Question about Compaq Computers & Internet
I want to install xp by removing my pre installed vista in presario cq61-132tu. and there is no option of sata in bios so plzzzzzzzzzzz help me. i want to operate only xp means i m not want to install both o/s(xp and vista)
Hi i have compaq presario cq61_132tu laptop with windows vista. how can i install windows xp in my laptop.plz help.
Posted on Feb 04, 2012
    President:
  • 1,865 Answers
Put XP disk in CD-ROM and reboot the computer.
Click yes to install XP. It will tell you there is a system already installed on C drive. You select to install XP on C drive. It will ask if you want to format C drive, you select full format.
XP will then install
Posted on Sep 24, 2009
XP will not install "Setup
That is because it was designed for Vista not the obsolete XP. There are no hard drive drivers suitable in XP.
Re install Vista or install Win7.
Hope that helps.
Jan 22, 2011 | Computers & Internet
Hi..i have HP pavilion dv5 laptop with preloaded Windows Vista. i want to istall windows xp instead of vista. i tried installing it using xp bootable disc. but after loading the required installation files...
its very simple....
enter the bios setting...The BIOS settings menu is accessible by pressing the f2 or f10 or the f6 key on some computers.
if the BIOS provides an option to disable the native-SATA configuration in the BIOS, do the following steps to Disable the native-SATA in the BIOS
1. Use the cursor to navigate the Configuration options to locate the Native-SATA setting. 2. If there is a SATA setting, select the Disable option, and then press F10 to save the change and restart the computer.
if your system bios does not contain such option.... then find "Native SATA mode" or "SATA IDE"
then change "AHCI" to "ATA"
Jan 16, 2011 | Computers & Internet
Displays no hard drive found wen installing win xp
You have to go to BIOS setup, find HDD setup, and change the value to the other one (there are only two possibilities). That will fix your problem. The problem is caused by the fact that the lap top was designed for vista, not XP. and the lap top contains SATA HDD. when installing XP pre-installation doesn't have SATA drivers, so your OS can not see the HDD. Change it in BIOS, and you trouble is gone
Nov 14, 2009 | Toshiba Satellite A200-19501F Notebook
Compaq CQ40-108TU unable to install XP OS
Prepare a Bootable XP Disc installer.
At first go to BIOS Setup to Boot First Priority the CD/DVD Rom Drive.
After that disabled SATA or RAID Configuration. The Bootable XP Disc Installer could not go on when you don't disable the SATA or RAID Connection.
Don't worry that you are thinking it would not detected the SATA HDD by Bootable Disc but it is. Then follow the instruction.
If i am helpful to you please rate me.
Thank you.
Yboyandrei
Aug 24, 2009 | Compaq Presario Notebook
Installing XP on a vista pre-installed laptop
your harddisk is not detected in bios.reconnect your harddisk power cable and sata or ide cable again.then check in bios harddisk is detect or not.
u cna enter in bios with "del" key when u power up ther computer prerss "del" or F2 keyh to enter in bios.
Mar 25, 2009 | Acer Aspire 3680 Laptop
Compaq presario cq45 112AU unable to install winxp
U need to edit the BIOS settings because SATA drivers is not included inside older Window XP CD.
Disable the SATA option under advance options in BIOS. That should work and it will also allow you to install/reinstall Win XP.
Feb 27, 2009 | Compaq Presario Notebook
I can't downgrade Vista to Xp
You can install windows XP.
First go to BIOS and change sata mode to IDE mode
or option to disable SATA Native mode
then choose mode to IDE or disable SATA Native mode
then install windows XP
If there is no option about change sata mode in BIOS.
You should insert ahci driver to Windows XP CD using nLite
read this
http://komku.blogspot.com/2007/11/integrate-driver-into-windows.html
you can use this driver
http://cahya.prastyanto.googlepages.com/driver-sata-ahci-4920.zip
Or you can install windows by inserting driver when setup prompted
To install Windows XP with native SATA driver, perform the following steps:
Boot the notebook PC.
Insert the Windows XP installation CD into the optical CD/DVD drive.
Press the F6 key when prompted
Press the S key to specify the additional device.
Insert the SATA driver disk into drive A. (using floppy disk drive)
Follow the on-screen prompts.
Or if both way is cannot be done
i have the third way
use an unattended XP installation disk
you can download it from here:
http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
after you download
burn the CD image to the CD/DVD
then install XP using that CD/DVD
Jan 24, 2009 | Compaq Presario C700T Notebook
Installation problem of windows xp on compaq presario cq60-104tu
its most likely your hard drive is not recognized by xp because it is a SATA drive. You need to go into your BIOS and set the compatibility mode for sata. or if your bios does not have this option then you need to install the drivers when xp asks if you would like to install any third party drivers during setup check with your manufacturer for the required drivers
Jan 17, 2009 | Microsoft Windows XP Professional
Compaq presario v3000 laptop..doesnt recongize the hard drive
I beleive that you are trying to install retail versions of XP which will not be able to detect the Hard Drive in the Notebook as it is a SATA drive and Windows XP will not be having the drivers for SATA Hard Drives by default.
In this situation, I recommend you to check and disable the SATA Native support  option available in the BIOS.
Start the Notebook and start tapping the F10 key which will take you to to the BIOS Setup window.
In this, go to the System Configuration tab using the Arrow keys and select the option as Disabled next to SATA Native Support.
Press the F10 key again to save the settings done and exit BIOS.
Now, you should be able to use the Windows XP disk and install Windows XP Operating System in your Notebook without any issues.
By disabling the SATA Native Feature, the Hard Drive of the Notebook will be detected as a IDE Drive because of which we will be able to install XP without any issues.
Donot Re-Enable this feature in the BIOS again as the Operating System may not boot. Let the option next to SATA Native Support be Disabled.
Hope this helps...
Aug 12, 2008 | HP Compaq Presario v3000z Notebook
Install xp in compaq presario c700
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find harddisk. So please provivide the solution
Dec 07, 2007 | Compaq Presario C700T Notebook
Computers & Internet Logo
175 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
