Question about Western Digital External USB 2.0 80 GB Hard Drive
Installing hd installing new hd into computer getting a ntldr error reading
  • 9 Answers
1-- make a partition with fdisk
2--make a format
rev. all conection and ear if device is working
excuse my bad english.
victores
Posted on Dec 17, 2007
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
Hd install
abigdog;
I assume you have windows OS? Which OS? Check your hd is bootable and actually is seen in BIOS. If you have formatted the drive yourself and not through the OS have you make it bootable? Clarify please. Describe in detail so that I can help you out.
Thanks
Dec 16, 2007 | Computers & Internet
Ntldr compressed
omg a relic, PC, with relic OS,
no idea at all what your are attempting I guess new OS?
what OS is there now.
what disk are you using
HP install media CD?
MS same
hackers site disks, pain.
old PC, 13 years old PC, that 99% are now in the dumps
why put cash or hard labor in any thing this old
go to Goodwill store, buy a $20 PC with Windows 7 COA sticker on the side, then do labor, on something with a future,
this PC you have is worth zero value.
came new with XP home,
XP is virus magnet, dump XP
Nov 18, 2017 | HP Pavilion a735w (PL308AAR) PC Desktop
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Nltdr missing
How To: Fix "NTLDR is missing"
Applies to: Microsoft Windows NT, Windows 2000, Windows XP
Symptoms
When you start your computer, you receive the error message "NTLDR is missing. Press any key to restart."
Cause
The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted.
SolutionCheck the boot drives
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows.
  • Check that there are no CDs or DVDs in the CD/DVD drives.
  • Check that no removable drives are plugged in to the USB ports.
  • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices.
If this does not resolve the problem, you will have to repair the NT boot loader.
Fix NTLDR
The easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead.
Use Spotmau PowerSuiteInsert the Spotmau PowerSuite CD and start the computer. The main menu will appear.spotmau-2.gif
  • Click 2. Windows Recovery.
  • When the Windows Recovery tool starts, click Windows NT/2000/XP/2003.
  • On the Windows NT/2000/XP/2003 Recovery dialog, click Recover NTLDR and NTDETECT.
  • On the Recover NTLDR and NTDETECT dialog, select your operating system (e.g. Windows XP) and then click Recover.
The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
  • Remove the Spotmau PowerTools CD from the drive and click Restart to reboot the computer.
Here link of the program Spotmau PowerSuite 2010 + Serial Download
Here link of the program Spotmau PowerSuite 2010 v5.1.1.4846 Download
Please Rate Me
Nov 17, 2010 | HP Pavilion dv6000z Notebook
I cant install windows xp because of... i dont know!
Here is what you should do, go to a computer store and buy a 40G HD. Try installing on that. It could be the size, but most likly not. Im going to guess and say take a look at the bottom of your reinstall disk. If it has any scratches, there is your problem. NTLDR is your boot sector on you HD.
Mar 04, 2009 | Intel Motherboard
Ntldr error on ibm intellistation z pro w/ xp pro
During the XP install, you will be given the chance to set up partitions on the drive. Blow them all out. Completely. Then recreate the partition and let XP install. I expect this will solve the nt loader issue. If, however, it does not, then use the recovery approach below to get the required loader files onto your boot partition.
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "d." This letter may be different on your computer.
    copy d:\i386\ntldr c:\
    copy d:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Mar 04, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
NTLDR is missing
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
Hi, i have windows xp home sp3 and turned my laptop on to get the ntldr is missing error, i have tried absolutley everything like using the windows install cd and the recovery cmd and have tried commands...
This file may be corrupted or deleted,u need to reinstall the OS ,it is the better way to stop viewing this error messages.it is rare case to handle this error without reinstalling the OS.
Aug 16, 2008 | Computers & Internet
What is NTLDR
NTLDR is short for New Technology Loader, an essential initializing program for Windows.NT4/2k/XP.
A missing NTLDR indicates several fault possibilities, most common are:
1. partially defective memory;
2. corrupt files or Windows installation in the boot hard disk; and/or
3. IDE cable, motherboard, the hard disk itself and others.
If it is a memory problem, try removing the memory sticks and clean the gold pins with a pencil eraser, re-install and make sure seated correctly. Reboot and try again.
If it is a corrupt file, insert an OEM Windows XP Installer (bootable) CD into the PC and when prompted, press any key to boot from CD. Once in the setup menu, press the "R" key to repair Windows. Log into by pressing "1" key and then enter.
You would need your administrator password, then hit enter. You need to copy the missing file(s) from the CD to your HD. Type :
copy D:\i386\ntldr C:\
copy D:\i386\ntdetect.com D:\
Soon as copied, reboot.
If thereafter, other files turn out to be missing also, perhaps you might be better off formatting your HD and re-installing your OS since chances are not only 1 or 2 files are already corrupt.
In some cases, even a re-install will not solve the problem, you then may either have to replace your memory or your hard disk.
Hope this be of some idea/help. Pls post back how things turn out or should you need additional information.
Good luck and kind regards.
Nov 03, 2007 | Toshiba Satellite A15-S157 Notebook
Western Digital External USB 2.0 80 GB Hard Drive Logo
67 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
