Question about EuroCave Comfort Duo-Temp 260 Wine Cellar (Black Finish & Solid Door)
EUROCAVE COMFORT DUO DISPLAY
EUROCAVE COMFORT DUO TEMPERATURE DISPLAY NOT WORKING
3 Suggested Answers
SOURCE: Eurocave comfort 264: Problem, ice formation
It's likely that you need to change the filter. Have a look at this post: http://blog.wineenthusiast.com/2009/04/20/caring-for-your-eurocave-3-simple-steps-towards-long-lasting-wine-protection/
Posted on Oct 15, 2010
heatman101
  • 43501 Answers
SOURCE: The compressor will not shut
With that unit having a digital temperature control... the problem is probably the sensor....
Did a quick search on the internet for parts for them and there seems to be nothing...
Hopefully you can call the manufacturer and order a new temperature sensor for that unit...
It seems as though that will be your only source for parts...
heatman101
Posted on Nov 28, 2010
Excess condensation in my eurocave 266
Check the door seal gasket is sealing without any gaps. Check the ambient temperature isn't too high, and check the condenser is clear and aired.
Apr 20, 2014 | EuroCave Comfort 266 Connoisseurs Package...
Eurocave comfort 264: Problem, ice formation inside the unite , half the way the middle section of the unit ( Racks 8-10)
Sep 30, 2010 | EuroCave Comfort 260 Collector's Package...
Thermostats are not working; unit is freezing up inside;
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
defrost timer is not working..
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | EuroCave Comfort 260 2-Temperature Wine...
Moving a Eurocave wine cooler laying flat
the reason you should not lay a fridge/freezer on its side is that you will get air bubbles in the cooling pipes,which you may not be able to get rid of when you turn it back upright.I have moved loads of f/f, in the past and have had no problems,as long as you give the unit at least 24 hours to right itself.....and keep the door(s) closed while it is "resting"
Apr 17, 2010 | EuroCave Comfort 260 Collector's Package...
Door warped.......
Hi, These cabinets have 2 sheets of tempered glass with an airspace between and are fully reversible I would doubt they are warped. My best guess is that the cabinet is not square. If you have a level, check it across the top of the cabinet not the door. Also check it diagonally both directions. The cabinet has feet which are adjustable unless you have a low spot on the floor for which you may have to use a shim. Remember that it needs to lean slightly to the rear for the door to close on its own if partially open. Good Luck to you! Let me know how this works for you.
Feb 08, 2009 | EuroCave Comfort 260 Collector's Package...
Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Jan 22, 2009 | EuroCave Comfort 260 Collector's Package...
Eurocave Repair
can you tell if if it's running by putting your hand on the compressor,then we can go from there
Dec 17, 2008 | EuroCave Comfort 260 Collector's Package...
Top indicator light is on (orange)
Get info here:
http://www.eurocave.com/wine-cellar/wine-cellar-cooling.htm
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
EuroCave Comfort Duo-Temp 260 Wine Cellar (Black Finish & Solid Door) Logo
103 people viewed this question
Top EuroCave Refrigerators Experts
Jim London
Jim London
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
