Question about Refrigerators
I have an amana afd2535deb the freezer stays cold but the fridge is warm and i feel no flow from the fridge bottom vents
    Sergeant:
    Champion:
  • 255 Answers
Check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Posted on Sep 24, 2009
  • jason king
    jason king Sep 24, 2009
    also check the heating element for proper Resistance.
My freezer is cold makes ice fridge is warm not cold at all
Look for frost on the rear of the freezer, that is a sign of a defrost problem. If the heater or heater thermostat is open then ice will form over the cols and block the flow of air.
Service manual for amana bottom mount
Jul 14, 2011 | Amana ABB1927DE Bottom Freezer...
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
My fridge compartment is warm... frezzer ok, How do I check to see if the fan is operating and how do I check the vents
A refrigerator temperature problem like yours is likely due to one of the following issues. Open the freezer door and listen for the freezer fan, you might have to close the door/light switch to activate the fan. There is a vent at the top of the back wall of freezer, as well as a vent at the top back wall of the fresh food section. Wet your finger and place it in front of either vent and feel for cold air flow. If you dont feel any air flow in the fridge and the freezer fan is running, you will likely have a defrost problem, either the heater, the bi metal t stat, or the defrost control have failed. Any of these will result in frost on freezer back wall. YOu may also have a problem with the damper door in the fridge, again, top back wall, not opening, or on the rare occasion I have seen a slice of wrapped cheese on the floor behind the fresh food crispers covering the warm air return vent to the fridge.
Oct 06, 2010 | Amana AFD2535DES French Door Refrigerator
My freezer works but my refrigerator wont stay cold...getting warm. it is 4 years old. what could be wrong?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 26, 2010 | Amana ABB1927DE Bottom Freezer...
Bottom half of fridge and freezer are cold top half warm?
This sounds like an air flow issue, If your freezer fan is running still you may have a defrost problem starting in the freezer cooling coils. This will cause the cold from the freezer to back flow into the bottom of the fridge and only the lower half of the freezer to keep very cold.
Most likely culprit for defrost issues would be the terminating thermostat (inside freezer behind back wall and clips to top of coils).
Good luck and let me know if you need more help!
Jun 14, 2010 | Amana 22.6 cu. ft. Side-By-Side...
My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Apr 13, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Tfx27fhc
The most common problem is the evaporator fan motor which is located behind the back panel of the freezer and it moves cold air up to the fridge.  You will be able to hear it when you open the freezer door.  May have to hold the light switch in the freezer shut for it to come on.  If the fan is running feel for air flow out of the vent in the top middle of the fridge section.  If you don't feel air and the fan is running then the damper motor behind that vent is bad.  All of this is assuming that there is no frost buildup on the back panel of the freezer.  If there is frost buildup then it is a defrost problem.  Let me know what you find.
Oct 10, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
295 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
