Question about Hitachi 42HDS69 42 in. Plasma Television
I have a black bar about and inch to an inch and half running vertically down the highth of the screen
  • 748 Answers
Hello
This is a capacitor in the power supply going bad. Call a reputable repair person to fix it.
Posted on Sep 24, 2009
Intermittent Vertical 2 inch black flicking to multicolored bar at center of screen ONLY ON THE TOP HALF of the screen on a Philips 63pf963d/37
hola perece ser que la pantalla de su tv no funciona bien no se complique y busque una nueva para reemplazarla busque ayuda profesional por que son muy delicadas y se rompen con facilidad..
Oct 23, 2016 | Philips Televison & Video
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Panasonic TC-P65VT25 has a black vertical line half way down screen.
Sounds like you've had a failure of a part in the electronics. Plasma TVs use pretty high voltages (like the old picture-tube models) and parts can get fried over time. You'll need to have your Panasonic serviced by a qualified technician. Don't try to do it yourself -- high voltages, remember?
Nov 01, 2014 | Panasonic Televison & Video
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Vertical lines/black squares all throughout this 50" TV. Is it worth fixing?
I have 5 vertical black bars coming down halfway on the screen. Also 1 black square that appears on the lower half corner of the screen. What can I do to get them off? Please respond or call me @(510)938-6237 Shon Thanx!!!
Dec 27, 2009 | Mitsubishi PD-5010 50 in. Plasma...
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Vertical black bar down the middle of hitachi plasma tv
Ok if your hitachi TV dies with no power anywhere try this:
Some models have a kill switch under the bottom edge. It's like a gray switch like a small light switch press it back in and voila let there be LIGHT. Saves you at least a $200 trip to repair shop!!
Jan 05, 2009 | Televison & Video
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Hitachi 42HDS69 42 in. Plasma Television Logo
156 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
