Question about Westell Wirespeed Computers & Internet
It says I'm connected but no internet pages come up.
  • 1 more comment
  • mathewperry Sep 24, 2009
    I have a westell verizon router connected to an rca cable modem. I can't seem to get them on the same page. my computer says I am connected but the internet does not work unless i unplug the ethernet cord from the router and plug directly into computer. It did this before but all of a sudden just started working. It stopped again because I unplugged everything to move it around.
    it goes cable modem ---> wireless router ---> computer. when i ran the ipconfig it says i have an ip address and everything looks fine. i am currently plugged in directly to my modem. the router is not plugged in to either. when i plug from modem to router i get no connection on my computer. even if i plug from modem to router to plug in computer i don't get anything. wireless never works. i can't seem to get info from modem through router to computer.
    westell 750015. the back of it has a port for dsl and 4 others. i don't have a plug that fits into the dsl one though. i was just using an ethernet cord to go between the modem and router. like i said that worked at some point but stopped when i unplugged everything to move it. the wireless does not work. it says i am connected just fine with my network but nothing ever materializes in internet explorer. i am curently plugged directly into modem. nothing is plugged into router.
  • 742 Answers
Is your connection wireless? if you are connected to the router but you dont have internet access, what about the other computers connected in same network, do they have internet connection?
first you must check if you are in the network: 1. Open RUN (Start => RUN) 2. Type in the box "cmd" (without the quotes) then press ENTER 3. When the DOS Prompt loads, type "ipconfig /all" (without the quotes, space between g and /)
Now, do you see an IP? It should be like 192.168.xxx.xxx If you have an IP, then you are connected to the router but you were behind a firewall or browser settings problem.
Keep me informed with your comments. Please tell me your connection scheme like: Internet modem => Router (wireless) => PC/Laptop
Posted on Sep 24, 2009
  • 2 more comments
  • Jess Sep 24, 2009
    the connection should be Cable Modem => Wireless Router
    then from there, you can plug an RJ-45 LAN cable to a desktop or any LAN-capable device to get connected. Besides, wifi should work already.
    In your wireless router, there is an "isolated port" named "internet", there should your modem cable go. And you have additional 4-ports for wired LAN connections, right? Bty, what is the name (complete with model) of your router? Since some routers should be configured first to work with the internet connection you have.
    Please keep me posted with your comments
  • Jess Sep 24, 2009
    if you are using linksys, try to access your router to configure it: click here
    if you are using d-link, click here
    if you have other routers, then tell me the name to help you access the configuration page.
  • Jess Sep 24, 2009
    ok. so that you can use your router, it should be connected this way:
    MODEM => (patch cable, RJ-45 cable) ROUTER
    from your router you can connect with wire from any of the 4 ports to a desktop or laptop. Besides, you can configure your router to broadcast wifi signal as well.
    Ok. try to follow those steps: Connect you modem to your router using the correct cable that fits to the DLS port. from there, your modem will broadcast internet to all that is connected to your modem. When this connection is done, visithttp://192.168.1.1 orhttp://192.168.0.1 to configure your router. OK, before you can visit that link, make sure that the computer you are using is connected to the router to any of the 4 ports.
  • Jess Sep 24, 2009
    One more thing sir.
    We will test your router this way without internet since you dont have the cable from modem to router taht fits to the DSL port of your router.
    Connect any PC to your router using LAN Cable. Turn on your router. Then visithttp://192.168.1.1 or 192.168.0.1 to configure it.
    Or simply command "ipconfig /all" in the DOS prompt and see if you got an IP address
    When you are connected, then the only problem left is the cable to connect your router to your Cable Modem
    President:
  • 1,865 Answers
Click on start and then "run" and type in cmd.exe
When the window comes up, type in ping www.verizon.net
If you are connected to the internet, you will see a reply from that website (4) times. If you are not connected to the internet, it will say no repsonse.
Go to accessories, then communications, and click on new connection wizard. That may get the internet pages working
Etting error message 50300
Error code 50300 implies that your internet connection settings aren't right.
Nintendo DS:
On your DS you'll want to navigate to System Settings > Internet (it's on page 3) > Connection Settings. Select an empty connection to use (it'll say "None"). Select the "Search for an Access Point" option; it'll show you all available networks in range. Select yours and provide any security key/password if needed.
Here's the specific support page for error code 50300.
Here's a detailed guide on how to set up an internet connection.
Wii:
From the main channel menu on the Wii, hit the Wii button. Then navigate to Wii Settings > Internet (page 2). Select an empty connection, choose your connection type and then follow the on-screen instructions. You should first try choosing "Automatic" or "Auto-Detect" whenever possible. If that doesn't work, try using Manual settings.
Hope this solves your issue!
Mar 25, 2011 | Nintendo Video Game Consoles & Games
My laptop is not connecting to the internet, its all connected to the wireless but when m trying to connect to the internet, its saying "the page cannot be found"
A 'page not found' error usually means that you are connected to the internet but the address of the page you want cannot be determined. Try connecting the laptop directly to the router with an ethernet cable and see what web pages work correclty. Then try wirelessly but do not go too far from the router.
Feb 26, 2011 | Computers & Internet
Wont connect to the computer or internet
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 30, 2010 | Belkin (F5D7230-4) Router (587009)
I hit the e icon and it says intenet explorer cannot open website
first make sure you are connected to trhe internet. Next go to TOOLS options and change the home page to some other location that you know works.. Try www.google.com and making that your home page till you decide which page you really want as a HOME page.
Please rate my help++++Thanks for using FIXYA
Nov 22, 2009 | Acer Aspire One PC Notebook
When i open it the page says cannot display the web page
CHECK YOUR INTERNET CONNECTION IS ACTIVE AND CONNECTED PROPERLY TO THE COMPUTER AND THEN TRY AGAIN
Oct 10, 2009 | Microsoft Internet Explorer 8
Page Cannot Be Displayed
Your internet is NOT connected properly.
Go to your "control Panel" and click on "network connections" to connect to the internet connections available. Make sure your modem is turned on and all the wires plugged in as well.
Jun 07, 2009 | Computers & Internet
Connected to the internet but IE cannot display the web page.
have you checked if the gateway you're connecting allows you to surf the net?
Feb 26, 2009 | HP Computers & Internet
I am connected to the internet but i cant open any pages
Maybe internet is because is not detect, check is fully connected.
Dec 22, 2008 | Microsoft Internet Explorer 7
How to set dsl modem
You go to start menu and access the Control Panel. Open Network Connections and make sure the LAN connection is enabled. If not, right click and select Enable. After confirming LAN connection, then go back a page and click Internet Options. Then the page will automatically show you the General Tab. Type in (or verify) home page in the window. eg. www.aol.com . Then select Connections Tab. Remove any connections that appear in the window below. Below that on the same page, select LAN Settings. Check the Automatically Detect option. This will allow your PC to detect your modem and your internet service. Select OK at the bottom and the window will close. Click Start again and select the Internet Explore. If your internet service is active the window will open to your home page. Good Luck!
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
54 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
