Question about Raymarine St6002 Smartpilot Hydraulic System For Mercury Verado Outboards
2000 75HP Merc 4 Stroke 4 cyl. Carburated WILL NOT START
I have a customers 2000 75 hp Merc 4 Stroke 4 cyl Carburated, he hit something and took the skag and 2 blades off the prop, he got that fixed now it will not start, the carbs have all new kits put in OEM, it has a new stator & ECM Unit & 2 new fuel pumps & filter, new spark plugs. it has good spark and compression, the coils, wires and caps test good by spec, all parts replaced were OEM, it has been sync'd and linked. The timing it right on. The fuel is perfect, it did have water in the inboard tank but we are using our test tank now. The Electric thermo valves are testing good, float level is correct, air screws make no difference where they are it still will not start but if it does it slowly peters out after a few seconds. Can even get it in gear before it quits. I did have it running for 100 yds perfect on the water but it died and now will not start. What are we missing?
    Champion:
  • 202 Answers
Ck your fuel pump pressure
Posted on Mar 27, 2010
What year is my 75 hp mercury 4 cylinder serial number 0a986452
Locate the serial number plate by looking on your motor's transom bracket; the plate will have "Mercury Marine" written on the top. The serial number is the top number on the plate. The number directly beneath this is the year it was manufactured.
The year will be determined by the number of cylinders,,,
A 4 cyl. is a 1986 .
75 - 4 Cyl. 1986 ELPTO, ELO A197882 - B249479 = U.S. Serial Numbers A70708 = Canadian serial numbers
Jun 25, 2017 | Mercury Boating
U have a 1971 15 ft phantom bass boat tri haul , the tag is missing , how big of motor will it handle legally ?
I had a 1976 15 ft checkmate. Low sides. It was rated at 100 hp. A 100hp in those days was pretty big. My 90 was a 6 cal merc. Todays motors are much smaller for the same ratings. A 75-90 3 cyl should work nicely and be safe.
Sep 19, 2014 | Boating
1987 Mercury 75 hp 2 stroke outboard motor clicks when we try to start it
Do you mean it clicks and starter not turning ? if yes then the starter solinoid wires are loose or it needs replacing ! more info needed !
Aug 16, 2014 | Clymer Mercury/mariner 75-275 Hp...
Hard hitting on compression stroke when starting
Most Briggs deco vaves are internal and pretty reliable, the valve clearances are very important, if the exhaust valve clerance is too wide the valve lifter will not work, if there is no adjustment yoy would have to fit a new service valve and re do the clerance by removing material from the valve stem
Jan 02, 2014 | Briggs AND Stratton Intek Briggs &...
My crank shaft is rotating twise the crank shaft. HOW MY 1342 FIRING WILL OCCURE?, I can spare only 30 digree for charge and spark plug contact. THERE ARE ONLY 2+2 CYLINDER. 180 DIGREE APPART KINDLY REPLY...
Your crankshaft turns 2x times the camshaft. Put it this way as # 1 cylinder reaches TDC (top dead center) of the firing/compression stroke, and this will be after a (8 degs BTDC) spark to ignite the air/fuel mix, the # 3 cyl. will be at BDC of the intake stroke and as #1 begins its power down stroke, (during explosion of air/fuel mix), #3 begins its compression up stroke, the #4 cyl. will be coming down with #1 cyl. but #4 will be in the beginning of its intake down stroke, and #2 cyl. will be coming up with #3 but #2will be in its BDC of the exhaust stroke. Which has just fired previously to #1. 1342134213421342 etc. Now the cam turns to open / close the valves; In the outline above, #1 cyl. valves will both be closed. #3 cyl. will have the intake starting to close at this point. #4 cyl. will just be starting to open its intake valve, and #2 will be starting to open its exhaust valve. Is all this clear as mud? So as the crank makes one full rotation (in a 4cyl. engine) only the firing of one cylinder has happened.and at every rotation one cyl. will fire. So #1 at TDC then one full rotation, #1 back at TDC, but this TDC is half of its 4 cycles, (1)Intake, (2)compression, (3)power, (4)exhaust. this 1234 refers to the 4 cycles of the rotation not firing order.
Oct 31, 2010 | 2008 Volkswagen Jetta
I'm looking for a downloadable version of the service manual for this motor. Any Ideas? It's a 1994 mercury XRi 175 hp outboard
I couldnt find one anywhere for my merc 75hp 2stroke-ended up buying a service manual $70
Oct 09, 2009 | Boating
Merc 75 4 stroke turns over but wont run
carbs, are gummed up. Pull the carbs and clean em, you'll be up and running in no time. The gas they sell now days, it don't take long for it to varnish.
Jul 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Raymarine St6002 Smartpilot Hydraulic System For Mercury Verado Outboards Logo
165 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
