Question about Nokia 6340i
Nokia 6340i has broken power button -? Keybrd command 2 power up
The power switch is disintegrated. Is there a power command from the keyboard that will turn the power on. I want to download Mem to Sim card and put it in another phone that is same make and model
Why in bluetooth keyboard cover for Lenovo Tablet Yoga 10 the "Delete" buttom does not working?
Could be something as simple as dirt under the button, get yourself some electronic switch cleaner and spray under and around the button. Always keep keyboard clean.
Jul 21, 2014 | Lenovo Yoga 10 Bluetooth Keybrd Cover
Hi, I can't remember what buttons to push on my keyboard to switch from one computer to the other with my belkin 2 port kvm switck? can you help me, Ive just set up the system in another office. Thanks...
Short answer:
There are two ways to switch from one machine to the other with the keyboard
1. Press Scroll Lock key twice, then the Up or Down arrow key.
2. Press Scroll Lock key twice, then enter 01 or 02.
Long answer (from the manual posted at www.belkin.com):
You can select which computer to operate by either the front-panel push button
located on the top of the Switch or through hot key commands. Note that it will
take 1-2 seconds for the video to display after switching. This is due to the
refresh of the video signal. A re-synchronization of the mouse and keyboard
signal also takes place. This is normal operation and ensures that proper
synchronization is established.
You can conveniently change ports on the Switch through a keyboard command
sequence using the "SCROLL LOCK" key and up and down arrow keys. To send
commands to the Switch, press the "SCROLL LOCK" key twice within two seconds.
You will hear a beep for confirmation. Then you can press the up or down arrow
keys to switch between ports.
You can switch directly to any port by entering the Switch port number you wish
to use. For example, if you press "SCROLL LOCK", "SCROLL LOCK", "2", the
computer on port 2 will be selected.
AutoScan Mode
In AutoScan mode, the Switch remains on one port for eight seconds before
switching to the next. This time interval cannot be changed.
To enable AutoScan mode, press "SCROLL LOCK", "SCROLL LOCK", "S".
Note: There is no mouse or keyboard control in this mode by design, in order to
prevent errors. If it were enabled, the user could move the mouse or use the
keyboard while the KVM Switch is switching to the next port. This could interrupt
communication between the computer and Switch that might cause erratic mouse
movement, or result in errant display of characters when using the keyboard.
To disable AutoScan mode, press the space bar.
Feb 05, 2011 | Computers & Internet
Nokia 6340i - Unable to change network setting
go to call settings and change the network type
Feb 01, 2010 | Nokia 6340i
My pc acer keybrd just went stpid on me
At the usb port you have an item plugged into it that receives signals from the keyboard and mouse, push the connect button, if not go straight to your mouse, turn it over and push the connect button.
If you had to press the connect button on the receiver and the mouse if it had lights on it that was blinking it will stop if not check batteries.
Then and only then press the connect on the receiver then the keyboard and not the other way around. If there was a connect button on the receiver and you did this operation the lights will stop blinking and all should be sweet, if not replace batteries.
Hope it helps.
Sep 06, 2009 | ViewSonic Wireless Keyboard and Mouse...
Keybrd quits working on laptop after ctl-alt_del to reach login
Repeating keys? This is a common problem for KVM switches if you go beyond the devices' capability. As you can see, GCS62 is a PS/2 KVM switch and it was designed to work only using a regular PS/2 keyboard.
This KVM switch does not support PS/2 to USB adapter. It might work but it's not guaranteed to work correctly. This does not work properly if you have a docking station for the laptop. It might work for couple of months then it would stop.
You smay isolate the problem by following the steps below:
1. Connect the keyboard directly to the computer to see if you will get the same problem.
2. Power cycle the KVM switch by disconnecting it from the computers and leave it unplugged for a minute or two.
3. Avoid using hybrid connection (PS/2 converted to USB) only for testing purposes.
4. If that work, then you know the answer is that this KVM only designed an work correctly with native PS/2 connection.
Feb 22, 2009 | IOGear MiniView GCS62 2-port KVM Switch
Codes
you problbly put the machine in "keyboard 2" mode, just put it back into "keybrd 1"
Nov 19, 2008 | Brother EM-530 Typewriter
Unlock codes for 6340i please
try this
turn on the phone without a sim card
then enter one of this codes:
#pw+719 910 645 711 014+1#
#pw+335 406 467 306 604+2#
#pw+972 402 004 036 605+3#
#pw+894 571 125 237 770+4#
#pw+272 215 503 074 012+5#
#pw+243 335 572 175 334+6#
#pw+814 541 142 247 545+7#
then insert the password: 12345
let it reboot(restart)
REMEMBER YOU DO NOT ENTER WRONG CODE MORE THEN 3 TIMES. PLEASE DO IT ON YOUR OWN RISK,OR GO YOUR NEAREST NOKIA SERVICE CENTER.
ALL the best
May 27, 2008 | Nokia 6340i
S510 keyboard problem
check for new keyboard drivers on the manufacturers website.
Check the connection into the PC.
Feb 28, 2008 | Computers & Internet
KVM GCS1734 with microsoft wireless mouse/keybrd 4000
The MS keyboard & mouse receiver is effectively a USB hub with two devices connected to it. So, plugging it into the keyboard socket on the KVM switch may well work, depending on how that particular switch implements USB. If it just passes things through, it should be OK. On the PC side you should only need to plug in the USB cable from the switch's keyboard port.
Sep 30, 2007 | IOGear USB gcs1734 4-port KVM Switch
Nokia 6340i Logo
170 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
