Question about Hotpoint RGB745 Gas Kitchen Range
Hot Point Gas Range oven problem
The oven only heats to about 200 degrees, on rare occasions it might work fine for a week the won't heat over 200 again.
  • dodia May 18, 2008
    I set the temperature to 400 degrees (to bake frozen pizza). The oven pre-heats and then about 10 into cook time it begins beeping and the top oven light blinks and the oven turns its self off. If I turn it off and re-set it the same thing happens.
  • 619 Answers
Open back cover fix the nozzle by push neddle to small hole where gas passes/ clean also burner holes /check the gap between nozzle and burner ,does incline with the guide.cover it and test oven.
Posted on Jan 05, 2008
Kenmore plt083-2 won't heat above 200 degrees
Please check that model number again. The one you posted comes up as a refrigerator. Look inside the oven door or the lower drawer.
Feb 03, 2014 | Kenmore 91112 / 91114 / 91117 Electric...
Door sags open when hot.
i just had this problem with a jenn air range i was repairing, installed new hinges door closed fine, heated oven hit 200 degrees and light came on (door opened slightly) as per techline I shimmed the hinge reciever to make a bit tighter. sure enough!!! been 3 weeks she hasnt called back yet (and trust me if it didnt work she would!.. call the tech back and have him call the tech line while in home
Mar 13, 2008 | Frigidaire PLCS389DC Dual Fuel (Electric...
Oven not working properly
Do you mean 200 degrees Celcius or Farenheit? If Farenheit then the most likely culprit would be the thermocouple in the oven which can usually be replaced relatively easily by someone mechanically minded, if Celsius then you should suspect the elements although a working broiler would suggest that there is at least one element that works fine. Maytag says; "Why won't the oven heat up? First, make sure you've properly set all the oven controls. Check your user's guide for more information on your model's controls.(see below for the link to the manual if you need it) If your range offers the option of a delayed oven start, check to see if it's been selected. If so, the oven won't begin to heat until the selected time. If your oven has a lockout feature, check to see if it's been selected. If so, it will prevent you from using the oven. If your oven still won't operate, please contact an authorized Maytag service provider for more assistance." Here is the link to the manual; and here is the link to Maytag Service if you need it - hopefully not; The other possible culprit would be the electrical supply to the oven - it may be adequate for the stovetop or grill but the oven may draw more power than the circuit can handle - even if it was fine before, this can change and may be caused by corrosion, rodents, overloading etc. and may not necessarily trip the breaker switch - if you suspect this at all then get a qualified electrician to check - it shouldn't take long to check so should be cheap, although repairs if necessary may cost more Hope this helps :)
Jun 21, 2007 | Maytag MER5555Q Electric Kitchen Range
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
I own a GE JGBP33BEH5BB and the oven doesn't get hot enough. I've changed the sensor with one from a JGBP30BEA1WH that was working fine when it was removed. (replacements for both are the same part number...
The orange glow is the igniter. Normally, the igniter turns on and begins to glow. As the igniter heats, the change in it's resistance causes it to use more electrical current (amperage). When the amperage level reaches a threshold (let's say 3.2 amps, for an example) the ovens safety gas valve will open because in knows the igniter (using that much electrical current) is hot enough to light the gas. This process usually takes under two minutes. The igniter stays on until the oven reaches the set temp, then it turns off, and the gas valve shuts off very soon after. Then the cycle repeats when the oven thermostat call for heat again after cooling down a bit.
The trouble is, as these igniters get old, they have a harder time reaching that needed amperage threshold to operate properly. You can just swap the broiler igniter with the bake igniter if you wish, as they are the same part number in your model, and the broil is generally used much less, and so should have much more life left. (of course now the broiler and the self clean will not work, until you replace the broiler igniter with a new one.) In rare cases, if you have low line voltage to the range (say 108 volts) that will also cause the same problem, or if you have a poor electrical connection, but those cases are rare, and about 99 percent of the time your problem will be fixed by replacing the oven igniter. (GE part number WB2X9154 for your model)
Sorry to get so long winded. Just replace the oven igniter.
Aug 15, 2009 | GE JGBP33 Gas Kitchen Range
Oven works when it feels like it.
The ignitor is weak and not lighting the oven consistently. Need to replace the ignitor.
Nov 16, 2007 | Amana RanARG7302 Gas Kitchen Range
Heating element
Give me the complete model # from the sticker on the range so I can assist you.
Oct 17, 2007 | Hotpoint RGB745 Gas Kitchen Range
Maytag MER5775Q Electric Kitchen Range
heating elements are usually good or failed with nothing between so unlikely to be the element. problem probably lies with the thermostat. to check, bypass the thermostat and check the oven gets really hot.
May 17, 2007 | Maytag MER5775Q Electric Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
115 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
