Question about Home
1/4 turn taps installation
I have bought 1/4 turn taps but my plumber can't seem to find a way to install them so that the handles are aligned in the off position and the taps can turn in the same direction to turn on (eg. both turn upwards or both turn downwards to turn on). At the moment, the taps are aligned in the off position but one must turn up and the other must turn down to be on, which is very confusing to use. There is also the complicating issue of the ''hot'' & ''cold'' writing to remain upright. Does anyone know a tip on how to install these taps?
  • 546 Answers
The only way to achieve what you desire would be to install two hot or two cold faucets.they were originally designed to turn opposite so the BLIND would know which tap they were turning.hot is left,cold is right.even w/my eyes closed.relax & enjoy a hot bath!
Posted on Sep 24, 2009
I have a Shower/Tub Faucet with UPC marked on it as manufacterer, can you tell me the full name of manufacturer?
check other hot water taps to check hot water is flowing from the hot water system(tap on heater not turned off)
check faucet handle is put on in the right place --only 1/2 movement to the stop
check for blockage to the hot water side of the insert ( incorrectly installed )
still with problems --call a plumber
Nov 21, 2016 | Plumbing
I bought a Stanley Screen & storm knob door latch recently (74-8258). The "spindle" connecting the inside and outside handles seems to "float", i.e., not be anchored in place. It seems that with repeated...
If the spindle is installed correctly, "floating" does not hamper proper operation. Review your installation and make sure the floating spindle is properly sated in the handle and alignment is maintained during the tightening process
Sep 03, 2013 | Stanley Hardware 748257 Black Screen &...
Remove lock hub from rotors 1995 toyota t100 4wd
1995 Toyota T100 4WD Pickup
Manual Locking Hub - Removal and Installation
REMOVAL & INSTALLATIONSee Figures 1 through 11
Fig. 1: Exploded view of the free wheeling hub
Fig. 2: Turn the handle with your hand to the free position
Fig. 3: Note the directions in which you can turn the handle: left-free, right-lock
  1. Remove the hub cover. Set the control handle to the "FREE" position.
Fig. 4: With the handle in the free position, remove the six hub cover bolts
  1. Remove the cover mounting bolts, then pull off the cover. Remove and discard the gasket.
Fig. 5: Pull the cover off
  1. Remove the bolt with washer.
Fig. 6: Using the correct size wrench, loosen ...
Fig. 7: ... then remove the center bolt and washer
  1. Remove the mounting nuts and washers.
Fig. 8: Next, remove the outside mounting nuts and washers
  1. Using a brass bar and hammer, tap on the bolt ends, then remove the cone washers.
Fig. 9: Using a brass bar and hammer, tap on the bolt ends ...
Fig. 10: ... then remove the cone washers
  1. Pull off the hub body.
Fig. 11: The free wheeling body should come off easily; be sure to discard the old gaskets
  1. Remove and discard the gasket.
To install:
  1. Place a new gasket into position on the front axle hub. Install the free wheeling hub body with the cones washers and nuts. Tighten the nuts to 23 ft. lbs. (31 Nm).
  2. Install the bolt with washer, tighten to 13 ft. lbs. (18 Nm).
  3. Apply multi-purpose grease to the inner hub splines.
  4. Set the control handle and clutch to the free position.
  5. Place a new gasket into position on the cover.
  6. Install the cover to the body with the follower pawl tabs aligned with the non toothed portions of the body.
  7. Tighten the cover mounting bolts to 7 ft. lbs. (10 Nm).
Fig 1.Exploded view of the Free Wheeling Hub
Fig. 2 Turn the handle by hand to the "FREE" position
Fig. 3: Note the directions in which you can turn the handle: left-free, right-lock.
Fig. 4 With the handle in the free position, remove the six hub cover bolts.
Fig. 5 Pull the cover off.
Fig. 6 Using the correct size wrench, loosen ...
Fig. 7 ...then remove the center bolt and washer
Fig. 8 Next, remove the outside mounting nuts and washers.
Fig. 9 Using a brass bar and hammer, tap on the bolt ends.
Fig. 10 ... then remove the cone washers
Fig. 11 The free wheeling body should come off easily; be sure to discard the old gaskets.
Oct 29, 2011 | Cars & Trucks
We bought a house last year that has a pool with a Laars Lite 2 heater. The drain plugs were not on the unit and we've tried to replace them, but it seems that either the treads are stripped or they...
We come across these from time to time and we were told that when the part is installed at the factory it is by machine...sometimes they end up so tight that removing them strips the threads. In the past we take a pipe tap out and re-thread the hole and then the new drain plugs will fit fine. It is a 1/4" MPT (often referred to as NPT on taps) pipe tap (tapered). You may find a local pool or pump service company or maybe a plumber that will lend it or make the service call to do it for a reasonable price.
John
Jun 21, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a Blaco eye BM 5300 tap and need to get the handles off to replace a washer. The setscrews have been removed but the tap handle seems firmly in position. Is there something else that needs to be...
Be very careful. I had a plumber help be and we ended up breaking the value with the bit stcu inside the handle. I managed to source a new handle, GBP12 plus VAT, but can't get hold of the valve!
Jan 21, 2011 | Blanco Plumbing
The entire faucet is lifting off and spraying water at the joint when the lever is activated and water is being used,do I need to call a plumber to repair this. It seems that the faucet cannot be screwed...
No you do not need a plumber,
below under the sink, there are two valves, One for Hot ,One for Cold.
Turn them to the right.make sure they are turn all the way with a little pressure at the end. Now the kitchen has no water.
With a wrench ot pliers remove the water hoses, There may be a little water left in the hose so don't panic.
Now this may be a little harder.
Put yourself all the way under the sink,with you on your back.
Do you see the taps. There may be a fitting with screws. remove screws and fitting. You should be able to remove the whole Tap.
With you new tap... Follow their instruction.
When you are putting the hoses back on.. make sure they are slightly snug.
We don't want it to leak again.
Turn you water back on and slowly turn on your taps.
Aug 05, 2010 | Rohl A3608LMAPC Single Lever Country...
Can't install new Kohler rialto Flush Value
First things first, remove the fill valve, and the flush handle mechanism. This will give you plenty of room to work with the flush valve. Before installing flush valve lubricate tabs with plumbers grease. Now put on a pair of work gloves, pushed down very hard and turn the tabs should slide easy because of the grease. Remember do not alter the gasket, the gasket needs to be compressed to do its job. I know removing the fill valve and the flush handle seems like a pain, but there is no way to get your hands in the proper position to install the flush valve assembly.
Apr 25, 2010 | Kohler K-3386-0 Rialto one-piece...
My Aprilaire is connected to the Hot water line and it stops working in approx 1 month. I just had plumbing work done and my new plumber said the problem it that it should be connected to the Cold Water...
Your plumber is correct your unit should be plumbed with cold water.
Easy fix if you need to do it yourself.
More than likely they have a 1/4 inch line taped into a 1/2 inch copper line near your furnace.
Simply shut off the tap on the undesired line and disconnect the 1/4 inch line.
Install a new tap on the cold water side and reintall supply line to the unit.
Do not remove the old tap on the hot water line simply shut it off because it puctures the line, hence the tap.
Jan 02, 2010 | Aprilaire 550 Humidifier
Plumber reversed the hot and cold lines during installation
Yes it can but I believe only the Pressure Balance Unit needs reversed.
1) Turn off water supply to unit
2) Remove handle/trim if installed
3) Remove cartridge by removing 3 screws holding cartridge
4) Remove retainer ring holding in P.B.U. in valve body by removing 3 screws
5) Remove Pressure Balance Unit, rotate 180ﹾ and reinsert
6) Reassemble in reverse order
Dec 31, 2008 | Plumbing
Home Logo
481 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
