Question about Amana DLE330RAW Electric Dryer
Install heater element ondle330raw - Amana DLE330RAW Electric Dryer
    President:
  • Amana Master
  • 1,922 Answers
Remove the rear heat duct that contains the heating element and unhook wires from element and reverse procedure to re install
Posted on Sep 26, 2009
I need part # for heating element 81V80D
Buy generic element from hardware store:
Copy following link to identify element and see installation tips.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
80 gallon, non-simultaneous electric heaters usually have 4500 watt elements
Avoid promotion of 'lifetime' or 'resistorized' or 'all copper' elements as a waste of your money, ... but might be beneficial by adding surge to the economy.
Apr 02, 2013 | Rheem 81VP6S/430126 Water Heater
Need to add electric heating element and thermastate to g6a-6e gas water heater
I don't know how you can drill into aluminum tank and install element.
That seems a good way to ruin the heater.
Why not just buy small 'under counter' 1500 watt electric water heater at local box store and install in-line before the water reaches atwood gas heater.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Otherwise I do not have a solution.
Don't blow yourself up by messing with gas appliance.
Mar 16, 2013 | Water Heaters
Can I install 4500 wt elements in a marathon MR50238? The tank specs are the same as MR 50245.
1) Product warranty will be voided if you install 4500 watt elements in year-2008 model MR50238 3800 watt marathon tank.
Older 3800 watt element models have been discontinued.
2) Copy following links for Marathon resources:
http://waterheatertimer.org/Review-Rheem-Marathon-water-heater.html
3) Product warranty is voided if element wattage exceeds label on side of unit.
4) Marathon has a problem with elements burning out frequently.
To solve this problem, they suggest installing element with lower wattage, such as the 3800 watt.
Upper 3800 SP610130
Lower 3800 SP210197
Feb 20, 2013 | Water Heaters
Installed but not heating
State point-of-use electric water heater plugs in.
Check that outlet has power.
The water heater must be full of water or elements burn out instantly.
Test the element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-install-point-of-use-water-heater.html
Match voltage to water heater:
This electric water heater, like all electric water heaters, will work on 120Volt, 208-240Volt or 3-phase unbalanced.
But wire size and breaker must match element wattage.
If you have outlet, check the wire size and breaker, and check what other devices are drawing power from same circuit, then add up total watts and compare with charts on link below.
http://waterheatertimer.org/Color-codewire.html#water-heater
Oct 20, 2012 | Water Heaters
Reliant 40 gallon tall electric water heater replaced both thermostats upper and lower elements flushed tank hot water very hot temp turned down lowest possible keeps tripping reset button what else could...
Problem has to be bad element or bad thermostat.
Test elements for short to ground through metal tank wall:
Make sure factory-installed insulation and cover are re-installed over new thermostats so they do not misread tank temperature.
If problem does not show with elements, then replace thermostats again.
Oct 06, 2012 | Reliance & 40 Gal Electric Mobile Home...
How to replace water heater element will water cme out when you remove element does tank have to be drained
Safest method:
Shut off electricity to heater.
Shut the water valve.
Drain heater to below the level of the element, open hot water valve in house to vent heater to speed draining.
If the element is on top, you don't have to empty the heater.
Remove old element, install new element.
Leave hot water valve open somewhere in the house.
Turn water on.
Once air is removed at hot water valve, turn electric on.
Shut water valve.
Gary
Aug 13, 2011 | Reliance /State Ind. 9002450 Element For...
We installed a brand new Reliance Electric Hot Water Heater, but no hot water, only lukewarm! Replaced top heating element and still no hot water!! Any suggestions as to what we need to do now?
If you have some hot water from dual-element water heater, then that tells us:
Water heater is 240Volt.
Upper element is working. If upper element is not working, then heater has NO hot water.
Reset button is not tripped.
Electricity and breaker to water heater are delivering 240Volts to heater.
Remaining suspects are:
1) Bad upper or lower thermostat: Solution: replace both thermostats for 28$.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) Bad lower element: Solution test and replace element:
3) Loose wire or loose connection: Solution: open both covers and inspect for burning. Tighten all screws very tight.
4) Bad wire: Solution: Buy cheap multimeter from Home Center and do a 30 minute troubleshoot of entire water heater before replacing any parts:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
When testing for voltage, rotate multimeter dial to 240-250-277VAC
When testing elements or continuity, rotate multimeter dial to Ohms.
Jan 10, 2011 | RELIANCE ELECTRIC WATER HEATER
We just bought a new water heater and it's not heating up water.
The heating element was bad. It's hard to believe that a brand new water heater would have a burn element, but that's the problem. I replace the heating element and its started working properly.
Dec 01, 2009 | Whirlpool Water Heaters
Matsui mf160 dishwasher not heating the water
Hot water heatermag-glass_10x10.gif elements will need to be replaced when there is no hot water, apparently less hot water or the hot water is taking longer to recover after showers, laundry, dishwashing or other demands on hot water. It is not difficult to replace a hot water heater element. Consult the documentation so you can purchase the right element for your hot water heater. If you do not have the documentation, write down the make and model information and take that information with you to a supply store. The store clerk will help you find the right element for your hot water heater.
  1. Step 1 Turn off all power supply to the hot water heater. Turn off the cold water supply to the water heater. Attach a garden hose to the bottom spigot of the hot water heater and open the valve to drain the unit.
  2. Step 2 Hot water heatersmag-glass_10x10.gif typically have an upper and lower element. Open both control panels with a screwdriver. There will be insulation behind each panel. Fold the insulation out of the way; the elements and thermostats will be visible.
    Disconnect the wires from the element and remove the element. If the element is installed with a mounting plate, remove the bolts with a socket wrench. If the element is not installed with a mounting plate, remove with an element wrench.
  3. Step 3 Clean the gaskets and the gasket area on the hot water heater tank. Install the new elements by inserting them into the hole. Be sure the gaskets are tightly in place. If the element is installed with a mounting plate, tighten opposite diagonal bolts so the element stays straight in the tank. If the element is installed with an element wrench, use the element wrench to install the new elements.
  4. Step 4 Reconnect the wires for each element. Close the drain valve. Open the cold water supply. Do not turn the power supply back on yet. The tank must be filled completely before turning the power supply back on to the hot water heater. Open a hot water valve; the hot water faucet on a tub is a good option. When all trapped air has escaped and the water is flowing freely from the spigot without air bubbles, the power supply can be turned back on to the hot water heater. After filling, inspect the area around the elements for any signs of leaking. If everything looks good, reposition the insulation and replace the control panel access covers
Nov 14, 2009 | Dishwashers
I have an old rheemglas fury 22v40 that's leaking from the bottom. What could be the cause? Also, it DOES need replacing, Who does installs at no cost at the time of purchase?
my top element to the hot water heater is working but my bottom element isnt there both brand new elements and im just not getting power to the bottom element but i have power to the top element is it possible that the top heats first and the bottom heats later running out of options!!!
Dec 06, 2008 | Rheem 40 Gallon FVR NATGAS Low WATER...
Amana DLE330RAW Electric Dryer Logo
76 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
