Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA projection, no power, no sound. recently moved.
I recently moved my RCA projection tv to my winter camphouse. Before I left, it worked fine. When I arrived and plugged it up it wont turn on. It has power and I checked the small fuse in the back. It ohmed good. Getting power to the outlet and tv. What could have happened?
  • RCA Master
  • 8,457 Answers
Ur DM power board have burn capacitors,check for puff up capacitors,and replace it.Tries these websites.Tv Repair World.com Shopjimmy.com Ebay.com or Partstore.com.
Posted on Sep 24, 2009
The tv wont turn on but the light will turn on and the a second later
open up the bottom left panel in the back of the tv, get a vacuum and vacuum all the dust within and get a hairblower and blow dry panel inside for like ten minutes moving it around , dont let sit in one area for a long time.. after that try turning it on it should work now
Nov 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
Rca screen projection tv will not turn on what can I check
There is 3 capacitors on power/deflection board cp150 2200uf16v look to see if it is puffed up on top if so replace 2 more caps aswell in same circuit cp114 cp120 220uf 35v.
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv wont turn on
What is your Chassis# and what year is TV??
Nov 18, 2008 | RCA P56950 56" Rear Projection Television
Tv wont power up ?
TV turned off and will not turn back on.
Sep 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca P52960 with the ptk chasis
It sounds like the flyback is actually defective. The set wont power up at all correct?
May 12, 2008 | RCA P52926 52" Rear Projection Television
RCA P61929 picture problem...
The TV was working fine, some time during the night the power went out, its plugged into a surge protector, everything else works fine, the TV won't turn on, the fuse is fine, is there a reset switch?
Dec 06, 2007 | RCA P61927 61" Rear Projection Television
Recently moved the tv
The possibilities are that either you have a bad connections somwhere causing a shutdown or a board has a crack in it that happened from moving it.
Feb 25, 2007 | RCA P61927 61" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
88 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
