Question about RCA F32650 32" TV
NO PICTURE I HAVE A RCA F32650 TV I PUT A NEW HORZ OUTPUT TRANSISTOR IN IT AND A NEW FLYBACK AND NOW THE PICTURE TUBE WILL NOT LIGHT UP AND THE NECK OF THE PICTURE TUBE IS NOT LIGHTING UP I HAVE SOUND.
    Problem Solver:
Adjust the two settings on the back of the flyback with a phillips screwdriver...
Posted on Dec 16, 2007
  • azcat90 Dec 16, 2007
    They are usually all the way off when new flyback is shipped out - turn them clockwise with mirror in front of the tv so you can see the effect...
We replaced the transformer for our RCA F27650. It was sparking and now it is not, but now the screen won't turn on. It is just black. We hookd all the wires up like they were. we can hear sound, but...
Hello
Along with the flyback transofrmer, its horizontal output transistor also must be replaced. I don't know whether you have replaced it or not. If not, replace it too. It can be located very near to the flyback transformer, a three terminal component, black in colour, usually screwed to a metal heatsink. Then switch on the TV and measure the video output voltage at the video output card pluged directly to the picture tube neck. The collector of the video aoutput transistors must come around 145VDC. If it also is there, advance the screen control on the flyback transformer to get a raster. If that voltage is not there, it means that the flyback transformer is not working, and horizontal oscillator stage should be checked for oscillation, check the lined drive transformer for its primary winding open, Check the entire horizontal oscillator section. The collector point of the line drive transistor, the transistor that drives the line drive transformer, a small transformer soldered diretly to the printed circuit board; should be checked with frequency meter. The frequency at that point should come around 15525HZ approx: OK.
Mar 19, 2011 | RCA F27650 27" TV
My rca tube tv has a high pitch whine when i plug it in no picture also
Hello you have a shorted Horizontal output transistor, also if you replace it also have the Flyback transfromer replaced also, these parts work in conjunction with each other, and if one goes bad its best to replace them both.
Dec 20, 2009 | RCA F32650 32" TV
10-year-old 32" RCA PIP TV just blinked off one morning after about 30 minutes. It makes a continuous high pitch sound, and the on/off switch is completely unresponsive. I assume this is a picture tube and...
It's not the picture tube(especially if image was good b4 it went dead). The high pitch noise is the power supply whinning because it's shorted or overloaded. I just fixed one of these sets - replaced the horiz. o/p transistor and flyback estimate around $120.00-$160.00
Oct 24, 2009 | RCA F32650 32" TV
I need to find a service manual for an RCA F32650 so I can replace a blown flyback transformer, preferabley free if possible
I have repaired many of these; if a high pitched buzz when you plug the set in---flyback and horz. output transistor are bad--transistor has a generic number on it--Flyback is location number LL05, part number should be 257805---you will find RCA no longer has this part--most now are replaced with an asti #2078----CHECK the RCA number on Ebay---company I get them from is Suburban Electronics---Flyback and transistor are less then 30 dollars for both.
Aug 06, 2009 | Televison & Video
Tv problem
it can be the flyback transformer and maybe horizontal output transistor. famous for that
bc
Jan 26, 2009 | RCA F32650 32" TV
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
Where can I horz output for my tv?
You can get one from Here
http://www.partstore.com/Part/Thomson/RCA/237470/New.aspx
I would only use the original part. This site I gave you is for the original Horizontal output transistor. If the part goes bad again, or runs hot, the capacitors in the circuit or the flyback is bad. Good Luck
Jan 07, 2008 | RCA F32450 32" TV
RCA TELEVISION
Heres the fix for your set, replace the following 2 parts:
1) flyback transformer RCA part number 257805
2) horizontal output transistor RCA part number 237470
you must be proficient at soldering & un-soldering or you can`t replace these yourself, be advised that the anode lead coming from the top of the flyback transformer can carry a VERY NASTY shock if not discharged properly before trying to remove it from the picture tube, I`d strongly advise you to call a tech unless your familiar with this type of repair, BMW Rider
Dec 09, 2007 | RCA F32650 32" TV
Proper grounding point for RCA F32650 TV
Leave set unplugged for a few hours = HV gone or discharge to CRT ground strap........................
Note: Part list.....257805 or ASTI 2078 xformer and
237470 horiz output xistor ( Do not use generic)
transistor must be first quality, no seconds ! !
Nov 25, 2007 | RCA F32650 32" TV
Will not turn on.
  • proceed as given after your power supply is ok (your statement)
  • isolate power supply from h/output stage.
  • check diodes & capacitors connected with flyback transformer.
  • check for print short.
  • ckeck h/output transistor.
  • connect supply to h/output stage.
  • put on the set.
  • hope this will help.
  • good luck
still there is a drop in voltage then your fly back transformer faulty.
Oct 12, 2007 | RCA F32450 32" TV
RCA F32650 32" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
