Question about Acer Computers & Internet
How do i use my computer and pc to tv at the same time
  • 3,153 Answers
Lots of people are doing this and part depends on what your home theatre has to offer in the way of connections.
For sound most use the LINE OUT on a computer or laptop and connect that to a suitable input on the receiver using a 3.5mm to stereo phono lead.
If you are lucky enough to have an OPTICAL sound out on your computer and one on the home system that would be a better option.
For the video side again it depends on what your computer has to offer
If it has DVI and your TV or home system has DMI then that is the very best option. Remember to lower the resolution on the computer first and to check and of your graphics card options for dual display. A DVI to HDMI lead is needed for that
NVIDIA graphics cards seem to work best in this area.
If you have a VGA connector on your TV that is another great option and you would only need a VGA lead.
Some cards and laptops have S-VIDEO out. Lots of TV's and home systems have these and the display is quite reasonable. If using S-video connections use a GOOD quality cable.
Some people can only obtain a black and white picture so check your graphics card did not come with any special adaptor.
Another method is composite video Even that is not always 100%
Some laptops need a special S-video adaptor which is just a short little cable to properly enable the S-video and convert S-video to composite. That is probably the worst way to do it.
Using a VGA to component lead is also an option but results vary wildly from no picture to quite good. A lot depends on the quality of the lead once again.
I use the optical sound and DMI lead to power a 50" Sony with great sound and picture.
Posted on Sep 24, 2009
  • Acer Master
  • 8,073 Answers
Connect the computer to the TV
1. Through an S-Video cable or
2. A VGA cable,
depending on the input option of you TV, and the output options of your computer.
Then from Graphic properties, extend your desktop to a TV if S-Video, or to a second monitor if VGA cable. For older TVs resolution on computer screen may have to be set to 800x600.
Hope it helps.
Connect pc to tv
You will need a cable that connects the tv to the pc. If you pc has a vga connection and your tv has a vga connection, then you would purchase a vga cable and connect it. If the computer and the tv have 2 different types of connections you will need some type of adapter between the two of them.
Once you get them connected with a cable you just turn the tv on and Select Input (Select either PC, Computer, HDMI) of where the tv should receive the signal.
On the pc if you just reboot it most times the image will appear on the tv. if not you can Press and Hold your FN function key at the lower left portion of the keyboard then hit the correct F1 thru F12 key that toggles the display. The correct F1 thru F12 key will have LCD/CRT on it or it will have the icon of a display.
Apr 28, 2012 | Computers & Internet
I am trying to hook up a 26 inch viZio to my hip desktop utilizing the VGA cord. It won't come up? I am on the comp screen on the tv also.
Once you plug the VGA cable from the computer to the VGA port on the tv, get the remote for the TV and go to the Select Input function so that you can select PC or Computer as the input source. Then Reboot the Computer.
Once the computer reboots it will probably display on the tv. If not, Press and Hold the FN function key on the computer then hit the correct key (F1 thru F12) that toggles the display. The correct key (F1 thru F12) will have LCD/CRT on it or it might have the icon of a display.
Once it is pressed the video should toggle each time you hit it from showing on the Computer only, TV only, both the TV and Computer.
Apr 14, 2012 | HP Computers & Internet
How to connect to tv
Depends on what type of ports your Computer has and what type of ports your TV has. The easiest connection is to try to connect using the ports that they both have. Otherwise, if they have different ports then you will need some type of converter that goes between the two of them to make them communicate.
Most computers have a VGA port, does the TV have a VGA Port? New computers have a HDMI port, does the TV have a HDMI Port? If so you the connections that are alike or you will need a converter.
Once you have them connected, you just have to select the Input on the TV. Most times if you use VGA then you select PC or Computer as the input. There should be an HDMI input selection if you use HDMI connections.
Reboot the computer and the display might appear on the tv. If not you will have to hit some keystrokes to toggle the display between the computer and the tv. Most times on the computer you will hit the FN function key and one of the F1 thru F12 keys that controls the display on an external. The correct F1 thru F12 key will have LCD/CRT on it or it will have the icon of a display. Press and Hold the FN function key then hit the correct Function key (F1 thru F12) that toggles the display.
Apr 07, 2012 | Archos 70 android tablet Notebook
I HAVE A LG FLATRON M197WA LCD TV MONITOR . HOW I CAN OPEN BOTH TV AND PC AT A TIME ? HOW I ADJUST THE MONITOR TO VIEW BOTH IN A SINGLE WINDOW? 0919830151045
You can't. The TV can't operate as both a monitor and a TV receiver at once. In order to use the TV as a computer monitor you need to select the VGA input, which shuts off the TV tuner. If you want to watch TV at the same time, you need a TV tuner card in the computer. Then you can have the TV program displayed in one window while another displays whatever other application you're running.
Jul 09, 2011 | LG Computers & Internet
I have connected my pc to my vizio tv and watched it for two days now it says no rgb signal. the power will be turned off. How do I fix this so I can watch my pc on my tv
First check that your VGA cable is fully seated at both the TV and the PC. Make sure the computer is on and not hibernating or other power saving mode. (Try jiggling your mouse, running a finger on the touchpad (laptop) or typing a character on the keyboard.)
Try connecting the computer to another monitor. (Try a different cable.) Alternatively, connect the TV to a different PC. (This checks if the TV input or the graphics port in the computer is the problem.)
The other issue is which order were the TV and the computer turned back on. (Many TVs need to be on before the computer boots up.)
I hope this helps.
(I run my TV on the computer intermittently (for a dual monitor situation). The last time I did this, my computer did not detect the TV on reboot. In that case, I needed to reinstall my video graphics driver. However, that was simpler to diagnose since the other monitor was attached and working fine.)
Jan 16, 2011 | Televison & Video
Connecting latitude D630 to Sony Bravia
Disconnect all cables and reboot your computer.
Turn off your hdmi TV as well.
When computer is already on, connect the VGA/HDMI cable to your computer and the other end to the TV.
Turn TV on then press Fn+F8 ONLY ONCE.
May 25, 2010 | Dell Latitude D630 Intel Core 2 Duo T7250...
Trying to connect HP a6230n pavillion to Sony Bravia HD TV
Using the original remote for the TV open the setup menu and select SVGA connection for IMPUT every time you use the tv as monitor i hope this solve the problem.
Mar 21, 2009 | HP Computers & Internet
Laptop to samsung tele
  1. Ensure that the connection is a direct cable connection from the PC to the TV, no converters or cable adapters as these are generally not Bi-directional which is required for a PC to see a TV.
  2. Try turning on the TV, then booting the computer. Some devices require the initialization signal from the computer to activate the port on the TV.
  3. See if the TV input select has an option to search for active signals.
IF none of that helps, post the exact model of TV and computer as well as the type of cable connection you are using.
The biggest stopper most of the time is a cable converter.
Jul 08, 2008 | Televison & Video
TV TUNER
Hey Lyn How's Sydney today?
Just a quick thought, have you connected a TV antenna to your computer?
Regards
Helen
Mar 02, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
