Question about Alpine Car Audio & Video
My alpine car stereo won't power up easily. it took me a half-hour to get on and now I can't change stations. I did take the back plate off to clean one of the buttons that got sticky from a coffee spill but this new problem is on the other side of the faceplate and just what is that red reset button on the head unit and what did I do pushing it in desperation
Duncan
  • 218 Answers
SOURCE: older Alpine car stereo light problem
It's probably a solder in lamp. They can tend to be very tiny. About the size of the head of a paper match or smaller. If you're not good with soldering then I would suggest you go to a repair shop and let them do it. Good luck.
Posted on Apr 30, 2007
  • 26 Answers
SOURCE: Faceplate not working
Try disconnecting the unit completely.
Posted on Nov 09, 2007
  • 11 Answers
SOURCE: Faceplate won't close
Alot, of the radios have a common problem with the connection from the radio's2.gif detachable face. What happens is corrosion builds up on the connectors between the pin and the connector itself. Sometimes you can clean it off with a small file. Also, some KENWOODS with the motorized face are known to have a problem with the ribbon cable connecting the face plate to the main board. The last time I repaired one I called KENWOOD2.gif and aquired the cable for about 65 dollars, what the problem is, is the cable is wrapped around a plastic white spindel with a high tension spring and places alot of pressure on the cable from the wear and tear of the face opening and it will cause strange problems such as: turning on and off, some buttons working while others don't, the display partially turning on and off, and the face to act peculiar and flip down halfway. In addition, sometimes the face open and close switches go bad, but I've never had to replace them yet. .
Posted on Dec 16, 2007
  • 4 Answers
SOURCE: Accidently removed the tiny screws behind faceplate
It could just be a plastic clip that broke.Most of the car stereo's ive taken apart only have a thin ribbon of wires that run into the contacts that your face plate connects to.If you actually took screws out of the faceplate then id put them back in and put it back into your stereo and see if it illuminates properly,if it does not then id search on E-BAY or contact pioneer and buy a replacement but most the time it would be cheaper to just buy new stereo.You might want to be more specific with the area you took screws out of,the way im reading it sounds like you unscrewed the screws in the face dock, not the faceplate.Hope this helps.
Posted on Dec 20, 2008
  • 3 Answers
SOURCE: How do I preset the stations for an Alpine TDA-7547 car Stereo
Select the station you want. Then hold down one of the 6 preset buttons for a couple seconds. When the station ID flashes, release the button and it should be saved.
Posted on Sep 16, 2009
I have An Alpine Navigation system from my 2004 Honda accord. it stopped working a few months ago and not only can I not use the GPS, I can't change the radio stations, set radio stations, use the in dash...
Alpine Navigation Technical Support (888) 628-4357.
Ship to:
Alpine Electronics of America, Inc.
2012 Abalony Avenue - Unit D
Torrance, CA 90501
Include:
Description of Problem
Return Address
Phone Contact
Include check or money order for $158 made payable to Alpine Electronics.
Mar 25, 2011 | Alpine GPS
My 9821 Alpine faceplate is scrambled. I cannot read the stations or the time. The radio and stereo play alright. Whats the problem with the faceplate? Ive bought other ones and have the same problem with...
had the same problem with my alpine, i was able to fix it once by, popping off the face plate and with fine grit sand paper (lightly) sand the connection point on the radio and the face plate, then put a little bit of dialectic grease on it. also doing a reset on the unit helped me from time to time...
May 01, 2010 | Alpine CDM-9821 CD Player
Trying to set the radio stations on Alpine stereo
The radio either does not have the yellow power wire connected(constant 12v) or the wire is connected to a switched source and when the key is turned off the radio has no backup power. You will need to pull the radio out and verify the yellow wire is not connected to switched voltage and connected to constant power. It is also possible that they have the red and yellow wires mixed up. Remember yellow constant power and red is switched power(with ignition key). And also disconnect your negative battery cable when working on the electrical system of your vehicle...you may short something out and damage your vehicle's electrical system or head unit.
Sep 19, 2009 | Alpine TDM-7543
Face plate buttons wont work
This is actually a common problem with more than just that radio. Sometimes the pins on the back of the face plate need to be cleaned. Take the face plate off, take a Q-tip and dip it lightly in some rubbing alcohol. Then use that to clean the metal pins on the back of the face plate. Make sure it is completely dry before you place the face plate back on. If this does not work, your better off replacing the whole thing.
Jan 20, 2009 | Alpine CDM-7874 CD Player
Alpine CDM 7854
my solution is, that you so called experts don't know squat, so you try to get people to pay
19.99 a head to set stations on a stereo
Jan 04, 2009 | Alpine CDM-7835
Alpine CDA 9825, wife hit a series of buttons, now I only see what is on the display when I change a station or turn vehicle on. How do I get the text back on the display?
i would suggest unplugging the wiring harness from the back of the alpine terminal (you will need to basically take out your stereo). then plug it back in, roll the key back in you car (to give power to the stereo) and see if it works. if not, take it into you local visions electronics and ask them to look at it for you
Dec 11, 2008 | Alpine Car Audio & Video
How do I preset the stations for an Alpine TDA-7547 car Stereo. This is an older stereo and setting the stations is not intuitive.
Dec 06, 2008 | Alpine TDA-7547
Alpine CDA-7840 works but does not light up for about half an hour
I have the exact same problem and it has been driving me nuts for several years now.  I have tried everything with no luck.  I finally resorted to buying a used faceplate on eBay (and they had several available so I suspect this is a common problem).  I will let you know how it turns out.
Nov 11, 2007 | Alpine CDA-7840
Installing rear speakers
You need a pair of alpine radio removal keys which get inserted in the slots along the sides under the trim ring. Any Car stereo shop should have them for free(ish).
Sep 09, 2007 | Alpine TDA-7547
Older Alpine car stereo light problem
Apr 29, 2007 | Alpine CDE-9846 CD/MP3 Car Stereo
Car Audio & Video Logo
194 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
