Question about Hunter Low Profile III 20807 Ceiling Fan
My fan is several years old and, as of today, only the fastest speed works. Supposed to have 3 speeds. Now it's fast or off!! What can I do?
  • 8,404 Answers
Generic comment:
There is a switch somewhere that controls this. It might be the pull string or it might be on the fan itself. You must find it. If you know where it is and if, after you manipulate it, there is no change, perhaps the switch is bad.
Can you check these things and let me know what you discover?
a
Posted on Sep 24, 2009
Casablanca fan intelli touch
there is a starter solenoid inside it works the speed setting. controls speed 1-2-3. 4 it bypasses it. in side the fan you will see a black box with c66 somthing that will need to be changed as that is the part that controls the speed.
Oct 17, 2013 | Dryers
Hi, I have an aloha 3 speed oscillating pedastal fan. motor is almost seized. can it be fixed?
What is the estimate rotation rpm at fastest speed ? Normally pedestral fan is a 6 poles or 4 poles single phase motor?
Jun 08, 2012 | Aloha Housewares Dryers
HI Please tell me how the fan in the front of the engine should work, we had the fan switch replaced when we start the car the fan turns faster before it was slower is this correct, is this how it is...
The fan speeds are control by th ECM. The fans speeds are determined by the temperture and load on the engine. And when you use the A/C. Sometimes you will see them at a low speed , sometimes fast. This is normal.
May 05, 2011 | Mercedes-Benz 190-Class Cars & Trucks
We have a Hampton Bay ceiling fan (about 10 yrs old) don't know the model. It will only turn 1 speed? When trying to change speeds with the chain pull it stays the same. It quit working for a while and I...
the fan changes speed by inserting a capacitor of different values in series with the motor .. direct drive to the motor is the fastest speed .. a large capacitor in series slows it down a bit and a smaller capacitor slows it down more ... so if your fan is running at full speed all the time then one of the capacitors is shorted or the switch is bad .. if its stuck on one of the lower speed settings then the switch has a bad contact .. the capacitors are mounted together in a small box with several wires going to the pull chain switch .. you can replace the capacitor box .. and you can replace the 3 or 4 position switch ... or you can remove all that stuff and put in a remote controled system .. that involves a box that just fits inside the fan .. it is hooked to AC power and neutral .. it then hooks up to the lilght and the fan giving you control over both .. you can vary brightness and fan speed .. you would no longer need the fan or light pull switch or the capacitors ... you could also get a new fan having such a controller .. since yours is fairly old it might be worthwhile to upgrade .. some of the remote controls allow you to set a temperature ..if the room goes above that temp then the fan turns on automatically and the speed is determined by how much higher the room temprature is from that set value .. some remotes also give you an additional very low fan speed .. thats nice at night when you just need a gentle breeze .. some also allow you to set a delay before the lights go out after you have clicked "turn off" ... that gives you time to exit the room or get in bed before the lights actually go out ... kindof nice features that might make it worth while to up grade .. to get parts for your old fan see this URL
http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
since Home Depot sells hampton bay .. then they might have parts as well .. worth a try .. you can also see new models there ..
Jun 06, 2010 | Hampton Bay 52 In. White Redington...
Westinghouse Lighting 3speed Ceiling Fan Switch 7707500: I just replace the speed control switch in my Hunt...
Typically the old and new switches have no relative relationship to each other .. One way to figure this out is shut off the power and then using the black power wire attach each speed wire to it and turn power back on to observe the speed .. mark the wire with the speed 1, 2, 3, .repeat this untill all the wires are identified .. . then you can put the wires on the appropriate terminations on the new switch ..
questions ..
Please vote !
May 17, 2010 | Westinghouse Electric Westinghouse...
My ceiling fan, at speed 5 also not rotating in full speed. I
Most likely the run capacitor has failed. Being 3 years old, I would not suspect the bearings.
May 16, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
I just installed a Hunter five minute fan which says it is called the augusta. I have also installed several other hunter fans in my house through the years, and they seem to move extremely fast especially...
Speed is not a factor in moving air. You can move air with a little fan that runs real fast or you can move the same amount of air with a big fan that moves slow.
It is the pitch of the blades that moves air. Big blades with steep pitch moving slow are comparable to little blades with shallow pitch that move fast.
It seems to me someone is trying to baffel you with bull**** when they tell you CFM = watts or something similar.
The real question is, is the fan moving the air necessary to achieve the result you desire? If yes, speed is not really a factor.
Let me know if this helps you.
a
Sep 22, 2009 | Dryers
PC CD-ROM drives
nero 6 have cd/dvd speed, to check ur drive speed,, actually there are a no. of softwares... try google
Feb 22, 2008 | Computers & Internet
Hunter Low Profile III 20807 Ceiling Fan Logo
54 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
