Question about GE 168997 Deep Fryer
Cuts off It will do one batch of food and then shuts down. After becoming completely cool it will do one batch and shut down again. Can you help?
  • 3 Answers
Like most of the problems listed on FixYa about this Deep Fryer ours worked fine the last time we used it, but we could not get the power light to come on again. I found that there is s SAFETY Micro-switch on the heating element control unit. This switch prevents the heating element from being turned on when it is not in the Fryer Pan. The accuator lever for the switch is located under the guide slides on the heating element control unit. It is a metal lever which is moved as you mount the heating element control unit on the fryer pan. You have to look closely under one of the guide ledges on the heating control unit to see it . The problem is that over time the adjustment of the lever changes as it flexes under use. I simply readjusted the lever by forming it with a pair of long-nosed pliers. CAUTION !!!!!!! You can bend the lever so far that the switch is closed all the time defeating the Safety Switch and create a hazard in that the unit will heat as soon as you plug it in whether inserted in the Fryer Pan or lying out on any surface. This might burn someone or cause a fire. Good Luck
X-IBM
Posted on Oct 09, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 125 Answers
Maybe you should check inside to see what's burned out.
Posted on May 01, 2008
Model b198 makes one batch then stops
Check the bin arm spring you will have to disassemble the front of the ice maker to do this and check timer motor could be getting hung up. not a cleaning problem. or replace the complete head.
Oct 09, 2012 | U-Line Icemaker
JTP85 microwave shuts completely off with a blank readout.
Your magnetron is overheating, and its attached thermostat is doing its job to protect the magnetron by shutting off the power to the oven until it cools back down to a safe temperature.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven when cooking such foods)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, and it is very helpful when troubleshooting, testing, and locating components.
dee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 21, 2012 | GE JTP85 Electric Double Oven
Laptop keeps shutting down
There are a few reasons, bad power supply adapter, cooling fan is not working or there is dirt blocking the ports causing it to shut down, battery issues, "remove to verify" the DC jack in the laptop has become intermittent and must be dismantled down to the motherboard level and flipped over for solder touch up.
Apr 14, 2012 | Dell Inspiron 1525 Laptop
I have a LG Microwave that shuts itself off before its done cooking any comments? The lights and clock are still on so its still getting power
The microwave oven has a temperature sensitive thermal fuse, if the magnetron overheats "heats food" it shuts that sector down until it cools down, "up to 30 minutes before it will reset" sometimes the thermal fuse becomes defective opening up because it has become intermittent over time. This is a tricky problem to diagnose and should be checked by somebody who is familiar with these types of devices.
Jun 05, 2011 | LG Microwave Ovens
The oven switched over from bake to self clean and I need to remove food before it becomes charcoal.
Pull the plug, turn off the breaker, kill the electric to it, whatever you have to do to shut it down...
Then wait a bit and reapply the power and it will reset. You may have to let it cool completely for the door lock to relase depending on what oven you have.
Heatman101
Jan 27, 2010 | Whirlpool Ovens
Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Mar 06, 2009 | Hobart H600 Stand Mixer
Hobart M-802 mixer
Your overloading the mixer with too much product or not enough water,cut the batch down,the motor protection board is doing its job by shutting off.
Aug 06, 2008 | Hobart Food Mixers
Fridge Problems
what model and make is it
Oct 30, 2007 | Refrigerators
GE 168997 Deep Fryer Logo
218 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
