Question about iRiver H10 MP3 Player
Turns on by itself
I have no problems using my iRiver or turning it off. The problem is when I turn it off, about an hour later the screen turns on to the welcoming scene and won't move. I can't turn it off or reset it. I have to wait for it to die and recharge it after every use. I am hoping there is a better way of doing things, instead of letting the battery die and recharging it every time. It even does this when I put the lock on the iRiver after I turn it off. Any advice?
    Problem Solver:
  • 17 Answers
Format the player it sounds like the settings may be causing this or just a glitch then reload firmware. if not ... well I dont know
Posted on Mar 24, 2008
After upgrade of software Phone turns itself back on even hours later
There is likely a process or application that is preventing your phone from turning all the way off, or it is turning your phone back on for its own purposes. Check the permissions of your installed apps to make sure none of them have that permission, and talk to Verizon to see if the recent upgrade may be causing the problem.
Nov 24, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
We were watching TV and the TV just turned itself off. We try turning it back on and we have a black screen for 10 seconds and then the TV turns itself off again. Called Sanyo and they said to unplug it...
Yes,unplug,replug the tv an hour later.The tv should reset itself back to factory setting and work.Not,than the tv power supply board have problems.That the board,where the power a/c coard plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 07, 2010 | Sanyo 42 in. LCD TV
Bush tv frequently turning itself off
make sure you have not accidentaly scheduled a power off and on if yes torn off/disable them if not check that your power cable is secure
Dec 21, 2009 | Televison & Video
How do I set the hb51r so it turns on and off after 6 hours?
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk unless you set override feature shown below
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
From these instructions, you should push button until 6 displays. Timer will turn ON at dusk and turn OFF 6 hours later
If timer.
If you want timer to turn ON immediately and turn OFF 6 hours later, push button until 6. shows in display.
If timer does not display or does not operate correctly, then timer is suspect. Return timer for another one.
Oct 02, 2009 | Intermatic Outdoor Timer/Photo Control...
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
H300 battery after being charged lasts about 15 minutes tops
buy a battery kit from the site underneath your question and install it yourself.I did this-cost $29 now my iriver h320 has anew life and is better than ever!
Mar 29, 2009 | iRiver H320 MP3 Player
IRiver H10 Turns On but then Turns Off After 20-50 Minutes
yes by the sounds of it , it is your battery try buying a new battery and see how it works form there if it is still playing up you will have to go to your nearest electronic shop and get them to have a look at it
Oct 10, 2008 | iRiver H10 MP3 Player
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Iriver h320 battery problems
your battery is broken you must buy new battery (very good battery is 2200 mAh because battery install in your iriver is 1350 mAh)
Oct 01, 2007 | iRiver H320 MP3 Player
Picture disappearance & tv turns off
It sure sounds like you have a classic case of bad solder joints. Resolder all the connections on all boards.
May 31, 2006 | Toshiba 36A43 36" TV
iRiver H10 MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
