Question about Zenith ZN-501S Remote Control
TV picture tube color problem
Hi I HAVE PROBLEM WITH COLOR OF TV PICTURE TUBE , COLORS ARE LIKE RAINBOW , I HAVE IDEA ABOUT THIS PROBLEM OCCURS WHEN PICTURE TUBE COME IN CONTACT WITH THE MAGANETIC FEILD ---- IS ANY BODY CAN HELP ME TO BRING THE ORIGINAL COLORS BACK
THANKS IN ADVANCE
Picture started out with whole picture turning red and now is a sepia. Is this the picture tube going out. I called the cable co. and pushed the volume and info buttonsas they suggested, but it didn't help. They said it must be my TV. C. Weaver
  • figambi Dec 21, 2007
    i have a sharp tv which of late displays only the blue and green components of the picture and no red. I have tried resetting the machine with out any results, how do i go about this.
  • 395 Answers
SOURCE: red color gone on tv?
is the red gone on all inputs? do you have the tv hooked up, to a sat box, cable box via component video (Red, blue, green connections)? if so check the red cable on both ends.
Posted on Jan 29, 2008
Slinteriors
  • 8617 Answers
SOURCE: 1999 zenith 52 inch rear projection screen t.v.
IS the screen white retrace lines ? Have you looked into the CRT lenses while they are on with a signal applied through the input to see if an image is displayed in the lens lens of the crt? Let me know what the answer is to these two questions and we will go to the next level.
Posted on Apr 10, 2008
joboo1
  • 257 Answers
SOURCE: I think my picture tube is going out on my Zenith System 3 Tv
Hi, Sorry it took someone so long to get back to you, but nobody likes to give bad news. This tv has a 1.7R tube with 530 resolution and an NTSC tuner which means it is analog and with the new change this month you would need a converter box anyway unless you have cable or satellite. Because of this particular tube and the labor to change it, it would indeed more expensive to replace it than buy a new one. Best of luck to you!
Posted on Feb 05, 2009
darjr
  • 379 Answers
SOURCE: Volume control doesn't work on Grundig t 55-640
Some TV has a hotel mode, try checking in Menu maybe your TV is in Hotel mode thus preventing you to maximize the sound or volume.
Posted on Jun 01, 2009
SOURCE: P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Posted on Jun 14, 2010
Rainbow screen aiwa tv,, screen shows different colors like rainbow// brushing a magnet infront of the screen fixes the issue temporary
Picture tube is magnetized. Manual degausing is required. already you have done this.
Since you say it is reappearing, you have to check the following.
1. Relocate the TV or relocate if you have placed any tower speakers
or home theater speakers close-by.
2. Check whether auto degauss functioning OK. In the MENU
check whether you switched off auto degauss option. If it is OFF
enable it to ON.
3. Finally re orient the direction of your TV and watch the rainbow
effect. Switch OFF TV, wait for 20 mts, and again switch ON.
Repeat the process. It should disappear.
Magnetic toys or any other devises using magnet will cause this problem.
Aug 11, 2010 | Aiwa TV-S2011 20"
Rainbow look on my picture
hit pictue tube w open palm if colors move crt shot.  if not magnatized need degaussing.  or defl youk loose.
Nov 30, 2008 | RCA 36F530T 36" TV
Sony Trinitron Color Rainbow
Usually when a tv is dropped the phospher screen inside the picture tube will detatch making the rainbow color This cannot be fixed as it requires changing the picture tube. Only other thing is demagnatize it with a demagnitizing coil (used by tv techs) but not likely to fix it since it was dropped. You have a bad picture tube.
Dec 30, 2007 | Sony KV-32FS13 TV
Insignia IS-TV040919 color problem
The tv has been dropped or banged around, you can try to get a degaussing coil and fix the colors, if you cant pull them back out than it would need a CRT/Picture tube...in other words the tv would not be worth anything.
Nov 11, 2007 | Insignia IS 20" TV040919 TV
Rainbow of color when viewing DVD
TRY TO MATCH THE SYSTEM OF THE TV AND DVD. IF ITS NTSC SET IT BOTH WAY OR IN OTHER SYSTEM
Jun 06, 2007 | JVC AV-32120 32" TV
Rainbow picture
The tube needs to be degausse you had maybe placed speakers beside the tv causing it to magnetize have a tech look at it to remedy the problem.good luck.
Apr 08, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
25TS56C22125
The description of the problem points to the picture tube being bad because of the rainbow colors,as far as the white lines you might have an open resistor in the crt board,a qualified technician should take care of the problem if the set is repairable and He will know as soon as he sees it.Good luck.
Sep 17, 2006 | Philips Magnavox 27MS343S 27" TV
Rainbow colors after a lightning storm
you need to borrow or rent from a repair shop a degaussing coil. Its a big coil of wire that plugs in and has a switch on it. How you use it? With the coil plugged in,but not switched on ,hold the coil in front center , about two inches fron the picture tube. Now switch on the coil and slowly rotate the coil in a circle all the way around the picture tube and at the same time pulling slowy away fron the front of the picture tube. Keep doing the circular motion till you reach about three feet from the front of the tube, turn the coil sideways fron the tube and quickly shut off the coil. This is done with the tv set on. The set should look clear now ,with no color blotches on the corners or the rest of the picture. If it dosent then the pictre tube is bad. If it does look good, shut off the tv set for a hour or so , turn back on the tv set, Is the colors back on the screen. Yes , then ther thermistor or degaussing circuit needs to be serviced, and this is something you will need to call in a tech to service for you cause theres extremly high voltage inside these sets and not for a handi-person to tinker with. But if its good then your all set. Good Luck
Jun 14, 2006 | Samsung TXN2771HF 27" TV
Zenith ZN-501S Remote Control Logo
401 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
