Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
The washer control panel displays for about 15 seconds as if it is going to start and then goes blank and the washer will not start.
  • 333 Answers
Please respond with make and model of the washer.
Posted on Sep 24, 2009
253.70101. Why does it keep cycling power every 5-20 seconds?
the caps are reading abourt right 7.5 uf for fan and 15 uf for compressor.
Jul 27, 2015 | Kenmore Heating & Cooling
My washer has the "control
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Press options and select for 10 secs till LOC is no longer displayed
Jul 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet ht washer control locked. How do I unlock it? Really need your help
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My dog locked the control panel on my epic maytag washer
OR
OR
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
OR press options and select for 10 secs till LOC is no longer displayed
Service Manual
Apr 04, 2011 | Maytag Washing Machines
Control locked, how do I unlock it. I can't start the washing cycle.
OR
OR
OR
Unplug washer
Apr 03, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
Dual Monitors. #1 works fine. Plug inb #2 and #1 goes to sceeen saver and #2 stays blank.
Both monitors must be plugged in when the computer is started for the second monitor to be detected, and you must configure the second monitor once the computer has started
In windows XP: control panel -> display -> settings tab -> select second display -> check "extend my windows desktop onto this monitor" -> click apply
In windows vista/7: control panel -> adjust screen resolution -> select second display and then under "multiple displays" select "Extend desktop to this display"
Mar 08, 2011 | Acer AL1917 LCD Monitor
Display powers on but display goes blank after 2 or 3 seconds.
you probaly need you power pcb repaired or the invertor replaced. sometimes the backlights burn out.
Dec 25, 2009 | Samsung SyncMaster 512N 15" Flat Panel LCD...
Instrument Panel
it will go blank and stay blank unless you get a fault..i/e low washer fluid,brake fluid,bonnet up,doors open etc,etc,try it ! when you turn on the key do you get anything at all ?
Nov 23, 2008 | 2002 Volkswagen Golf
CANON iR C2105!! no display on the LCD!
try adjusting the contrast, open front door and look under the panel there should be an adjustment screw for the contrast, if it doesnt work I suspect it is the panel itself that is bad.
Sep 12, 2008 | Office Equipment & Supplies
Oven controller not functioning
9. The time of day does not display on my electronic oven control. If I push the CLOCK pad on the control panel the time will display for a few seconds and then it goes blank again.
  • On many ranges with electronic controls the time of day display can by turned off or on by holding the CLOCK keypad down for 15 seconds.
    Push and hold the CLOCK keypad. The time will appear for a few seconds, and then disappear and finally it will reappear and beep. Release the keypad and the time should continue to display. Follow this same procedure to turn the time display off.
http://www.frigidaire.com/support/FAQ-New_Electric_Smooth_Range.asp#9
Nov 04, 2007 | Frigidaire FEF336BC Electric Kitchen Range
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
