Question about Gaggenau EB 270/271 Electric Single Oven
  • gousgouni Feb 08, 2008
    I just bought a new eb 290-91 and even though the light and fan works, the oven will not heat up in any mode. The childlock light is staying on all the time. I tried to reset it but could not. Please tell me how to get the oven out of this mode
This oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Posted on Dec 19, 2007
Gaggenau oven display clock unreadable.
The display may have to be replaced
Sep 01, 2016 | Gaggenau Ovens
No heat from my oven Gaggenau EB 868_6
hi amy,
          it seems there is a defect in ur owen..because if light and fan works, it should heat, otherwise it means there is a fault in the heating kindly cal any near by technician to sort out this problem or use our find oven repairman service to contact d near by repairman...
good luck
Jul 06, 2008 | Ovens
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
I saw sparks? or small flame on back wall behind fan inside oven
It sounds likely that the fan motor is faulty,more so if the oven is heating to some extent.
You should be able to see or hear if the fan is working or not
Hope this helps with your prob.
Nov 26, 2009 | Gaggenau EB 270/271 Electric Single Oven
Large oven doesn't heat up. Heating element gone??
Hi, In a word yes. As for who you can contact, I'd suggest only an authorized b/s/h (bosch/thermador/gaggenau) service provider. I used to be one for over 10yrs. but now work exclusively for sears...I'm not sure if I made a good choice or not yet, lol ! I digress. It is quite possibly not even the element as the gaggenau have cut-outs (they are actual thermal fuses that cannot be reset, they must be replaced) built into the bake circuit that can open often times. This of course unless you're certain the bake element is defective. Check your local directory under appliance service or a vendor who sells that line may be well equiped to direct you for quality service in someone they trust and are proficient. Hope that helps, good luck. macmarkus :)
Nov 10, 2009 | Gaggenau EB294/295 Electric Double Oven
Older Gaggenau double oven unit...heating elements stop working
Shut off te breaker for the oven for an hour then turn on again and it should come back on, just so you know Gaggenau appliances are super high end, if it needs service it will cost you
Jul 10, 2009 | Gaggenau Ovens
Temperature Problem
Replace the oven sensor 174459. Depending on when this oven was built, there was a change to the sensor to inprove the overall baking results. That is from the Gaggenau bulliten for this unit. You will have to pull the oven to replace it. It is the small tube sticking out the back, If if remember, right of the oven. It could be the left side, in the corner. Sorry but been awhile since I worked on one of these ovens.
Feb 08, 2008 | Gaggenau EB294/295 Electric Double Oven
Bottom oven not working
If its brand new, most possibly the electrician did not bridge the mains connection. It sounds like an installation fault. There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection. Oshie
Nov 27, 2006 | Gaggenau EB294/295 Electric Double Oven
The electrical panel does not light up
I'm afraid you are going to need a new display board. Not very hard to change but a pricey item. Have seen this problem a few times. Good Luck!
Oct 05, 2006 | Jenn-Air WW30430P Stainless Steel Electric...
Gaggenau EB 270/271 Electric Single Oven Logo
412 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
