Question about Motorola Mobility Karma QA1 Cell Phone
At&t symb comes then shuts off - Motorola Mobility Karma QA1 Cell Phone
Wont start cranks no gauges slashed key symb on dash lit
Sounds like your Sentry Key Immobiliser Module may be at fault. That's a Main Dealer Problem. Try disconnecting the battery lead for a minute or 2 then reconnect. Red.
Dec 01, 2014 | 2003 Jeep Grand Cherokee
Tip
Nokia Symbians Secret Codes
Nokia Code function
*3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
*#4720# With this Nokia code you can deactivate the Half Rate Codec
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
*#9999# Phones software version if *#0000# does not work
*#06# For checking the International Mobile Equipment Identity (IMEI Number)
#pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
*#147# This lets you know who called you last (Only vodofone)
*#1471# Last call (Only vodofone)
*#21# This phone code allows you to check the number that "All Calls" are diverted to
*#2640# Displays phone security code in use
*#30# Lets you see the private number
*#43# Allows you to check the "Call Waiting" status of your cell phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
*#67# Allows you to check the number that "On Busy Calls" are diverted to
*#67705646# Phone code that removes operator logo on 3310 & 3330
*#73# Reset phone timers and game scores
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
*#7760# Manufactures code
*#7780# Restore factory settings
*#8110# Software version for the nokia 8110
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
*#94870345123456789# Deactivate the PWM-Mem
**21*number# Turn on "All Calls" diverting to the phone number entered
**61*number# Turn on "No Reply" diverting to the phone number entered
**67*number# Turn on "On Busy" diverting to the phone number entered
12345 This is the default security code
press and hold # Lets you switch between lines
Symb OS v6.1
    Nokia 7650
    Nokia 3650
    Nokia 3660
    Nokia N-Gage
    Nokia N-Gage QD
    Siemens SX-1
    Sendo X
Symb OS v7.0
    Nokia 3230
    Nokia 6600
    Nokia 6620
    Nokia 6260
    Nokia 6670
    Nokia 7610
    Panasonic X700
    Panasonic X800
Symb OS v8.0
    Nokia 6630
    Nokia 6680
    Nokia 6681
Symb OS v8.1
    Nokia N70
    Nokia N90
Symb OS v9.1
    Nokia N91
    Nokia 3250
    Nokia E60
    Nokia E61
    Nokia E70
    Nokia N71
    Nokia N80
    Nokia N92
Nokia phones service codes
*#0000# - SW version
*#06# - IMEI
*#war0anty# - SIMLOCK info
*3370# - Enhanced Full Rate ON
#3370# - OFF
*4720# - alternative sound quality codec ON
#4720# - OFF
*#7780# - default factory settings
*#7760# - production serial no.
*#2820# - Bluetooth info.
*#73# - reset phone timers and game scores.
*#7370925538# - delete all the content of the wallet and the wallet code.
*#7370# - soft format — erases all telephone memory.
[Green]*3 - hard format — if only the telephone memory is formatted, puts back the attitudes and reboots
*#delset# - MMS/GPRS settings removal
NOTE: code depends on phone model
on Oct 09, 2008 | Nokia E71 Smartphone
No channels found
you have reseted your box to manufacturer default values....if you are not having correct parameters(trans. no., symb rate,etc) of your satellite then you have to contact the service man...before that , make a blind search of channels with trans freq 05050...this may get you..
Aug 19, 2009 | Televison & Video
Integration, too few arguments
I reset my calculator and this solved the problem. To reset your calculator press [2nd], then [6] (Mem), press F1 (reset), Select 3 for all memory, and select Yes.
Oct 23, 2008 | Texas Instruments TI-89 Calculator
Amp Err
please check all speakers cables for short circuit-disconnect all speaker-put volume low-wait and observe it if no shut down -go to next step-connect your speaker one by one until you find the bad one,start with speaker cable(try another good cable) and then speaker.if shut down happened again while you connect nothing to your system you will have inside problem and ask for service center to fix it.
Jul 07, 2008 | Audio Players & Recorders
Sub problem
have u tried bridging the speaker wires. amp could be gone?
May 19, 2008 | 2002 Pontiac Grand Prix
CHINA N95
Install the appropriate Nokia PC Suite for your phone.
Then you can connect your phone to your PC and download games using the application installer.
Nokia.ApplicationInstaller %ProgramFiles%\Nokia\Nokia PC Suite 6\ApplicationInstaller.exe %1
Nokia uses the Symbian Operating System. Some SIS-file malware has started to show up. For example, the file CARIBE.SIS containing the components CARIBE.APP, FLO.MDL, and CARIBE.RSC is a worm called Symb/Cabir-A which will attempt to send itself to nearby Bluetooth-enabled devices.
Jan 15, 2008 | Nokia N95 Cellular Phone
Motorola Mobility Karma QA1 Cell Phone Logo
13 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
