the composite in of the TV (set the TV to the AV source).
For a set top box that has a composite out and a TV that only has a coaxial input, you need to add a RF modulator. Something like this: http://www.radioshack.com/product/index.jsp?productId=2103095 . If you have a composite input on the TV, use the composite cable directly; the modulator will decrease the signal strength.
There are other converters for component out to composite video. See http://www.svideo.com/ypbpr2svideo.html . Going from a digital source (HDMI) to analog can be done but the resulting signal is poor compared to the original. Also DHCP content will not be transferred. See http://www.gefen.com/gefentv/gtvproduct.jsp?prod_id=5280 for an example.
I hope this helps. Please add a comment with the specifics of your set top box and tv for the best choice for your situation.
Jun 29, 2011 | Televison & Video
I have lost the manual and would like to hook up the VCR to my TV in order to record programs. Can you help? JVC Video Cassette Recorder HR-D18OU Thank you.
Is the incoming signal OTA or cable? (If cable, is it analog (CATV) or digital (QAM)?)
Most TV's do not have a video out but you should check your TV. Assuming the usual TV with no video out, then you will need a set top box to record any program other than analog signals (CATV or a low power OTA option). The VCR only has an NTSC (analog) tuner.
For an OTA signal, take the coax from the antenna to a digital-to-analog converter coax in, then coax out of the converter to the coax in (tuner) of the VCR. Then set the VCR to channel 3 or 4. Set the switch on the converter. (Some VCRs will record Line In or Input, so you could use the composite out of the converter to the VCR.) Then coax out from the VCR to the coax in on the TV and set the TV to Channel 3 or 4 as well. Set the switch on the VCR. (Alternatively use the composite (A/V) out on the VCR to the composite In on the TV and set the input to AV1 (or whatever the TV calls the input). Digital cable will be set up like the OTA, except for using a cable set top box instead. You may want a splitter to allow for watching one program while recording another. In that case, put the splitter before the set top box if the TV has the digital tuner. Otherwise put it after the set top box. In both cases, you will need to use the AV (composite out) on the VCR to the TV.
For analog cable, take the coax cable and connect it to the VCR's coax in. Then connect the coax out or AV out to TV.
Set the VCR to the desired station and press REC. For timed record, enter the menu and set the time to start and end the recording as well as the channel. If you are using a set top box, set that to the desired station and then press record. (Leave the VCR set to Line in or channel 3 (4) as needed.)
Manuals for some JVC vcrs are here: http://support.jvc.com/consumer/product.jsp?categoryId=CATG0002&productId=PRD4600001&archive=true . A manual for a similar model will help since they all connect the same way. However the HR-D18OU is not in the list.
I hope this helps.
Feb 10, 2011 | Computers & Internet
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Kitchen Appliances - Others Logo
59 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
